My aircon is making a noise, sounds like the fan, it is a kelvinator wall unit but is on a table not on wall it is a 62 model
hotuna
  • 288 Answers
SOURCE: loud whistle noise kelvinator split KSR25F-01
It may be the small vent fan motor on the inside if the control panel. When the noise begins remove the panel and you may be able to catch it in the act.
Posted on Dec 28, 2007
  • 244 Answers
SOURCE: opener only makes clicking sound when activated by remote or wall
where is door trolley, up or down. did it go up too far and wedge against bolt in track. take out bolt to release and try. put bolt back in. did you overheat motor. wait 15 minutes. give more info. (Does light bulb blink 10 times, then safety beam problem affecting door going down).
Posted on Jan 15, 2009
SOURCE: Fan making noise in AC
pls try to lubricate it if it got oiling port as soon as possible. if no port you may change bearing before the damaging motor . also if this type of motor does not have bearings better to change it
Posted on May 01, 2009
james3751
  • 614 Answers
SOURCE: outdoor unit fan making noise when running sounds
Bearing in fan going out. Let it run till it quits or call service tech to change motor. Fix cost about 250 to 300 dollars. russ
Posted on Jul 22, 2009
  • 21 Answers
SOURCE: kelvinator aircon is dripping water from air vent in house
Sounds as if unit is freezing over----typically a response to lack of proper ventilation-----check all filters and access panels to unit and clear or clean as needed-----if unit has a drip pan make sure unit has been positioned properly so as to catch excess......properly ventilating unit should resolve issue though
Posted on Jan 15, 2010
Testimonial: "cheers mate problem solved thanks for your expert advice "
What could be causing loud grinding noise when i switch on aircon? Aircon now not working but only makes loud sound.
Sounds like the bearing or part of the clutch in the A/C compressor has failed, or possibly component on a/c fouling on something due to recent repairs however would be unlikely and probably just a coincidence..
Check A/C compressor turns by hand, should be firm but not make any noises.
Check for fouling components related to a/c compressor clutch.
Feb 12, 2016 | Cars & Trucks
I have a shenbao mennelium aircon its gets cool after i turn the unit on but after 10-15 min it stops blowing cold air i have to shut the unit off and then back on to get cold air and also the compressor...
Check the fan,to make sure it is really turning fast on the high mode with ac on,not just fan.It sounds like the fan is slowing down,and not cooling the condenser,therefore cause the head pressure to rise,and producing warm air.The fan motor would have to be replaced to fix the problem if this is the case.
Apr 16, 2012 | Heating & Cooling
Hi we have an old Kelvinator Aircon/Heat model no RF5ooG its fan stopped working, how can I fix this problem? It was working fine then wasn't used for a number of months and now it won't work. It sounds...
All users must know. There will be too dusty when unit is not used for several months rather being used.
Please do complete service and then try.
Dec 11, 2010 | Heating & Cooling
Kelvinator aircon is dripping water from air vent in house
Jan 15, 2010 | Heating & Cooling
My air conditioner is making a tinny sound when it runs--both when I run the fan only and the AC.
Many noises on aircons come from a resonant frequency and can be sorted by slight re-alignment of the unit. Sometimes pushing in a paper spacer can help. You should look inside and behind the louvre at the drum fan. There may be a build up of dirt causing it to be unbalanced and also making more noise.
Nov 13, 2009 | Heating & Cooling
MY AIRCON IS BUILDING UP SOME ICE
Sounds like it's low on charge, dirty coil. Is this a ductless unit or window?
Jul 26, 2009 | LG Heating & Cooling
Aircon compressor makes noise
Is this noise definately from the compressor? have you looked round the system for a loose componant like the fan? is this system a heat pump sorry I have not checked online but if it is what is the sound like in heat mode, if just coling unit please ignor last.
Jun 08, 2009 | Sanyo CM3172 Air Conditioner
Loud whistle noise kelvinator split KSR25F-01
Dec 27, 2007 | Carrier 36KCARMS Air Conditioner
Loud Popping Sounds
If this is a heat pump system it is possible that your fan blade is hitting ice on your condenser coil.
Nov 17, 2007 | GE Zoneline AZ55H07D Air Conditioner
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
