The keyboard doesn work.onthemains but does on batterys
Computer doesn't recognize ez eyes keyboard
unplug the keyboard, go to the manufacturers website and download and install the drivers, plug the keyboard back in.
If that doesn't work
check your device manager and see what keyboards are in the keyboard section. delete anything but the hid keyboard device and the standard ps2/2 keyboard from the keyboard section. repeat the first set of instructions
if that doesn't work either
take the keyboard back it is most likely faulty
Aug 25, 2012 | Toshiba Computers & Internet
My keyboard is not working I replaced my batteries and it doesn't have a reset button and it had a connect button and pressed it but its not working
Press the connect button on the transmitter attached to the computer, then push the connect button on the keyboard.
Mar 12, 2012 | Computers & Internet
Model number 9131URF keyboard has stopped working. i have put in new batteries but no luck.
if this is a wireless keyboard then you will need to re-link the keyboard to the usb device. there might be a reset button on the bottom of the keyboard and the usb device for re-linking them together. to test if it has worked by opening notepad then type some keys. if that doesn't work then you will need to un-install and re-install the wireless usb keyboard.
Aug 24, 2011 | HP TouchSmart IQ770 PC Desktop
I cant get the keyboard the respond to the hub, the mouse works fine but not athing from the keyboard. I have even put different batteries in.
I have this problem to sometimes. Hold the keyboard connect button with the hub connect button at the same time. If this doesn't work then restart the computer. If this does not work reinstall the software.
May 08, 2011 | Office Equipment & Supplies
Stopped working.
You don't have say in details. but I'll try to solve your problem. If both are not working then detach them both and replugged again to the system. Then reboot the system. If it doesn't work then check the device manager settings and external device settings in Bios settings. If those device are wireless then check first the receiver battery and change the battery. Better if you can place another set of keyboard & mouse to the system to confirm that there don't any problem or not getting hang the system.If it doesn't solve your problem then go to the nearest service center for repair or purchase a new.
Apr 28, 2011 | Logitech Computers & Internet
Lights are on but mouse doesn,t work.Inland wireless mouse and keybord. Keyboard works great.
Check with fresh batteries.. Did you sync the mouse with transciever? Push tiny button on transceiver, (maybe hold for few seconds) light flashes quickly.. then push tiny button under the mouse, light stops flashing. Try few times, maybe otherway round. If still not work consider defective.
Dec 11, 2010 | Inland u-Touch wireless Keyboard/Optical...
Replace the battery inside the keyboard.
Make sure the wireless "receiver" is in the "line-of-sight" between the keyboard and the receiver.
Make sure that the wireless "receiver" is still connected to a USB port in your computer.
Apr 10, 2010 | Logitech Wireless Access Duo Optical...
Inspiron 5100 bios a32, keyboard
You can try reseating the keyboard connector. If that doesn’t work, the keyboard needs to be replaced. To reseat the keyboard connector, follow this link:
Be sure to remove AC power and the Battery.
Nov 01, 2008 | Dell Inspiron 5100 Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
