Question about Samsung Heating & Cooling
Samsung smart inverter air cond model AQV24UWBN GREEN LIGHT FLASHING AGAINST BOTTOM LOGO ON FRONT OF UNIT
2 Suggested Answers
  • 1249 Answers
SOURCE: HOW TO RESET A CODE ON A SAMSUNG SMART INVERTER MODEL NO AQV24uwbn?
Unplug it, then plug it back in. Unless you repair the cause of the error code, the unit will fault out every time it sees the error. It is basically saving its own life.
Posted on Feb 23, 2015
Back light cutting out, red light flashing on front
Hi, Mister,
Two things, first check if the power supply of the tv is in good order, second, has to be your inverter, this is the circuit of the backlight. Thank,s good Luck.
Serge.
May 06, 2016 | Panasonic 65" Class 64-1/2" Diag. - LED -...
Feb 23, 2015 | Samsung Heating & Cooling
Samsung smart inverter AQV12UWAN has green flashing light at the timer and will not operate.
AUTO- DIAGNOSTIC FUNCTION
The unit has an auto diag to detect failures. When an failure is detected , the Lamp will blink.
The manual states:
Before contacting customer call center green number, please ask installer to make a double check of all connections of installation unless there's a full evidence of SAMSUNG product problem.
Oct 24, 2014 | Heating & Cooling
Green light flashing on wall unit - no cold air?
Compressor should switch on after 3 minutes.And if it does and still no cold air coming out of the inverter.Then unit needs to be gased.
Jan 06, 2014 | Heating & Cooling
Light s on front flashing - red lock light, four top green lights and the bottom timer light under indesit logo - any ideas?
Possible: You may have overheating the unit
Unplug the power cord, click the start button.. this should empty all power still stored in the PC.
you may hear some clicking..
Please specify the make and model of the PC... this will help immensly
Jun 16, 2011 | Computers & Internet
The green auto light keeps flashing on the head unit of my a/c and i can not turn the unit on. It has power, it does work, every now and then the green auto led stops flashing and i can use the unit with...
Need model and make of unit? Take off the bottom door of your furnace and there will be a label on the inside or the outside of the door it will tell you what the flashed mean.
Nov 25, 2010 | Heating & Cooling
Fujitsu inverter air cond. Just stopped working properly. Model outdoor AOT30PMAL indoor unit AST30PBA-W. Code oper. Red led flashes fast continously green led (timer) repeats 13 slow flashes. After power...
It sounds like your inverter is at fault. You will need an inverter tester ( most good service techs will have one ) to prove that the output to the compressor is correct. If the inverter is okay then it will be the compressor at fault with a location error or it is simply seized. A common fault that caused this was the eev remained closed (coil failure ) and caused the compressor to over heat.
May 11, 2010 | Heating & Cooling
My carrier split type non-inverter aircon always blinking
It indicates afault within the unit. Give Carrier a call and get it serviced.
Mat
Jul 01, 2009 | Carrier 36KCARMS Air Conditioner
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Heating & Cooling Logo
Top Samsung Heating & Cooling Experts
Nyte_Ryder
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
