Question about HP Computers & Internet
How do I solve a problem with starting up windows in my hp pavilion g6? Whenever I start windows a blue screen appears and the computer restarts.
Whenever I power up my computer a blue screen appears and the computer restarts, and whenever I try to re-install windows it shows that there are no drives found.
  • 3 Answers
Sounds like your hard drive has either failed, come disconnected, or someone performed a full format of the drive which wiped out the partitions or the boot sector of the drive. Worst case you will need to replace drive and purchase reinstall disk from hp. Best case you will only need to purchase reinstall disk from hp. If you do need a new drive, I recommend purchasing it from hp directly, as it will already be prepared with hps proprietary boot configuration files which must be present for hardware to be recognized by system bios.
Posted on Dec 31, 2016
Testimonial: "I do really appreciate for your cooperation and answer, it was really helpful."
    Top Expert:
  • HP Master
  • 42,671 Answers
Go google and type in --- hp pavilion blue screen on start up---
you will need access to another computer for this and there are hp support sites that will help
startup symptom--computer displays a blue screen or continually re-starts
use this document if the led lights glow or you hear the sound of a fan or hard drive spinning and the hp or compaq logo displays briefly but then the notebook stops responding and displays a blue screen. In some cases the computer may be operating in windows but suddenly crash and stop responding. In most cases , an error message is displayed on the blue screen, the computer does not respond to commands typed on the keyboard and it is necessary to press and hold the power button for 15 seconds or more to turn off the computer
The most common cause of this problem is conflicting instructions from multiple programs or drivers . Installing a new program that is not compatible with the hardware or another program may cause blue screen error
do this first--perform a hard reset
if a pc fails to boot properly, you should perform a hard reset as the first procedure
1--- disconnect all peripheral devices and remove all usb devices and media cards
2--- disconnect the ac power adaptor, remove the battery and then press and hold the power button for at least 15 seconds
3--- reconnect the ac power adaptor( but do not connect the battery) Press the power button. Look for glowing LEDs near caps lock and number lock keys and listen for sounds of a disc drive and fan turning
there are actions to take for error messages so it is to your advantage to get the hp support screen up on another computer and read what has to be done
( extracts from support hp.com)
if you want more assistance call hp support
    Top Expert:
  • HP Master
  • 22,121 Answers
Set the first boot to DVD and place your system sisc in the DVD drive. Power up the laptop and you can install a new OS by booting from the system disc.
Why won't my HP Pavillion G6 turn on after downloading windows 8.1 update?
try disconnecting power supply and removing battery as well then replace both and try again.Is it possible there was a power interruption while update was downloading. have you tried to access the bios on startup (press f9 at start of startup until it goes to bios)and see if all settings are ok
Sep 01, 2014 | HP Pavilion G4 G6 G4-1000 Series...
Pls help me; my hp pavallion g6 loaded with windows 7 boots with a white screen no d
May 08, 2014 | HP Pavillion G6 1d72nr I3-2350m 15.6"...
How to fix unexpected shutdown due to Blue screen problem of Pavilion HDX9494NR
See if the Check disk utility will solve your problem. To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Mar 31, 2012 | HP Pavilion HDX9494NR Notebook PC
Hp pavilion slimline s3600t desktop pc - Wont boot up, flashes to blue screen after hp blue screen and restarts. no option for safe mode either
A Blue Screen is more time than not indicative of a driver issue or some hardware issue. First of all when it boots to the screen that shows Safe Mode and the other options, scroll down and see if there is an option to Stop or Disable Automatic Restart on Boot. This will stop the screen from restarting itself when the blue screen appears and give you a chance to read and see what the error is. Afterwards it is ok to run Startup Repair. Startup Repair does not delete any of your personal files. Let startup repair run and then see if it boots. Once again, startup repair does not delete any of your music, documents, pictures, videos or programs. System Restore does not delete any of you documents, music, pictures, videos or programs. System Recovery WILL DELETE all of your music, pictures, videos, documents & any programs you've added since you brought the computer home from the store. System Recovery sets your computer back to the very first time you turned it on after you purchased it. I would run the startup repair, if that does not fix your problem, see if you can run a System Restore. A lot of time the Restore Points are damaged or missing when this happens, but give it a try and restore to a point before you started having the blue screen issue. If all fails you're going to need a system disc so that you can get into the Recovery Console so that you can enter a dos command in the little black box that opens up with white letters. You want to type: chkdsk /r
Let it run. It will run well over an hour and you will notice the percentage of completion going from high to low, but that's ok. Let it run to completion then try rebooting. If this doesn't work, you're going to need to take it to a repair shop or reload the operating system yourself.
Mar 19, 2012 | HP Pavilion Slimline s3600t Desktop PC
My Compaq Presario V3000 has a problem with the wireless on it. Whenever the wireless side-switch is turned on before I turn on my laptop, before it shows the login screen a blue-screen message shows...
you should reinstall the wireless drivers on your laptop go to the hp support site and type in the model number (it can be found on the white service tag under the laptop)
Jun 14, 2011 | Computers & Internet
Windows keeps failing to start an screen stays blue how do i fix it?
1) Restart your computer.
2) Keep the F8 key pressed.
3) Before the usual Windows logo screen appears another screen pops up with lots of options.
4) Select repair computer.
This option lets you repair your computer or even format your computer to the factory condition.
Nov 18, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
My HP Notebook first showed a black screen and then after a hard shutdown and restart it only shows a black screen with colored lines. It seems that it is starting up even though I can't see the screen.
Try this,Start in VGA mode.Once started,update your video drivers
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Safe Boot options loadTOCNode(2, 'moreinformation');
  • Safe Mode (SAFEBOOT_OPTION=Minimal): This option uses a minimal set of device drivers and services to start Windows.
  • Safe Mode with Networking (SAFEBOOT_OPTION=Network): This option uses a minimal set of device drivers and services to start Windows together with the drivers that you must have to load networking.
  • Safe Mode with Command Prompt (SAFEBOOT_OPTION=Minimal(AlternateShell)): This option is the same as Safe mode, except that Cmd.exe starts instead of Windows Explorer.
  • Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
Please rate this a fixa
Feb 01, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
