How to change a rth7600 honeywell thermostat from Celsius to faireight
  • 4 Answers
SOURCE: Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
Posted on May 05, 2009
SOURCE: switching thermostat from farenheit to celsius
My thermostat was set on celsius and couldn't get it to change back to fahrenheit. My son suggested pressing both up and down arrow buttons at the same time and it worked. It changed back to fahrenheit.
Posted on Jul 27, 2009
  • 89 Answers
SOURCE: i want to change my TH6110D1013 honeywell
You need to go into the setup mode to change it. Push and hold the i button along with the increase and decrease buttons. All the segments on the display will appear for about three seconds, then setup number will appear to the left and factory setting to the right. Change the setup number by pressing the (i) button until you get to 14. This is the degree temp. display, factory setting is 00. Use the arrow up key to change to 01 (celsius).To exit setup, push and hold the(i) key until the display returns to normal.
Posted on Oct 09, 2009
  • 252 Answers
SOURCE: how do I change my DIY honeywell RTH2310
go to
http://www51.honeywell.com/honeywell/
and enter your model number on the right side near the top.
Posted on Oct 17, 2009
heatman101
  • 43501 Answers
SOURCE: How do I switch the
Hi, The procedure is fairly simple.... the easiest way is for you to look up the manual and have the proper steps right in front of you...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Posted on Nov 07, 2010
Testimonial: "thanx"
Need to change thermostat from Celsius to Fahrenheit
The first link is operators manual.
The second is installation and contains the procedure to set many functions including the display temperature.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2577ES.pdf
See page 15 function set 14. This sets F or C temperature
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2578ES.pdf
hope this helps?
Jun 23, 2017 | Honeywell Heating & Cooling
Heat pump works but not ac with honeywell rth7600
Was there an Rc and and Rh terminal on the thermostat sub-base??? If so, there must be jumper across the two for the cooling portion of the circuit to be energized.
Mar 19, 2015 | Honeywell RTH7600D 7-Day Programmable...
Hooking up a new thermostat honeywell rth7600 from a honeywell t8411r. we hooked up the wires as shown in the installation manual- we have fan but no cold air blowing out or it feels like the heat is...
apparently who ever did the wiring installation did not use the Proper color coding when they did the install. Now you must trace the wiring to the appliance and wire accordingly.
Oct 10, 2013 | Honeywell Programmable Thermostat Heater
How do i change the honeywell rth7600 thermostat from fahrenheit to celsius
http://www.homedepot.com/catalog/pdfimages/85/855cb54b-bbb7-45e8-b7a4-4c868f05e142.pdf
See 12a.
1. Press System/Fan
2. Hold down Fan for about 5 seconds
3. Press the "120" on the middle
4. Press the up to 320
5. Set to 1
6. Click done
Aug 04, 2012 | Honeywell Heating & Cooling
Where do I put the wires on my honeywell thermostat RTH7600. they are black green red and white
This is the official installation guide for your thermostat. Go here:
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2206EF.pdf
Jul 06, 2012 | Honeywell Programmable Thermostat Heater
Temp dispayed in celsius.
Inside the thermostat (behind) are 3 tiny DIP switches.Switch #3 should be set to OFF or click it to the left to display *F.You can use a tiny scerwdriver
Nov 07, 2011 | Honeywell Electronic Programmable...
How do I change my Honeywell FocusPRO6000 TH6110D1005 thermostat to from Fahrenheit to Celsius?
Press and hold the up arrow and fan buttons until the display changes. Then press Next until you see 14 in the display. Change this value to 1 (with the up and down arrows) to get Celsius. (O is Fahrenheit.) Press Done to exit and save the setting.
The manual is available here: http://customer.honeywell.com/Honeywell/ProductInfo.aspx/TH6110D1005 . Scroll to the bottom and choose a manual then press Download. This particular section is in the Installer's Guide.
I hope this helps.
Jan 30, 2011 | Honeywell Programmable Thermostat Heater
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Switching thermostat from farenheit to celsius
Feb 16, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
