Question about Bosch Washing Machines
My Bosch washer will not start when I press the start button the spin and end cycle lights flash rapidly. It was working fine an hour ago . what can I do?
Model # WAS20160UC/28 It is a front loading model.
  • Bosch Master
  • 5,323 Answers
Https://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
Washing Machine Repair Help WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is free cuz God is good!
All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced
Lastly CONTROL BOARD
If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures.
https://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
http://www.partselect.com/Repair/Washer/Will-Not-Start/
Posted on Jan 14, 2017
WFL 2260 Fills hot, fills cold, no wash action, move control to drain, empties, move control to spin, no spin but goes thro. cycle ends program door unlatches, any suggestions?
Motor brushes, worse case scenario motor complete. Run the following motor test.
1. Put main dial to off
2. Press and hold start button whilst turning dial one click to left (easycare 30).
3. When display show 8.88 or two of the progress light come on, release the start button
4. Turn dial anticlockwise to 60 cotton (take the long way, NOT thru OFF or you'll have to start over)
5. Press start
6. Motor should rotate in both directions, pump runs, motor kicks up to full spin.
7. No motor action and two lights flashing on progress lights (separated by a light that's not on) indicates a motor fault.
As suggested brushes or complete motor.
Hope this helps
Mar 27, 2013 | Bosch WFL 2063 Front Load Washer
Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
Jan 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
My Bosch front end washing machine will not start a cycle. Door is closed tightly and when I push start/pause red light comes on & immediately goes off-this happens every time I push the start/pause...
My Bosch washer turns "on" and water runs but it does not spin or complete wash. I hear the machine "clicking" as if it is attempting to to function but no spin or full wash cycle.
Oct 17, 2010 | Bosch Axxis WFL 2060 Front Load Washer
How do i deactivate the child lock on the bosch axxis washer
Hi
To unlock the washer press and hold 'dry' & 'spin' button. It should unlock now. If this doesn't work then press and hold "end of cycle" button for 5-10 seconds. However, if it is still locked then unplug the washer for 5 minutes and then plug it back. After plugging it back press and hold Start button for 10 seconds to unlock it. Hope this helps...
Daniel
Aug 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Flashing time lights...pressed cxl button...not working
Flashed f ...time light flash...pump starts to work...doesn't spin...doesn't cycle...
Oct 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Axxis problem
Thought these additional details might help as we are having a similar problem.
When the washer is turned on we get a blank screen, then after a bit we see the display flash. After sometime flashing then we see it go to normal and we can run it. It is as almost as if it need to warm up...
We can get the display to show faster, by playing with the knob. However, the machine still needs time before we can use it.
Any ideas?
Thanks in advance.
May 04, 2008 | Bosch Axxis WFL 2060 Front Load Washer
DRUM NOT SPINNING
Disconnect your washer's plug for 5 minutes or more from the wall socket. Plug in. Press "end of cycle" button for over 5 seconds, the child lock comes off.
Press it again and the child lock comes on................ If this does not work, try the pre-wash button likewise.
Nov 22, 2007 | Bosch Exxcel WFO 2264 Front Load Washer
Washing Machines Logo
155 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
