Question about Water Heaters
Heatpump was switched off for 10 days. On return we switched the mains on and off to reset but water is still cold. Please help.
2 Suggested Answers
SOURCE: The water heater (Reliance Elec
Two-element water heater is 240Volts.
No hot water means: ECO reset button tripped, upper element bad, upper thermostat bad, or 240Volts is not reaching water heater.
Circuit breaker can be delivering power on one leg of the 240V circuit, so water heater appears to have electricity but is only receiving 120V.
Test for 240volts across top two screws on upper thermostat.
Look for loose wires and burned connections.
Push in reset button real hard.
Replace both upper and lower thermostats.
Remove wires and test upper element for continuity.
Open following links for do-it-yourself troubleshoot walk-thru:
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Posted on Aug 21, 2011
Suburban Water Heater-Sw10de-10 Gal Gas/Elec W/Direct Spark - 5063A
Manual Yes 12 volts may help. I can't see anything about your switch from this manual
Dec 02, 2013 | SUBURBAN MANUFACTURING C Suburban Water...
Boiler working but radiators cold
Seems that you may have bad circulation pump.
Feb 24, 2013 | Water Heaters
The water heater (Reliance Elec 501) does not turn on, This happened on the same day that our whole apartment lost power due to tripped main switch.n I reset main but water heater does not respond,...
Aug 21, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a 1991 40 gl and it fell through the floor which is like 2 ft off the ground. turned the water off and replaced the pipes it has its own lever type power supply with the screw in fuses 30 amp (2) of...
You have 2 problems with several possible causes:
You have 10-year-old electric water heater that was reinstalled after falling down, and doesn't heat the water.
And you have no hot or cold water pressure, and no pipes are leaking.
1) First problem is lack of water pressure throughout house.
Turn on outdoor spigot nearest to water meter.
This spigot will tell you if problem is inside the house or between the house and meter.
If spigot runs full force, then you probably have clogged pipe where water heater connects to main cold line, or the main shut off valve got clogged with sediment that broke off inside the pipe when you were working on water heater.
Open and close shut off valve to see if that helps. Then disassemble pipes and track back the problem. Put pressure gauge on water heater drain valve to watch pressure drop when turning on indoor faucet.
Read following information:
http://waterheatertimer.org/Low-hot-water-pressure.html
Water heater doesn't work:
Test across wires at top of heater to see if you are getting correct voltage:
If tank is receiving correct voltage, then no hot water puts suspicion on upper element or upper thermostat, or both.
Open following link for electric water heater troubleshoot steps:
Jul 30, 2011 | RELIANCE ELECTRIC WATER HEATER
GE gas water heater smart shield manufactured date 10/2004. Water is rust colored. Have drained heater twice and it clears for a day or two and the rust color returns. Suggestions?
Anode rod is depleted and tank is rusting:
New anode rod will stop tank from additional rusting, but will not repair rust damage.
http://waterheatertimer.org/Replace-anode-rod.html
If rusting has been going on for a while, the steel tank could be weakened, and maybe rupture.
http://waterheatertimer.org/Water-heater-is-leaking.html
I suggest replacing water heater, loosening anode before install, and then checking anode rod each 2-5 years so tank last longer. Also add a ground wire between hot and cold pipes to avoid water heater deterioration from stray current.
Buy new water heater from local hardware or box store and offer 10% less than price, or have them install.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 25, 2011 | General Electric Water Heaters
Hello we have Bradford hot water tank model #MI65R6DS13. Our problem, I keep having to press the tanks reset switch for us to get hot water. At the same time after I press the reset switch we have hot...
No the top thermostat is the first place I would start to replace. They run about 14.00 more than likely it isn't controling right. Turn power supply to water heater off and replace thermostat.
If you was getting scalding hot and then turning cold without tripping the thermostat it would be the top element working and the bottom one bad.
Bottom element good it will give you luke warm water for a while then gradually turn cold because it's heating the bottom of the tank.
Hope this will help you out.
Oct 09, 2010 | Fasco Bradford White Hot Water Heater...
I have a 135 litre, 10 year old Rheen mains pressu...
usually on the hot water piping, It starts to rust closed faster than the cold side, due to electrolosis. What you r discribing are the first signs of this happening. only solution is to replace the effected pipes..
May 20, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have low pressure on my Worcester Bosch 30si but I can't remember how to fill it up, please can you help?
connect filling loop from cold main too heating flow or return you,ll find teed pressure system by short quick flicks at the valve on the cold supply best of luck
Nov 29, 2009 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
