Question about Coffee Makers & Espresso Machines
Why doesn't water flow though to coffee on a new manchince
4 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: No coffee flows after grinding
Adjust the grind on the machine.
Posted on Feb 26, 2009
  • 115 Answers
SOURCE: My coffee tastes watery. It seems as though the
Hi, Your coffee is ground too coarse. Make the grind finer as this will slow down the flow rate. If you go too fine it will just dribble and over extract the coffee."bitter". Dazza REPAIRER
Posted on Sep 24, 2011
SOURCE: my basket always overflows, the water doesn,t empty fast enough
Here is the SOLUTION(S):
1. Buy a sprayhead that restricts the flow2. Let the water flow through for a few minutes, then lift the lid while it flows through.3. Don't use Decaf4. Plug up a couple holes on your current spray head
Posted on Dec 14, 2012
Why does my coffee come out in drips not a continuous flow?
Your pump is getting weak. Pumps are made cheap now days and are part of a planned obsolescence program. That way you keep buying new coffee makers.
Oct 15, 2014 | Coffee Makers & Espresso Machines
Ours does not finish cycle either!!! The machine runs through the cycle up until the point where water should enter the "brew group". The coffee doesn't come out. What shall we try?
I just fix that problem by opening the water flow meter by some coffee grinds, also had a little coffe grind jamming a check valve that is at last of the water pump flow, now is running pretty well
Dec 20, 2012 | Saeco Easy Espresso Machine
My basket always overflows, the water doesn,t empty fast enough
Mar 24, 2012 | Bunn BT10B Coffee Maker
My coffee tastes watery. It seems as though the water flowing through the filter is going too fast. My other Keurig at work brews much slower, and the coffee is delicious.
Sep 23, 2011 | Keurig B60 Coffee Maker
Our keurig powers but doesn't filter water through it or heats up.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 21, 2011 | Keurig Elite B40 Coffee Maker
My coffee maker states that it is brewing but it doesn t take any water out of the reservoir nor dispense any coffee
heatman101
Sep 19, 2011 | Keurig Platinum B70 Coffee Maker
After the coffee is ground and pressed, no water goes through to brew the coffee and dispense it
Sounds like the brew unit is blocked, to be sure try this, use the pre grounds button to brew a coffee, if no water comes out then it is the brew unit, remove unit and look under red o-ring, you will see a shower screen, clean shower and tube that flows to the discharge(top, you will have to remove the 2 screws up there, be careful not to lose the small plastic ball under the spring). Reassemble and try again.
Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
