Question about Crock Pots & Slow Cookers
How to make turkey stock with my new pressure cooker.
Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
Mar 03, 2017 | Crock Pots & Slow Cookers
Owner manuals for pressure cookers
Presto®: Instruction Manual Downloads
National Presto Industries150+ items - A listing of instruction manuals for selected Presto pressure ... STOCK NO
4-Quart Aluminum Pressure Cooker.
01241 Manual.
6-Quart Aluminum Pressure Cooker.
01264 Manual.
Presto® 23-Quart Pressure Canner
Jan 08, 2016 | Crock Pots & Slow Cookers
Steam release valve is not very tight....very loose. how do you install it?
I posted the same question, as I was very nervous about the loose fitting steam release valve. I thought for sure it was defective. I have never used a pressure cooker before and I think most people are nervous the first time. I finally called customer service and was told this is how it is supposed to be. It's supposed to be loose, and the lid won't fit tightly. Everything works out fine when you start the cooker. The valve tightens up and the lid fits securely. Keep in mind also that it takes quite some time for the cook cycle to begin. When it took so long to start the actual cooking, I thought yes, I was right, this one is defective. But I cooked a perfect turkey breast and am continuing on to make turkey soup. I hope I have helped, as there doesn't seem to be anybody who wants to share their knowledge with us newbies!
Feb 08, 2011 | Wolfgang Puck 5-Quart Electronic Pressure...
My boyfriend accidently tossed our instruction manual and I have no clue what my settings are I want to make a turkey roast what setting would I put it on?
On a thawed turkey it will take about 20 minutes per pound on 350 degrees. About 25 minutes per pound if you have a stuffed turkey.
Nov 30, 2010 | GE Crock Pots & Slow Cookers
Where can i find instructions for cooking a turkey in a bella cucina oven roaster?
Here are the settings
Turkey, fresh, 10 - 14 lb, 350° F, 15 to 17 minutes / pound
A roster is a roster... when it comes to cooking they all cook by time and temp.
Time and temps can be found in this rival manual:
Here are 2 recipie sources:
With any search engine (google, yahoo et al) use this search phrase for more recipies:
Roaster oven baked Turkey
Thanks for choosing FixYa,
Nov 25, 2010 | Crock Pots & Slow Cookers
New Rival 22qt. Roaster Oven
If you want to use it for food tomorrow, you need to burn it in tonight; 1 hour or longer at 400 degrees, outside but protected, to burn off the factory oils, etc. If you cook in it without doing this, you will ruin the food (and the atmosphere) with bad smells.
This turkey is really bigger than Rival recommends for this roaster, so check the size/fit tonight, also. You need an inch all around for best cooking.
I use 325, not 375 as the Rival manual suggests, 4 hours for an unstuffed 18 pounder.
Nov 24, 2009 | Crock Pots & Slow Cookers
Need a new rubber seal for the lid of my pressure cooker 6qt
Need to have new rubber installed on my pressure cooker lid, but cannot find anyone to do it. Presto says they do not do the labor but will send me the rubber???? Any suggestions?
Nov 10, 2009 | Wolfgang Puck Electric Pressure Cooker...
Crock Pots & Slow Cookers Logo
60 people viewed this question
Top Crock Pots & Slow Cookers Experts
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
