Question about Boating
Yamaha 80 outboard poor performance on pul off and sounds like engine not reving properly
80 yamaha outboard
Fame_Guru
  • 483 Answers
SOURCE: Yamaha outboard motor manual
You got it :
http://www.yamaha-motor.com/outboard/service/viewmanuals/outboard_manuals.aspx
here !
Posted on Mar 20, 2009
mcgyver468
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
canbruce75
  • 1776 Answers
SOURCE: how to service a tilt/trim on a 50 hp yamaha
To check the fluid level, tilt the motor up and engage the tilt lock lever. Open the bolt on top of the tilt/trim reservoir. The fluid should be even with the bottom of the bolt hole. If not add some fluid. When you put the bolt back in, run the trim up and down a few times. That should purge any air out of the system. Always be on the lookout for any leaking hoses or fittings. Hope this helped and best wishes.
Posted on Aug 31, 2009
SOURCE: year model of yamaha outboard and fuel mix ratio
See linked manual!
JD
Manual
Posted on Sep 26, 2009
  • 86 Answers
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Posted on Oct 16, 2009
Hi, can you tell me the year model of my Yamaha 40hp outboard? Serial number 452214.
Search Results
Yamaha Outboard Serial Number Location and Model Identification ...
https://www.perfprotech.com/.../yamaha-outboards/yamaha-outboard-serial-number-l... The Yamaha Outboard Motor MODEL, PRE-FIX and SERIAL NUMBER are stamped on a plate attached to the transom clamp bracket. When ordering parts and/or accessories from our Yamaha OEM Online Parts Catalog it's important to properly identify the exact model you are dealing with.
Yamaha Year Models - Hunts Marine
https://www.huntsmarine.com.au/pages/yamaha-year-models This Yamaha outboard year model chart will only work for Asia Pacific distributed engines. If you have a Yamaha engine that has been bought in from America or E. ... For Asia Pacific engines your year model code is found on the bottom right hand corner of your serial number decal. It will be a single letter as per the ...
Decoding Yamaha Outboard Motor Model Number and Manufacture ...
www.murrayyachtsales.com/decoding-yamaha-outboard-motor-model-number-and-... Dec 30, 2015 - Decoding Yamaha Outboard Motor Model Number and Manufacture Date (MFG Date)
Yamaha Outboard Serial Number Lookup
uvgb.you4k.top/ By Darnell Zacharias. DOWNLOAD Yamaha 60HP (60 HP) Repair Manual 1984-2009 Outboards 8.8. By Michael Hornby. HOT. How To Decode A Suzuki Outboard Serial Number 8.4. By Ralap James. Mako 261 Center Console Boat For Sale at Unreserved Auction (Inv.3368) 7.1. By Aldrich Child. yamaha 40hp 2 stroke ...
Outboard Spares YAMAHA Model Year IDENTIFICATION CODES ' eBay
www.ebay.com/gds/Outboard-Spares-YAMAHA-Model-Year...CODES-/.../g.html Outboard Spares Yamaha Outboard Model Year Identification Details needed for ordering outboard spares parts On the Serial Number Plate on most Yamaha Outboards it will be in this format 6E9-L-675634 The...
Jan 15, 2018 | Yamaha Boating
Problem with yamaha 50 hp
Check the oil level to see if it's over filled... Use Google for other options.
May 11, 2013 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
50 hp yamaha outboard mid 1990's
2 stroke ?? choking up do you mean ? what oil make and mixture ratio ?
How to adjust carb on 1973 dt 80 cc
Hi, Cori if you have changed your fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" your not getting enough fuel.
1. Closed to 1/8 throttle is managed by the air screw and pilot/slow jet.
2. 1/8 to 1/4 throttle is managed by the air-screw, pilot/slow jet, and throttle slide.
3. 1/4 to 1/2 throttle is managed by the throttle slide and jet needle.
4. 1/2 to 3/4 throttle is managed by the jet needle, needle jet, main jet, and air jet.
5. 3/4 to wide open throttle is managed by the main jet and air jet.
6. Wide open throttle is managed by the main jet.
If you are running lean, spark plug electrode color is white, engine runs hot and feels like it is starving for fuel you need to go up on the jet size or move the c-clip down one notch. If you are running rich, spark plug color is black or dark gray, engine runs cool, and bogs down when accelerating you need to go down on jet size or move the c-clip up one notch. When your carburetor is properly tuned for maximum performance your spark plug electrode will be a light tan color like coffee with cream. If you prefer fuel economy over performance you can go down on main jet sizes until a satisfactory level of lower performance is acceptable versus MPH, your spark plug color will be whiter and your engine will run warmer. These tuning adjustments will only make improvements if your intake and exhaust system have no air leaks or sealing issues and the entire electrical system is in proper working order and you have no mechanical issues. For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have nice a day.
Carburetor Set up 101
1983 Yamaha DT80 Enduro Part 1 Rebuilding Cleaning Carburetor
Yamaha DT80MX Service Manual
OEM parts for Yamaha
YAMAHA DT50 DT80 MX MULTI LANGUAGE SHOP MANUAL 1981 1984 Download Manuals...
http://mybikemanuals.com/yamaha/yamaha-dt
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 13, 2013 | 1973 Yamaha DT 360
Trying too establish what year this motor is it a 2 stroke 80 hp 6hoL450289 yamaha outboard motor.
Try contacting Yamaha direct or a reputable outboard dealers for the address, they will point you in the right direction, like all motors manufactured the makers keep a record of the serial number, i recently tracked this down for a friends Perkins Diesle engine that is running a generator in the middle of Spain, it turns out that his engine came from a 1912 lorry.
Good luck
lacala69
May 14, 2011 | Computers & Internet
My R15 is flashing Yellow Light whenever i cross a speed of 80-90. I do not see the light when i am riding it slow.PLease help.
I have purchased a R15 YAMAHA from dealer Bangalore Wheels in Bengaluru on 11th April, 2010. The looks, speed and performance are almost as said in by the company. The battery used by Yamaha company is a poor substandard and unheard name MINDA battery. It will invariably fails within 6 months from date of purchase. The Company/Dealer will say it is not battery fault but our fault as not properly maintained and not using vehicle for more than 50 KM per day. This was not told when we purchased the bike that everyday we should use 50 KM. The service and pickup of the vehicle to be improved to the promised standards. This type of service and wrong original parts selection was not expected from the YAMAHA company. After buying we do not have any choice except to accept the vehicle as it has come. YAMAHA listen and keep your name and reputation.
Madhava Rao H.K.
Mar 17, 2011 | 2008 Yamaha YZF-R15
2000 Yamaha YZ 80 poor idling
Hi, Shaundavies6 and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yz 80 2001 model Carburetor tunning Trouble
Life On 2 Wheels
Yamaha YZ80 service manual repair 2001 YZ 80 YZ80LW Download Manuals... $8 cheap
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Oct 24, 2010 | Yamaha Motorcycles
Boating Logo
66 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
