Question about Xerox Office Equipment & Supplies
Sir, i have a xerox machine GP215 AND PROBLEM IS SWITH MAIN POWER OFF & ON ... ERROR 002 IN MY SCREEN. PL HELP ME.. THANKS..
  • 277 Answers
SOURCE: TOSHIBA WASHING MACHINE AW46S1E
hi this will help you http://www.repairclinic.com/0047_11.asp http://www.applianceaid.com/direct.html#agitating there are links to new parts there if you torn somthing in there good luck
Posted on Apr 20, 2006
  • 2072 Answers
SOURCE: xerox error code u1-1 main motor fault
You will need to replace the main drive motor assembly.
That stepper motor is a common fail item.
You have to remove the rear cover, the MFSYS and MCU board assembly to access that motor.
Posted on Jul 09, 2008
  • 2072 Answers
SOURCE: my xerox workcentre pe 220 machine have an error message on "low heat error"
You will have to replace the fuser.
Posted on Apr 19, 2009
  • 2340 Answers
SOURCE: Sir, Pl. help me- I have installed "Nero Burnlite
Does your XP requirements satisfy the requirements at the link page?
System requirements for XP installing Nero 10. -> LINK.
If it does not then you have to update your XP windows system first before installing Nero 10.
Hope it helps.
Posted on Nov 25, 2010
  • 122 Answers
SOURCE: i have problem with canon
open the right door, spray wd40 or zorrik under inside upper black roller(u've to use torch to see the white strip inside there).if problem is still there, check the horizontal motor.
Posted on Jan 05, 2011
Sln for Xerox wc 5330 error code 092-315
092-315 ATC Fail RAP
BSD-ON: BSD 9.3 - Development and Toner Dispense Control
The frequency at which the ATC Average Fail or the ATC Amplitude Fail has been occurring
has exceeded the threshold value.
NOTE: •
Although this Fault can be cleared by turning the power OFF and ON and it will be possible to output a few sheets of printouts, when this Fault has occurred a certain number of
times, it will no longer be clearable by turning the power OFF and ON. To clear it, clear the
value of NVM location [752-022] (ATC Average Fail) or NVM location [752-023] (ATC
Amplitude Fail) to "0" (
NVM Read/Write). If the machine is not repaired back to normal
status, this Fault will occur again during the operation.
• When turning the power OFF, turn OFF the power switch first and then the main power
switch.
Procedure
Check the following:
• The connection between the MCU PWB
P/J413 and the Xero/Developer Cartridge P/
J615
for open circuit, short circuit, and poor contact
• The Toner Dispense Motor for revolution failure:
Component Control [093-002] (PL 8.2)
• The Toner Cartridge for internal toner blockage
If no problems are found, replace the following parts in sequence:
• Drum Cartridge (
PL 8.1)
• MCU PWB (
PL 18.2)
See Service Manual page 827 (2-831):
https://docviewer.yandex.ru/?url=ya-disk-public%3A%2F%2FEXv3f5bJ9f7WprcvyqxuiVsXMlmyrp4nx2LzJa50u6s%3D&name=Xerox_WC_5335F_SD.pdf&page=827&c=55716712dd0d
Xerox WorkCentre 5335 Family 5325 5330 5335 Service Manual
Jun 05, 2015 | Xerox WorkCentre 5325 5330 5335 Black...
Xerox 4150 workcenter says fuser module needs to warm up. This appears usually first thing in morning. I have to power off then on to stop this from showing on the screen. also, it wont print until after I...
1. Switch off the machine, then switch on the machine.
2. Enter dC330 code 10-100 to heat the fuser to 180 degrees. Enter codes 10-200 (centre
thermistor) and 10-210 (front thermistor) to verify the condition of the thermistors.
3. Enter code 10-300 to check power supply unit 2. If necessary, install a new power supply
unit 2, PL 1.10 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.25
Item 9 are clean and in good contact with the fuser heat roller. Check the wiring to the
thermistors. Install new components as necessary, PL 10.25.
5. Check for continuity between the two pins on the fuser assembly connector, PL 10.25
Item 8.
NOTE: A cold fuser has a resistance of approximately 11.5 ohms (220V/240V) or 2 ohms
(110V).
6. Check that there is continuity through the fuser heater and across the over temperature
cut-out.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CON3, CON8 and
CON9 on Power Supply Unit 2. If necessary, install a new fuser connector, PL 4.15 Item
20.
8. Check the wiring between CON4 on Power Supply Unit 2 and CN7 on the Main PWB.
9. Install new components as necessary:
• Fuser assembly, PL 10.25 Item 1.
• HVPS, PL 1.10 Item 2.
10. Perform the OF5 Main PWB Check RAP.
4250/4260 Checkout
NOTE: The main PWB has test points. The location of the test points is shown on the Main
PWB PJ location illustration.
Refer to Wiring Diagram 17, Wiring Diagram 18 and Wiring Diagram 21. Perform the following:
unit 2, PL 1.15 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.28
thermistor assembly. Check the wiring to the NC thermistor, PL 10.28 Item 19. Install new
components as necessary, PL 10.28.
5. Check for continuity between the three pins on the fuser assembly connector, PL 10.28
Item 8.
(110V).
6. Check that there is continuity through the fuser heat lamps and across the over temperature
cut-out. Install new components as necessary, PL 10.28.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CN5 on the Main
PWB. If necessary, install a new fuser connector, PL 4.15 Item 20.
8. Check the wiring between CON1 on Power Supply Unit 2 and CN7 on the Main PWB.
• Fuser assembly, PL 10.28 Item 1.
• Power supply unit 2, PL 1.15 Item 4.
May 10, 2012 | Xerox WorkCenter 4150 Black and White...
LSU error in XEROX workcentre pe220. What is the
R/sir,
I have a Fax machine of Xerox make model PE220.From BSNL line connectivity is allways out of order.I want to connect FIXED CELLUR TERMINAL (FCT).After conecting machine give dial tone for outgoing calls.and other end caller received a fax tone on their machine when they want to make a call on my machine.But printer is not printing after some LCD diplayed a massage communication error.Kindly GUIDE me for change in settings.
Thanks and regards
PK Jain
(Pennywise)
Dec 15, 2010 | Xerox WorkCentre PE220 Series
Canon gp215 error E064
Hi, Well this error code means there is some problem in Main Power supply or Main PCB.Check it to fix this problem!
Thanks! mannu_rakesh
Aug 26, 2009 | Office Equipment & Supplies
Xerox 5855C Copier
it need to replace the connector in the toner cartridge
Dec 11, 2008 | Xerox 5855C Copier
Help with Xerox DC 440ST Machine
This problem can only be cured by a Xerox engineer or by someone who has access to a Xerox laptop. You have to have a special program called AltBoot to be able to reload the software.
The only other way is to replace the SCSI hard drive in the ESS (network controller unit) with one that has been pre-programmed.
Sep 10, 2008 | Office Equipment & Supplies
LSU ERROR DISPLAYED FOR XEROX WORKCENTRE PE220
Hi Dear
I am facing LSU Error on my Xerox workstation PE 220
I am not able to do anything, please let me wat to do
i have lot of work penindg
urs
mujahid
May 25, 2008 | Xerox Phaser 8500/DN Printer
Error 3-397 Xerox DC 12
Hello, I have a Xerox DC 12 and i receive the error 3-308
Someone can you help me or information about me ???
Thank you.
Feb 22, 2008 | Xerox DocuColor 12 Printer
26 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
