Question about Electrolux Vacuums
Electrolux EV4602 - how do you remove covers - Electrolux Vacuums
I need to find out how to open the cover to change the motor filter on my Electrolux Epic Series 6500 sr canister vacuum.
There is not a replaceable motor filter inside the body of the vacuum. There is an exhaust filter under the cover on top which can be removed by pushing a little tab at the rear of the cover.
Nov 15, 2017 | Electrolux Vacuums
Electrolux model el6984a how to remove cover
the rubber sile slide off.Please be very careful as the winder is controlled by a metal coil and is under a little of pressue and very sharp.....
Jun 16, 2014 | Electrolux UltraLux 2000 Bagged Canister...
How do I dissasemble Electrolux EL4101A?
there is a buton that you press on one side or the other of the cover and when you press it and hold it down you should be able to pull the cover right off
Mar 28, 2014 | Electrolux Guardian Bagged Canister Vacuum
Carpet attachment with beater brush not working
Resolution for Quick Connect Power Nozzle: If you're vacuum is 2001 prior, chances are one of the two contacts in the power nozzle elbow have let go.
The elbow can be disassembled by removing the two screw covers. You will need a flat head and small star. Also, you need to release the retaining clip on the back of the elbow. You will have to remove the elbow completely if it needs replacement. You will then have to remove the top cover of your power nozzle. That is easily done by removing all screws in the bottom base of your nozzle. Once you remove your cover you should see 2-4 screws holding in the elbow
When you remove the cover, you will see metal contact rings and two contacts. If one of them isn't contacting the ring your power nozzle will not turn on. You can try shaping it back into place but from experience the new revised elbow that does away with that kind of connectivity is a lot more effective. The new elbow runs about $40-$60. Between eBay and Aerus Electrolux Dealer.
Jul 12, 2010 | Electrolux Centralux Vacuum
How is the motor cover removed?
Two screws at the front, accessed by opening the dust bag lid. Two screws at the rear accessed by prising off the on/off switch and rewind button covers.
Jan 05, 2010 | Electrolux Vacuums
How replace lightbulb on carpet beater (Electrolux central vac). Can't find any screws near light
To replace the bulb you will have to remove the power nozzle cover. Remove the cover by extracting the screws from the bottom. Take notice of which screw comes from which hole. Depending on the year, one screw may be shorter than the others. If put back in the wrong place, the screw will come through the cover when replaced. Once the cover is removed it's easy to replace the bulb. Make sure everything is lined up when reassembling.
Dec 30, 2009 | Electrolux Centralux Vacuum
How to remove the motor cover?
There are 2 screw under the removable outlet cover and 2 more under the shiny label under the booster slider. Pick off the label to find them.
Dec 05, 2009 | Electrolux Vacuums
Can't remove motor cover for electrolux EL2050
usually there are screws on the bottom, normally 6-12 screws. Once they are out, there may tabs on the outside of the base fram, lightly use two flat head screw drivers and pull the cover away from the base.. be gentle as this plastic is thin, and could break. You will also need to make sure that the handle assembly is in the down position as the cover can get caught up in the handle when you try to remove it.
Jan 20, 2009 | Electrolux Vacuums
Older electrolux on/off switch
I'm not exactly sure which model you have, but I'll take a guess. Usually there are four screws that hold the cover on the top of the machine. One in the very front, one in the handle, and then two under the sliding exhaust cover near the rear. There are variations of this but it's usually the two exhaust screws that get missed. Good Luck!
Jan 01, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Cover won't close
Try removing the bag and closing the cover. Unless that piece that holds the bag has gotten loose, there isn't anything that should prevent that cover from shutting, so it may just be the way the bag is sitting.
May 03, 2008 | Electrolux Harmony Canister Vacuum -...
Vacuums Logo
67 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
