Question about GPS
My tom stand on start - GPS
I need a stand for an Akai LCT3201TD
I'm fittin' to post one to eBay. In great shape and all the screws.
May 23, 2012 | Akai LCT3201TD 32 in. LCD Television
Need to identify and find parts for the Pearl FZH725/C85 Drum Kit. It was delivered with missing parts. Specifically Floor tom, 14" tom and arms to hold it. Need some direction and guidance, thanks.
I am a drummer as well in a classic rock band. Most the time when I need a part for something for my drums. I will go to guitar center. But to save money eBay is your best bet. You go to guitar center to make sure you have the right part, but don't buy it there . Match it up and go to eBay, lot of drum companies use eBay to sell there stuff. Thanks mike
Jul 22, 2011 | Pearl Forum FZH725/C85 Drum Kit, Zenith...
When i press the switch on button,the tom tom still remain on stand by light on with out the screen do not open or the map.what should i do?
You didn't give the model you have but all tomtom gps units have a reset. Check your manual to find it.
Mar 04, 2011 | Cameras
How do I remove battery from Tom Tom for recharging
what model do you have, i dont know of any tomtom that needs to have the battery removed to charge it.
Bill
EX
Standing Member of G.O.T.
Sep 27, 2010 | GPS
Cannot get TomTom One to turn on
make sure its charged, and on the bottom, where the tom tom docks to the charger/stand for the computer, there is a small push button that you can press with a straightened paper clip. its the reset button. give that a try. if you cant find it, let me know what model of tom tom you have.
Oct 03, 2009 | Tomtom ONE GPS Receiver
Have a 2002 triumph sprint st 955i, bike would
Hi, the problem lays with your side stand switch. This is designed to stop us riding off with the stand down. When the switch plays up the safety still works with the stand up. Try giving it a good clean and spray with WD40. It gets covered in crud from the chain lube.
Tom
Jul 07, 2009 | 2002 Triumph Sprint ST
Tom tom can't find sats signal
Try standing still outside in an open area. If you still don't get a signal it's probably broken but worth trying a reset - reset button generally underneath the unit needs a paperclip to operate it...
Jun 01, 2009 | Tomtom ONE 3rd Edition GPS
Screen continues to go out,touch it ,it reappears,every 20 second
Hello megbert, I own a TomTom also. I have listed the procedures from TomTom Home and hope this will work. First try a soft reset (Reset button is located at the bottom of the TomTom device next to where the DC plug plugs in). Make sure your batteries are fully charged up or the USB cord is plugged in.
If your device is not starting up properly, follow the steps below:
  1. Soft reset your device. *
  2. If your device still does not start up, then reinstall the TomTom application using HOME
If you have backed up your TomTom to your computer, then you can reinstall the TomTom application from your backed up data. *    In rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. A reset does not delete any data.
Jan 18, 2009 | Tomtom ONE 3rd Edition GPS
What is HOV stand for concerning the gps Tom Tom
HOV stands for High-occupancy-vehicle lane. Your TomTom may be able to find these lane, and let you use them.
More info can be found at:
http://en.wikipedia.org/wiki/High-occupancy_vehicle_lane
Oct 07, 2008 | Tomtom GPS
Electronic snare drum pad picking up tom tom triger signal ?
your right old and new technologies are all the same basic concept, a Piezoelectric transducer converts mechanical energy into an electrical pulse. Adjust/increase the cross talk (x-talk) setting on the module for your specific channel. this settings job is to disregard really small signals (ie. vibrations from the stand, other drums etc...), you may have to play the pad a little bit harder but it should work fine.
Aug 02, 2008 | Yamaha Dtxpress III Electronic Drum Set...
GPS Logo
27 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
