Question about Kitchen Ranges
Glass top temreature control not working - Kitchen Ranges
One of my glass top plates doesn't work, it goes red and then turns off. How can I fix it?
I have no idea what you're talking about. Glass top plates? In a microwave oven? All I know is the glass turntable tray. And if it's not turning around, you either have that feature turned off (a dedicated button on the control panel), or else the turntable motor is bad.
Sep 09, 2014 | Microwave Ovens
The glass of scanner hp2510 is broken how can i remove it and fix it
I can tell you how to get access to the glass panel, although I cannot remember how easy it is to remove the glass itself:
First remove the lifting lid by unplugging the jack plug connector at the back, then riase the lid to vertical position, pull the plastic tab in the middle of the hige towards you and wiggle the lid upwards so that it comes out. Then pull off the keypad label plate, then gently pull off the control panel (which has two ribbon cables attached) by sliding it forwards from back to front of the printer. Disconnect the ribbon cables from the control panel (they pull off) and thread the cables back through their retaining clips on the top cover. Now you can remove all FIVE retaining screws (Torx T-10 driver required) from the top cover and lift it off, leaving the ribbon cables in situ. You can then turn the top cover over and work on removing/ repairing the glass. I would say it s not worth bonding - just get a new piece of glass.
Mar 25, 2013 | HP PSC 2510 All-In-One InkJet Printer
I need a replacement glass top for my Thermador CEP 365/CET365 cooktop. It is cracked but works fine. Where can I get this?
contact the service agent for the brand to see if a replacement glass is available
in reality you are not required to replace the glass as glass breaks in normal use and is out of your control and in renters terms comes under fair wear and tear
Dec 21, 2017 | Thermador 37 in. CEP365 Electric Cooktop
Ge glass cooktop range won't bake or broil. error fault codes f7 and g6
see the cause and fix it for F7:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jul 20, 2012 | GE Stove / Oven / RanMain Glass Top Assy....
TOUCH CONTROL HOB (SCHOTT CERAM) GLASS CRACKED
Hi. Yes you can buy a new glass. Most of the come with frame top now. If you get me the model # I can look this up for you and get you an idea on cost.
Vic
May 18, 2009 | Cooktops
I have a GE profile Glass top M#JSP47COF4CC That is cracked but can't figure out haw to remove. Have already removed 4 screws under control panel still won't budge
To remove the top on this range, remove burner knobs and face plate, then remove 2 screws from control panel one at each end. Fold panel down out of the way, remove 5 screws accross front of control panel and release 2 quick connect plugs for burners, then lift to remove glass top. Flip over remove 2 screws and clips from each burner and the indicator light assembly just pops out. Transfer this to new top and reverse your steps for removal.
Mar 27, 2009 | Kitchen Ranges
Glass top is scratched no matter what I do. oven doesn't work ri
glass top stoves are not designed to do canning on, sorry. the only thing you can do for the top is that special cleaner as it has a "wax" in it and will help to prevent stains, but not scratches.
remember your top is glass and it will scratch.
your oven can be calibrated to help it to bake better. what you need to do is make sure you have a temperature problem that can be corrected by calibration. try to just set the oven temps up or down 10 or 20 degrees and try to bake the same items. if this helps then you can reset the calibration of the control as per your owners manual, if you dont have one then i can tell you how if you can tell me the brand and model.
Dec 11, 2008 | Tappan TGF320 Gas Kitchen Range
HP 6110 scanner glass is cloudy
Here is how, but it seems a lot of work.
- Remove all the torx-screws
- Remove the little glass on the left side
- Remove the Control Panel Cover (lifted it a little with a screwdriver and released two latches)
- Remove the Control Panel itself (another two latches&move to the left)
- The whole top of the 6110 is attached to the bottom with 4 latches. I remove that, turn it around and clean the glass.
Note: The cables between 6110-bottom and control panel/feeding unit are long enough to set those things aside.
Dec 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Glass top repair
Replace the glass top...
Jun 10, 2008 | Frigidaire Cooktops
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
