Question about Speed Queen Washing Machines
HOW to remove a speed queen washing machine vertically that is standing in a corner
The machine stands in a corner of the pantry - tight against the side and back wall; only 270mm front clearance to a corner cupboard and 80mm side clearance to basin cupboards. There is a cupboard above the washing macine against the side wall with a 710mm clearance to the underside of the cupboard. It cannot be slided out because of space constraints in the front; the only way is to lift it up and there is only enough space for a person or two to stand in front of it. The machine was put in the corner before the cupboards were built.
SOURCE: removing stand from tv
UNSCREW the FOUR (4) screws on the back panel (marked with an "S" next to their recessed holes.
Work with the panel screen-side up (ie on its back - we did it with the LCD on the bed), and just JIGGLE the stand back and forth until the screws drop out. This make take some doing, but using force is a no-no (as the screw mounts are only plastic). Obviously the screws MUST be undone, so just keep unscrewing them while someone else jiggles for you.
Thats it. The plastic cover (from the manual & warranty bag) covers the hole.
Posted on Feb 09, 2008
SOURCE: how to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
  • 15 Answers
SOURCE: tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Posted on Sep 06, 2008
  • 21 Answers
SOURCE: Remove stand
if the screws won't come out, then get a magnet, the small kind that is used in auto mechanics, that's what I use to finish pulling them out, or use a magnetice drill bit, but that's all that is holding the stand on
Posted on Dec 28, 2008
SOURCE: How to remove the stand
On the the sticker on the back of my SONY kdl-40xbr1, where the model number is, there is the symbol > x 18.  That means you need to remove the 18 screws on the back of the tv that have arrows next to them.  Most are around the outside but 2 were by the RCA inputs and 2 were under the cover for the computer input.
Once you remove all these screws the back will come off easily.  Remove the 4 screws holding the base on, slide it off and refasten on the back with the 18 screws.
Thats it.
Posted on Jan 31, 2009
Hi i have a speed queen toploder washing machine
It might need to be rebalanced or your connection are not tight.
Feb 01, 2017 | Speed Queen Washing Machines
How do I remove the agitator on a speed queen washer model # aws17nw
It has a large nut under the cap on the top of the agitator, but it will be the devil to remove due to a tight fit and corrosion.
Sep 28, 2016 | Speed Queen Washing Machines
What is the size and tread pitch of the 7/16" bolt that fastens the drive bell? The tread of the transmission output shaft was damaged during the removal. Speed queen lws11aw-3062
I believe that is a 1/4" bolt with a 20 TPI.
Also known as a 1/4"- 20
I've used a bottom tap to clean the threads,
Next time put the bolt back in and use the puller against it instead
Jan 10, 2015 | Speed Queen Washing Machines
When the spin cycle begins the washer vibirates and moves on the floor. After the spin cycle reaches the maxium speed it stops. The springs are fine, but what else could be wrong?
The machine is probably not leveled properly. To level the machine, partly fill it with water. Make sure that the drum is standing in the middle of the machine and then adjust the machine until the water is at the same level all around at the nearest set of holes to the water. Check that the drum is still in the center of the outer drum. Make sure that the adjusting feet are all firmly on the floor and that you cannot rock the machine at all by hand. A top loader must be 100% level or it will shake.
Jul 25, 2011 | Speed Queen AWS44NW Top Load Washer
Speed queen washer mod.AWM 593W How do youu lift the top of the cabinet to remove inner basket?
use a 5/16" nutdriver/socket and remove the two screws and the bottom of front panel and tilt panel out and then look and find 2 screws(one on each side) facing up on the corners of top/cabinet, remove those and raise top
Jul 22, 2011 | Speed Queen Washing Machines
Hello... Have a SPEED QUEEN Washer # HA4591L shaked vigourously for a while, then would only do partial loads while shaking, then stopped working all together. Any suggestions? Thanks in advance.
Balance it
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Apr 10, 2011 | Speed Queen Washing Machines
HOW TO REMOVE COVER TO SEE INSIDE UNDER THE COVERS
Normal 0 false false false MicrosoftInternetExplorer4 Try this.. Turn OFF the power. and remove the front vertical panel by inserting a drywall knife in a the top right about 4" in from edge at the joint 1" down from the top, push the clip back to release that corner, get another knife and do the same to the left top corner, the pull the top of the front panel and swing towards you, then lift off and remove.
Nov 09, 2009 | Speed Queen AWS52NW Top Load Washer
Why does my EPIC z walks during spin cycle even after I used the rubber pads? It moves from the right back corner out to the left.
Make sure that the leveling feet are secure with the jamb nut tight against the BODY of the washer. If not, the washer could walk during spin. Make sure that washer is flat level front to back and side to side with a 24" level. Just set the level on the top near the front and then on both sides as well. Adjust the feet and jamb nuts so that they are as low as possible. If washer is on a stand, remove drawer to adjust feet. Also, if on stands, washer will vibrate more due to increased height and natural flexion of stand. What kind of flooring? If ceramic tile, rubber feet may not couple to surface and provide enough friction to stay in place. I have had success with......I know it might sound stupid.....but buy a couple rubber jar opener pads and cut them into small pads. Put them under the rubber feet of stand or washer. These seem to make a better connection to the floor.
Aug 01, 2009 | Washing Machines
Washing Machines Logo
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
