Question about Sharp Televison & Video
My Sharp LE820 Aquos has for the past month been taking some time to turn off and it flickers as it powers down. There also seems to be some lag in using the remote. Help.
    Master:
  • 469 Answers
Mouse pad is necessity for optical mice, simply because this type of mouse utilizes image sensors to detect movement. Although some customers use paper or other surfaces rather of mouse pad, most customers perfer a mouse pad for comfort, pace and accuracy. Steelseries Sx Professional Gaming Mouse Pad AmanStino
Posted on Dec 31, 2016
My Sharp LE820 Aquos LED TV will automatically turn itself off after some time, but it will automatically turn itself back on after about 15 minutes without me switching it back on. why is that?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 15, 2015 | Sharp AQUOS 52in. LE820 LED LCD HDTV
My Sharp LE820 Aquos LED TV recently auto turn itself off, when I turn it back on, a few good 10 minutes or so later it automatic turn itself off again.
Please check that the sleep timer did not somehow get set. If it's not the sleep timer, check if the panel stays ON longer after it's been off for awhile to cool down. Possibly a heat problem with the power supply or main board.
Bolt size for wall mount to fit new sharp LC60SQ15U
It will be a metric bolt. They very from model # to model #. Don't get them too long as they could go past the insert and into a PC board!
If you were too Google your model # you may just fine what Metric bolt it would take to mount it. Any good hardware store would have the correct metric bolt or screw for you.
Dec 07, 2014 | Sharp AQUOS 52in. LE820 LED LCD HDTV
TV will not trun on
Not enough information
Does the power LED flash ?
Are you plugged into a surge protector ?
How old is the unit ?
Have you inspected the power supply.?
Feb 01, 2014 | Sharp 60in Le820 Series Aquos Lcd Hdtv...
Is changeing the main board changing from ntsc to pal?
No. You'll need to replace the power supply board too.
Jun 20, 2012 | Sharp AQUOS 52in. LE820 LED LCD HDTV
How to adjust for best picture a Sharp Aquos Quattron 3D LED LCD 52 inch tv. I'm having problem maintaining perferred brightness. Also when initial turn on the screen goes to channel then shuts down and...
This sounds like a setting that can be adjusted. What I like about some of the Sharp televisions is the av mode setting (preset brightness/contrast adjustments). I am not looking at the manual for this model so I'm not sure if this is an option on this television. However with this being a high end aquos model there is free assistance available to you. You can register your television at aquos advantage and chat live with an aquos advisor at Sharp's Midwest Corporate Headquarters. The agent may advise you to call in if your television need and Industry Initialization because you have to be talked through it. I advise the chat reps initially because when you call you aren't able to speak with the Midwest Corporate Sharp reps unless your call is being escalated.
http://www.aquosadvantage.com
Apr 22, 2011 | Sharp AQUOS 52in. LE820 LED LCD HDTV
We've just purchased the Aquos LE820 and set up foxtel IQ box using red/yellow/white cable. We can see the channels but the image in is black and white and fuzzy, like not in tune. Did we do something...
Hi, try setting the FORMAT to NTSC, or AUTO, in settings this is what happens when the wrong one is chosen, if you have it wired up correctly also you must choose COMPOSITE Video INPUT, this is the Yellow wire, this goes color to color in the jacks, same with the other two, the other two, the Red & White are the Audio stereo left & right.
http://www.scribd.com/doc/19365521/Sharp-AQUOS-LC404652LE700UN-Operation-Manual
above is an operations manual so you can check exactly how to do this.
Apr 16, 2011 | Sharp AQUOS 52in. LE820 LED LCD HDTV
I need a owners manual for the AQUOS LED LCD 60 in..
Download manual here:
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Enter product model then search. Click on result manual to download in PDF format.
I have a copy of the manual if you have specific questions.
Mar 27, 2011 | Sharp AQUOS 52in. LE820 LED LCD HDTV
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
