Does the Huawei E5186 wifi router allow Virtual Server / Port Forwarding / Dynamic DNS for security camera monitoring via DVR?
5 Suggested Answers
govinda123
  • 2263 Answers
SOURCE: Port Forwarding on NB7Plus4W router
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
For example ,
You have a Linksys wireless router and you want to open the ports for the X-box.
You have opened the set up interface of the router. You will see Application and Gaming TAB at the top.
If you click on that tab you will find different Sub tabs.
Click on Port Triggering => Here you can open the port numbers for the network.
Click On Port forwarding if you want to open the ports for a special device in the network.
Click Save settings once you open the ports on the router.
Some of the recommended port numbers for different applications :
IMAP ==> 143 SMTP : 25
HTTPS ==> 443 HTTP : 80
DNS ==> 53 FTP : 21
SNMP ==> 161 TELNET : 23
XBOX ==> 53, 80-88, 3074
PS3 ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
WII ==> 28910, 29900, 29901, 29920, 80, 443
VPN ==> 1723, 500, 443-447, 10000-20000
World of Wars ==> 3724, 6112, 6881 - 6999
Click Here for more info
Posted on Dec 06, 2009
  • 23 Answers
SOURCE: port forwarding
As i remember all port forwarding was under Virtual Server configuration. But you need to check maybe web cam is using more then 1 port. Try to play with netstat to see, to which ports Connection establishing when you are connecting to cam.
Posted on Apr 19, 2010
SOURCE: Access Geo-Vision Multi-Cam security system on internet
Same problem here. Any one know how to fix it?
Posted on Oct 26, 2010
Tom Marvolo
  • 708 Answers
SOURCE: belkin surf router F7D3302 setup for port
PORT FORWARDING
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the DVR
Step 7: Get the IP Address of the DVR
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the DVR in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Posted on Dec 12, 2010
How can i configure aip w505 for att elevate internet, in order to view my qc dvr
You need to enable the virtual server settings on the AIPW505
You also need to allocate a static address to the DVR within the range of the DHCP address range.
Virtual Server Settings - Selects between enabling or disabling port
forwarding the virtual server. (Default: Disable)
? IP Address - Specifies the IP address on the local network to allow external access.
? Port Range - Specifies the port range through which traffic is
forwarded.
? Protocol - Specifies a protocol to use for port forwarding, either TCP,UDP or TCP&UDP.
? Comment - Enter a useful comment to help identify the forwarded
port service on the network..
The manual can be obtained from here
ALFA NETWORK Inc
Oct 21, 2012 | ADVANCE Alfa AIP-W505 802.11n/b/g Wireless...
Port forwarding
Apr 19, 2010 | D-Link AirPlus DI-524 Wireless Router
For example ,
DNS ==> 53 FTP : 21
Nov 22, 2009 | NetComm NB5PLUS4W Wireless Router
Port forwarding with linksys router
If you can get online. Definitely, your DNS server is correct. Meaning that your DNS and your static IP are on the same range. Because if the DNS server is NOT within the same range of your static IP, you will never get online. Slow connection has something to do with either the router settings or your ISP.
Port forwarding is opening a specific port so that you could send/receive messages, so that you could allow other URL. Like https, FTP and other stuff.
If you're connected wirelessly to the router, you may need to check/cnage the wireless channel of the router. And if the Internet is still slow, you may need to verify it with your ISP. Maybe they are doing some settings on their end.
Have a great day!
May 29, 2009 | Linksys Wireless-G WRT54G Router
I nd to configure dynamic host for my dvr camera through router
You need to assign static IP on your dvr camera, then open the port(port forwarding) for your camera using the router's setup page.
Jan 18, 2009 | Linksys Wireless-G WRT54G Router
Can't access my DVR remotely via Video Server E
why i cant remote access my dvr in WAn but LAN is working fine?
Jan 03, 2009 | 2wire 2700HG-B Router (2700HGB)
DVR camera system help
First, check what ports the DVR system uses, in GeoVision for example is:
80, 3550, 4550, 5550, 6550
So...
You DVR must be with Manual IP
And then, open the router management page and configure NAT settings, so that when someone in the outside network "calls" you ip+port, the router knows to which machine the "call" is...
Also... use some kind of dynamic dns service like DynDns or NO-IP so that people use an regular URL and not a IP address.
Aug 16, 2008 | Computers & Internet
Port Forwarding
Instructions for DG834, DG834G, DG824M, FR114W, FM114P, FR114P, FR328S, FVL328, FVS328, FVS338, FVX538, FWAG114, FWG114P, or FVS318v3 These routers do port forwarding by assigning port numbers to a "service" associated with the application you want to run. "Rules" are set for particular services. Rules block or allow access, based on various conditions such as the time of day and the name of the service. To Create a New Inbound or Outbound Rule 1. Submit the router's address in an Internet browser. (The default is 192.168.0.1). 2. Enter the router's username and password. 3. From the main menu, click Security > Rules. 4. Click Add for inbound or outbound traffic, as appropriate to the application you are planning to run. 5. Select the Service. The services the router knows about are listed in the drop down. If the service you want is not listed, add it as described in the next section. 6. Select the Action, for example ALLOW always. 7. For Send to LAN Server, enter the IP address of the local server. Note that this is also the IP address the computers on your LAN will access. 8. For WAN User choose Any, or limit access to particular IP addresses. 9. For Log selection it is reasonable to turn logs on, especially at the beginning when you are unsure of the result of the changes you are making. Later, you may want to set logs to "Never" for performance reasons. 10. Click Apply. As noted in user manual for some models: * Consider using the Dynamic DNS feature on the Advanced menu, so that external users can find your network when the DHCP lease is renewed by your ISP. * If your own LAN server uses DHCP, and your IPs change on rebooting, consider using the Reserved IP Address feature in the LAN IP menu. To Add a Service for These Routers 1. Click Security > Services > Add Custom Service. 2. Enter any name you choose for the service. 3. Select whether the service is to use TCP or UDP. If you are unsure, select both. 4. Enter the lowest port number used by the service. 5. Enter the highest port number used. If the service uses only one port number, enter the same number. 6. Click Apply.
Feb 19, 2006 | NetGear ProSafe FVX538 Firewall
Port Forwarding
Feb 19, 2006 | NetGear ProSafe FVS338 (FVS338NA) Firewall
Port Forwarding
Feb 19, 2006 | NetGear ProSafe FVS328 Firewall
Computers & Internet Logo
163 people viewed this question
David Payne
David Payne
