HOW DO I MAKE dEGREE SIGN ON WINDOWS & WORD PROGRAM
    Top Expert:
  • Computers & ... Master
  • 26,713 Answers
In word press and hold the Alt key and type 0176 then release. Alt 0176
Posted on Dec 31, 2016
Which mark is the five degree mark for the ignition timing
. I was reading on the net( stop-the-star- program.3084.x6.nabble.com that the initial program is for 5 degrees advanced but all shops state that the reading from the plug lead is 10 degrees -even new vehilces and it is set by the ECM program
this site is a forum for this discussion
Jan 08, 2014 | 1995 Mitsubishi Mirage
Sideway screen INSPIRON mini how do I fix it
Changing the screen orientation of your Windows display can make your screen rotate at a 90-degree, 180-degree and 270-degree angle. By default, Windows operating systems do not come with a built-in mechanism to change the screen's orientation. Certain graphics boards, such as Intel, utilize hot keys to change the screen orientation. If the hot keys do not work on your computer, a program can be installed to create shortcuts that change the screen's orientation. One such program that is Windows compatible is called "iRotate," which is available to download for free.
Turn your computer on and wait for it to load. Once your computer finishes loading, make sure any open programs are minimized or closed. Press and hold the "Ctrl" and "Alt" keys on your keyboard. Press the corresponding arrow key on your keyboard for the direction to which you want to orient your screen. Press and hold the "Ctrl," "Alt" and up directional arrow key to return the screen to its regular orientation. iRotate Application Open the iRotate download site (see Bottom of page.) in your web browser. Click on the blue download link on the left-hand side of the page. The download link contains the text "iRotate" and has an icon of a floppy disc. Save the file to your computer. Open the iRotate file and follow the on-screen prompts to install the program to your computer. You can choose whether or not to put a shortcut on your desktop, place a folder for the program in your "Start" menu or automatically run the program after it finishes installing itself. Right-click on the iRotate icon in your taskbar. The iRotate icon is a blue rectangle that will display information about your graphic properties when you hover your mouse over the icon. Select a screen orientation from the drop-down menu. You can choose a 90-degree, 180-degree or 270-degree rotation. The "Normal Landscape" option returns your screen to its default orientation. iRotate
http://www.entechtaiwan.com/util/irotate.shtm
Mar 01, 2013 | Dell Inspiron Mini 10 Notebook
Acer z5610 suddenly turns OFF Temperature is normal, no overheat, new thermal grease System scanned for errors, viruses - nothing WHAT DOES IT MEAN?
Are you sure the temperatures are ok? When I run DIVX Plus Converter on the Z5610 the CPU (intel Q8200) is running (naturally) at a high load. Speed Fan 4.42 shows rising temperatures going north of 90 degrees C. If only DIVX Converter runs the temperatures of the CPU cores is around 92 to 94 degrees C. But if I start browsing the internet the temperatures go close to 100 degrees C. When one of the cores reaches 100 degrees C Speed Fan shows MINUS temperatures on the cores (-10 to - 20 deg C). Speed Fan is just monitoring as it can not even detect the Fan.
When that happens the Fan stops completely!! And short after that the computer switches of (same as if you would pull the plug).
Obviously there is a bug in the BIOS or the Motherboard which leads to interpretion of temperatures above 100 degrees C as MINUS temperatures which leads to the stop of the fan.
I am sure that also happens whenever you use a CPU intensive program (like a game or any other video converter/rendering program). You might download a temerature monitoring program (i.e. Speed Fan - its free) and see for yourself. Also listen whether the fan stops working compltely (goes completely silent) when the PC overheats and short before it switches off. Let's see what ACER says to that.
I used to like ACER. But first Aspire 4310 tripping frequently because the VGA chip overheats and now that stupid fault ==> never ever ACER again. I will use the Z5610 for internet surfing and get a real all-in-one which you can use. That is a clear sign for me that ACER does not test their machines at all under full load - or knowingly sells faulty machines.
Dec 16, 2010 | Computers & Internet
Windows Live Sign-in Assistant is not working. When I click on it, I get a message prompt that windows live messenger stopped working and I get this following after.. .....C:\Program Files\Windows...
Try installing the program again using the original installation media or contact your system administrator or software vendor for support.
Jul 09, 2017 | Computers & Internet
A Sign appear every 3 minuts from Security Center Alert. Windows Firewall has blocked some features of the program. HELP.
I am convinced that you have a virus called "FAKE ALERT". Download and install "Malwarebytes" run the program and it should take care of the virus. After that, run Disk Check Scan from windows to repair the windows damages and correct filing system errors. GOOD LUCK!! Lucky4lynn2
Feb 28, 2010 | Dell Inspiron 1525 Notebook
Find cos 32° 45'
Look at the column of keys under the ALPHA key. You have the integral, the square root, and then the key that has a degree sign, an apostrophe and a double closing quotation mark. That is the one you use to enter the angle in sexagesimal notation. To simplify my task I will symbolize the key with [DMS], degree, minute , second.
To calculate cos (32° 45')
you press
[COS] 32[DMS]45 [DMS] ) and press [=] The result si 0.841039013
Hope it helps.
Nov 08, 2009 | Casio FX-115ES Scientific Calculator
How do i make the weather degree sign ? ? ?
In windows, click Start>Programmes>Accessories>System Tools>Character Map. Here you will find every symbol and you can copy this to the clipboard for pasting into any application you require.
Regards
Chris
Nov 06, 2009 | Gateway 2520915 Keyboard
Error code in windows live messenger 14.0
Try to clear the cache
C:/users/%USERNAME%/contacts/%YOUREMAIL%
C:/users/%USERNAME%/appdata/local/Microsoft/Messenger/%YOUREMAIL%
Delete these two folders and then restart Windows Live Messenger.
May 06, 2009 | Microsoft Windows Live Messanger
Norton 360 keeps disconnecting MSN
I uninstalled the Norton 360 program. Windows Live Messenger seems to be able to stay online now.
Apr 02, 2009 | Microsoft Windows Live Messanger
M3plugin.dll
Error loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.
pentium iii windows XP
the specified module could not be found m3plugin.dll it appears on startup on windows xp and i want to fix it
Jul 28, 2008 | Intel Motherboard
Computers & Internet Logo
David Payne
David Payne
