Question about Beko Refrigerators
Brand new beko fridge/freezer the fan is not working is it supposed to be on all the time or is it itermitting
bobotfel
  • 236 Answers
SOURCE: beko fridge freezer humming
- Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object.
Posted on Jan 12, 2008
  • 29 Answers
SOURCE: Our beko frost free fridge
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Posted on Aug 13, 2008
  • 1462 Answers
SOURCE: I have a Beko -
i assume this is a frost-free type.
remove the back panel inside the freezer and check if the pipework is frozen up. if so, melt the ice off with a hairdryer and get back to me for further details
Posted on Sep 04, 2008
Bogie Boy
  • 46 Answers
SOURCE: my mothers beko fridge freezer making bubbling sound
Sounds like the evaporator fan is doing its job. Nothing to worry about. Good hearing is a blessing all fridges make different sounds some click loud while others gurgle loud. Some pop and snap. Till I got my hearing aids I didn't know mine ran so loud and clicked.
Posted on Dec 16, 2009
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
Fan not working, fridge not cooling anymore, freezer seems ok
Hotpoint Fridge Freezer RFA52 BUT I DONT KNOW WHERE IS THE FAN CAN SOMEONE HELP ME TO TELL ME WHERE IS THE FAN IN MY FRIDGE SO I CAN DEFROSE IT.
PLESAE EMAIL ME ON: RAFIK02UK@YAHOO.CO.UK
MANY THANKS
Posted on Mar 01, 2010
Hi. Why has my Beko fridge freezer ceased freezing. Fan & light still function.
compressor is running? u can hear it? may have a freon leak? or check the defrost timer or cold control thermostat, some freezers have a freezer thermistor may have gone bad can check all with a multi meter
Mar 10, 2015 | Beko Refrigerators
Why does the new fan in my Beko AP930 not come on. It worked for 30 minutes when I first installed it.
Three possibilities: 1) new fan motor failed or is jammed by something
2) power is not getting to the new fan. 3) The fan run circuitry is not getting the 'run' signal from the temperature sensing system.
Jul 23, 2014 | Beko Fridge Water Filter Ap930 Ap930x...
Why won't the new fan on my fridge freezer work
The new fan motor may have failed!. Check the power supply to the fan motor. If the fan motor was not designed for the very cold air (-20 F) it simply stuck.
How the fan for beko fridge. work.
Please restate you question with better grammar & spelling.
May 07, 2014 | Beko Fridge/freezer Thermostat Genuine...
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
My mothers beko fridge freezer making bubbling sound
Dec 15, 2009 | Refrigerators
Thick ice build up behind freezer fan
check door rubber,if is oblate heat it with fan,if it is ragged change it.
Jun 29, 2009 | Freezers
My freezer works perfect but everything in the refrigerator doesn't get cold enough. My milk sours. My fridge is an inglis and supposedly brand new
Warm fridge cold freezer problem fixed
In the freezer section there was a one screw removable panel which housed a four bladed rotary fan. One blade had broken off adn was jamming the fan from rotating. Once the broken part was removed the fan was free to rotate, but out of balance, but it did get the fridge going again. It took about one minute to replace the fan once a spare was aquired. Now I understand how it works, if one side of your fridge freezer is not working it can only be the air movement or lack of it Robert
Robert
Dec 30, 2008 | Refrigerators
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Refrigerators Logo
70 people viewed this question
Top Beko Refrigerators Experts
AJMAL KHAN
ray gallant
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
