Question about Speed Queen Washing Machines
Speed Queen takes on water but does not start washing, can it be reset?
  • 177 Answers
SOURCE: Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Posted on Jul 29, 2008
  • 14 Answers
SOURCE: I have a speed queen washer. Last wash my
the seal in the transmission is bad
Posted on Feb 22, 2009
  • 5 Answers
SOURCE: speed queen
I'm sure you have already bought a new washer BUT......
The repair isn't as hard as you are lead to believe.
First I would check for leakage from the pump.
This is the Most common reason for water under the machine
The pump is a fairly straight forward repair that is a little different on each model of washer, but is usually easy to figure out.
If it is the seal/bearing then that is a more involved repair but not impossible for the average person who is mechanically inclined.
The front panel must come off, the the top panel, which is held by two screws in the corner. Lift the top back and disconnect the tub inlet hose. Push it out of the way. I wedge it into the top groove.
Pop off the water level switch hose on the back of the tub.
The tub module needs to come out. It is held upright by several springs. The number varies with the year.
A ready made spring hook can be found by removing and using one of the front springs. I use the one in the front to the left. It's the easiest. It's easier to catch the springs if you hold your hook facing up.
Disconnect the motor harness, leaving the capacitor attached to the harness. Pull it through the frame and out of the way.
Dis-connect the drain hose. there will be water in it so be prepared with towels. Place an old towel on the floor. Now lift the tub module up and out, setting it on the towel. This will keep grease. etc off the floor.
The tub top clips on. Gently pull the tabs out and lift two at a time, just until you break the seal, no more, till you have all of them loose.Remove and put aside. Take out the 4 tub bolts. Don't worry if you break them, the new kit comes with new bolts. The tub is usually stuck to the hub. Put a foot inside the tub and stomp down on one side. It will pop loose. Put tub aside after cleaning old gasket from bottom.
SPECIAL TOOL; you with need a 1 1/2" socket of shrt handled wrench to remove the large nut.
Once it is off there is a nylon lock unit in the grooves with the threads that looks like a crown, cut a slice in it and pull it off. There is a new one supplied.
Remove the hub. Sometimes a puller is needed, don't damage the shaft or threads.
Turn module over.
Remove the 6 bolts around the outside of the tub, the motor bolts on some models and the two holding the counter-balance to the tub.
Lift off the transmission assembly as a unit.
The seal kit has the instructions for your particular model.
If the bearing is a separate 3-bolt unit, replace it as well.
Never leave a bearing that has gotten wet from a leaking seal, or you WILL end up doing the job again in a few months because of a $15 bearing that should have been replaced the first time.
Re-assemble the washer in reverse order.
Spray WD-40, or other lube, on the cork gasket between the tub and hub before installing tub.
Don't forget the nylon lock unit.
If the pump looks like it has been leaking At All, Replace it Now.
When installing the springs, do the back ones first. Hold the hook facing down this time. Install the one you used for a tool last and in the front left side.
Let the washer set for an hour before use, or as directed in the seal instructions. The first cycle should be hot water, without a load .
Posted on Apr 27, 2009
  • 142 Answers
SOURCE: SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
Posted on Sep 14, 2009
  • 84 Answers
SOURCE: My speed queen top loader is leaking water during
It is probably the pump. Run the washer with the front off of it. The pump is on the bottom of the motor.
Easy repair.
Posted on Jan 12, 2010
Why do a Speed queen washing machine take in to much water when switched to large bundel?
I'm afraid the old up right machines always take in to much water. You have to get a front loader to save on water and it does pay for itself in the long run.
May 12, 2017 | Speed Queen Washing Machines
I have a speed queen top loader washing machine it start with the washing sickle and the timer stop when it must start to spin or rinse and i replace the timer with a new one
There is sometimes a pause between wash and spin. This allows a little time to pump the water out before starting to spin. Do you hear the pump running between wash and spin?
Feb 01, 2017 | Speed Queen Washing Machines
The water flowing into my speed queen is vert slow
The to ensure that the water valves at the inlets are fully open. If they are, then shut them off and remove the hoses from the supply to the washer. There is usually a small metal screen-type filter in the connection at the back of the washer for each hose. These may be clogging up. They can be carefully removed, cleaned, and reinstalled.
Sep 08, 2016 | Speed Queen AWS52NW Top Load Washer
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
I have a Speed Queen top loader(older model). It let's water in but does not wash or let water out. I have checked the control pannel and motor. All seems to be ok. The reset used to work but now it does...
Make sure that the lid switch is working as it can make the program from advancing forward. So check the continuity of the switch that goes to trigger the main board.
If Ok then the program controller is not functioning, if you can try to change manually then the control board is faulty.
Jan 13, 2011 | Speed Queen AWS17NW Top Load Washer
Will not start washing process
Is the belt broke?
If not, will it spin it you put it in spin mode?
If it spins, but not agitates, the transmission is locked up in agitation and needs replaced. This is a major undertaking.
Dec 12, 2009 | Speed Queen AWS51NW Top Load Washer
Kelvinator or (Speed Queen Top Load washing machine)
You probably have the wrong belt, and its to small? Go to repairclinic.com or google Kelvinator parts. Order the correct belt.
Apr 15, 2008 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
