Question about Dehumidifiers
I recently bought a Keystone KSTAD70B when I switched it on it made loud rumbling noise so we switched it off & let it set for 3 minutes but it didn't work again after that. What do I do?
Drains through hose and into bucket
this happens when the drain tube becomes blocked so unit overflows and water falls into bucket and not flows out tube , clean tube and drain port with compressed air (wear eye protection!!!)
Jul 17, 2015 | Keystone KSTAD70B 70 Pints Energy Star...
How can I purchase a replacement air filter for keystone kstad70b?
The filter in your Keystone KSTAD70B is meant to be washed. It is not listed as a replacement part in the owners manual. This is copied from the manual:
3. Clean the air filter
Remove the filter every two weeks based on normal
operating conditions.
Remove the filter from the top of the unit (See.Fig.11a),
or to remove the filter,remove Bucket then pull filter
downwards (See.Fig.11b).
Wash the filter with clean water then dry.
Re-install the filter,replace Bucket. CAUTION:
DO NOT operate the dehumidifier without a filter
because dirt and lint will clog it and reduce
performance.
If you have lost or destroyed the filter, go to Amazon and order the Duck Brand 1285234 Replacement Air Conditioner Foam Filter, 24-Inch by 15-Inch by 1/4-Inch, 1-Pack for 96 cents with free shipping as an add-on item to any order. It is also washable so you will be able to use it like the OEM filter material.
Jul 06, 2014 | Keystone Dehumidifiers
Continuous Drain
If the design is unique, Keystone may be the only source.
May 27, 2014 | Keystone KSTAD70B 70 Pints Energy Star...
Touch control for humidity setting only goes up, cannot lower setting, is touch pad defective and can it be replaced or not worth it anymore
Yes, the touch pad may defective. But, before you try to replace it, let's try something else first.
Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Wait 15 minutes and plug the unit back in. Turn the Master ON/OFF Switch to ON and set the humidity extraction level where you want it. Hopefully, that 15 minute time out allowed the unit to reset itself and revert back to the original factory settings.
If it didn't you can order replacement parts directly from Haier 877-337-3639 or locate a service center near you.
Hope this helped to solve the problem. Please let me know. Thanks.
Jun 03, 2011 | LG LHD45EL Dehumidifier
Recently bought a Frigidaire Dehumidifier four days ago. Ran it for 3 days on the co setting as the manual instructed. When I set the humidity level, after about 5 minutes it shuts down...does not come...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jan 21, 2011 | Frigidaire FDL25P1 Dehumidifier
Loud Vibration
Check the front water bucket handle.
Sep 10, 2008 | Haier Dehumidifiers
LD65EL Dehumidifier rumbles and has poor air flow
Sounds like the bearings have failed in the fan motor, & the rotor is rubbing on the stator. You mentioned end play in the shaft, check for cross play. There should be no perceptable cross play, any found indicates a need for a new motor.
Jun 20, 2007 | LG LD65EL Dehumidifier
Dehumidifiers Logo
105 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
