Question about HP Office Equipment & Supplies
Hp1005 printer continue initialization - HP Office Equipment & Supplies
In my hp1005 printer language showing in chinies how can i change the language in english
first learn chinies then you can read the instructions .or google language conversion Google
Oct 11, 2017 | The Office Equipment & Supplies
My hp1005 printer is not coming in hardware detection list of my pc. What may be the prob
Hi friend,
You need to install hp1005 printer drives in your system for install hp printer.....
can go on the HP website, find the driver and start downloading it but at one point is says : "unzip file", so I click on it to unzip it, then it says that it unzipped successfully and closes the window ! So then what should I do ??? Because the download is apparently stopped..
Click on link download hp printer divers.....http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=214539&lang=en&cc=us&prodTypeId=18972&prodSeriesId=240170&taskId=135
With regards Avnish Kumar
Feb 14, 2011 | HP Office Equipment & Supplies
My hp1005 printer give the blank page
kindly replace the toner.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Jan 21, 2011 | HP LaserJet 1005w Printer
HP1005 says out of paper but there is plenty of papers
your printer needs to be opened so better take to service station
Aug 04, 2010 | HP LaserJet 1005w Printer
Need a driver for a HP laserjet HP1005 printer that works with MAC computers
Actually you three types drivers available for hp 1500 printers.
Basic drivers, full features Drivers, network Drivers. So the fluu feature software is comes with total features. You can download those drivers from below link:
HP LaserJet 1005 Printer Drivers
Nov 18, 2009 | HP LaserJet 1005w Printer
HP1005 says out of paper but there is plenty. One
In run window type services.msc and the go to print spooler option just stop and restart the service.and switch off and switch on the printer it will clear the queue.
Oct 21, 2009 | HP LaserJet 1005w Printer
Hp1005
Why HP company is so stupid?
Why can you not let the customer easily to download the driver? Why?
Nov 14, 2008 | HP LaserJet 1005w Printer
Printer takes ages to process
NV RAM and HD
To initialize NVRAM
1. Remove any installed accessories (for example, a stapler/stacker).
2. Turn the printer off.
3. Hold down the DOWN ARROW ( ) button, and then turn the printer on. Continue holding
down the DOWN ARROW ( ) button until all three printer control-panel lights flash once and
then remain on. This might take up to 10 seconds.
4. Press the UP ARROW ( ) button.
5. Press the PAUSE/RESUME button. The display should show SKIP DISK LOAD.
6. Press the UP ARROW ( ) button until NVRAM INIT is highlighted.
7. Press the SELECT ( ) button. The printer initializes NVRAM and then continues its poweron
sequence.
Hard-disk initialization
CAUTION A hard-disk initialization erases and reformats the printer hard disk. Perform a hard-disk
initialization only if an error code on the control panel indicates an EIO disk error. Always try
initializing the hard disk before replacing it.
NOTE Before performing a hard-disk initialization, print a menu map and a configuration page (see
Menu map and Configuration page). Use the information on the configuration page to reset
any customer-set printer configuration values that the hard-disk initialization procedure
changes.
To initialize the hard disk
1. Turn the printer off.
2. Hold down the PAUSE/RESUME button, and then turn the printer on. Continue holding down
the PAUSE/RESUME button until all three printer control-panel lights flash once and then
3. Press the BACK ARROW ( ) button. The display should show INITIALIZE DISK.
4. Press the SELECT ( ) button. The printer initializes the hard disk and continues its power
Mar 12, 2008 | HP LaserJet 2420 Printer
26 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
