My thermostat is st on 70 but only reaches 63 and goes off
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
May be the thermostat is defective or is not installed correctly
Thermostat is heating house to desired temp before programmed time
there is a installer setup in this thermostat. do you still have the book?
you will need to gain access to the installer setup/programming and in it you will find a setting called auto recovery turn it off. what this does is after a few days of initally running the system figured out it needed to come on earlier and is starting before the set time to come on... you can turn it off and then will have to adjust depending on insulation value/construction type of home how soon you want it to come on so that it reaches desired temperature when you want...
hope this helps you out,,,
Nov 21, 2011 | Honeywell Programmable Thermostat Heater
This unit has a manual thermostat. Is there a way
60 IS A DREAM TEMP MOST UNITS WILL NEVER REACH THESE TEMPS. THERE NOT MADE TO. AT 60 YOU LOWER THE HEAT ABSORPTION INSIDE AND OUTSIDE AND WITHOUT HEAT IT BEGINS TO ICE UP WHEN IT IS 70 INSIDE AND 70 OUT SIDE YOU WILL ICE UP 75 IS GOOD SETTING. IF YOUR TSTAT HAS A HOLD BUTTON SET TEMP AND PRESS HOLD THAT MY HELP
Apr 20, 2010 | LG LXA1030ACL Air Conditioner
Installed the Honeywell RTH2300
at the thermostat you have a small tolerance (most have 5% + or -) few degrees is not a problem ex...70F= 21C and 82F=27C this diference is inertial, you can set a lower temperature(ex...60 F to reach 72 F) the problem is if the temperature grow and never stop until the saftey thermostat stop the heating.also is posible to have a broken thermostat(work thermostat) and in this case it must be changed whit new one or the teperature probe is plced in a wrong place.
Feb 14, 2010 | Heating & Cooling
Set back thermostat has mind of its own.
The Honeywell Vision Pro 8000 can be complicated to figure out if it isn't set up right from the system menu. There are so many things that you can make it do, sometimes the most common things are wrong. My question is ''what kind of system do you have, heat pump or not?, and is the system gas or oil?" If I knew these things, I could definitely help you figure out if the thermostat is set up right. I have the manual so that I can give you exact numbers. Just in case, you can email me at : kingbrizzle@aim.com
Feb 06, 2010 | Honeywell Programmable Thermostat Heater
Furnace shuts off at 63 no matter where i set the thermostat
check the selector switch on the thermostat and if you have gas, it should be on HG. If you have electric, it should be on HE. If you have an amp meter(clamp on style), check the white wire for amperage with the heat on. What ever the reading(.7 for example) set the heat anticipator located on the subbase to that number. this is for efficiency and must be set to the proper setting or the heat will not cut in and out properly
Jan 02, 2010 | Honeywell Electronic Programmable...
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
Thermostat temperatures not reaching preset Energy Star settings
Well with a boiler system like you have it will cost you more money to heat your house that way than if you leave it like it is. With a boiler system it takes a lot longer to heat an area than with a furnace. The best thing you can do is find a happy medium and leave it there at all times. If you read the paper work on your new thermostats they have a set procedure which tells the thermostat if you have forced air or boiler system. Do you have baseboard or in-floor heat how many zones do you have.
Jan 07, 2009 | Honeywell Electronic Programmable...
Need help with rth230b
AFTER ST UP. HOW DO YOU PUT IT IN PROGRAM MODE?
Jan 23, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
