Sharp5 cd disc player XLDK225 shows er-1 drawer does open and close but disc will not play
  • 1153 Answers
SOURCE: Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Posted on Oct 08, 2007
SOURCE: CD drawer will not open or close
Had The Same With Mine. Its was the belt Inside that joins Motor To Cd Tray. Its Black and directly under the cd tray at the front. Its probably either loose like mine of maybe broken. I replaced mine with an elastic band and its been fine since.
Posted on Oct 29, 2007
SOURCE: onkyo c707chx...
This is an easy fix if you are somewhat handy.... The belt for the door/tray is slipping. If you remove the enclosure and face plate, you will see two motors below the disc drive. Press eject while observing the pulley to the left. You should see the problem with the motor shaft spinning and the belt slipping. Replacing the belt is possible without any further dissassembly. Simply bend some light wire into an L shape and you should be able to hook both pulleys and lace the new belt on. As far as obtaining a new belt I decided to do the simple thing and use a slightly smaller rubber band. The repair has held now for almost three months and the player is used everyday. Good luck.
Posted on Dec 20, 2008
kbdesign
  • 370 Answers
SOURCE: cannot open cd drawer
If it will not open by itself, open up a small paperclip and push it into the little hole on the front of the cd rom. This will release the latch, and allow the drawer to open
Posted on Mar 16, 2009
SOURCE: NAD C521 CD Player
The tray belt raises the laser to proper focal length at the end of closing the drawer. This demands more grip from the belt. If the belt is sloppy, it will slip at this point, even though the drawer is shut. Took two years of repeatedly cleaning lasers to notice this.
Posted on Nov 08, 2009
How do I fix my Sony cd player with 5 disc carousel changer in which the door keeps opening up? When I close the door the carousel moves around a bit but then the door opens up again.
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
I have a Sony mini hifi stereo(pixy) and when ever I close the tray it continues to ... my cd player drawer opens ...
ToddFun.com: Repairing a 5 disk CD player - YouTube
? 10:09
https://www.youtube.com/watch?v=aKE1CbHOBVo
Nov 23, 2011 - Uploaded by Todd Harrison
ToddFun.com: Repairing a 5 disk CD player ... Sony CDP-CX300 300 Disc Changer Belt Repair and ...
Jan 01, 2016 | Sony Audio Players & Recorders
CD function in 5 disc stereo constantly flashing "CHANGE"
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Nov 17, 2012 | Audio Players & Recorders
Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
Thanks for understanding. Please let me know if you require any clarifications.
Jul 09, 2011 | Toshiba SDP93S Portable DVD Player
Cd disc player will not play
Reset the drawer timing. The door switch is not working properly.
Dec 16, 2017 | Audio Players & Recorders
CD player will not play
dirty lens , focus problem , laser failure , mechanical difficulty
Dec 01, 2008 | Audio Players & Recorders
Rotel cd player Rotel 1070 cd player
Well I fixed the problem myself by taking yhe cover off and cleaning the laser with a cue tip and alchohol very gently of course. I guess it was not reading the disc the first time it closed because some foreign object , works fine now
Mar 03, 2008 | Audio Players & Recorders
Error message
I had this happen to me as ell. you've probably got a cd stuck under the revolving tray. I took the top cover off and then opened the drawer and removed the offending disk. If you're not technically minded it's probably better to take it in to a repair shop. Mike
Dec 24, 2007 | Marantz CC-4300 5-Disc CD Changer
Electronic repair
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
Error nd after entering cd and pressing play
Have you tried cleaning the Lens? nd means No Disc, indicating that the Lens is not picking up the signal, and so is indicating a 'No Disc'
Oct 22, 2006 | GE Slim Spacemaker 7-5295 CD Shelf System
29 people viewed this question
 Grubhead
Grubhead
