Question about Kenmore Washing Machines
Kenmore dishwasher model 665.1303 Cycles will not run. machine starts normally, fills with water and then nothing. able to cancel and drain, but no cycles will go past initial water fill.
I have tried all cycles with same result. water fills but won't click over to start washing. again, hitting cancel will drain water. Have tried all cycles with all settings/options with same result. Help!
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
  • 5911 Answers
SOURCE: Kenmore Washing Machine fills with water then just stops
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at Just type in your model number and look under the "Top and Cabinet" heading for item number 11 for the lid switch and item number 20 for the lid strike (if needed). If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can also cause more potential problems.
Posted on Oct 21, 2008
  • 10 Answers
SOURCE: Kenmore Ultra Wash Diswasher - wont move past initial cycle
Motor trying to start. blockage in pump, or bad motor!
Posted on Nov 23, 2008
  • 1214 Answers
I suspect for either of these units that the timer control boards are bad.
Posted on Jan 24, 2009
  • 297 Answers
SOURCE: Normal wash cycle- tub fills (?), then comes a loud hummmm and nothing happens. I noticed water level didn't reach heater coil and added water until limiter switch clicked. Still just a loud hummmm. M
You are an expert enough reading this. But with a terrible complicated dishwasher. First clear the waterlevel problem.
Rest is a result. You do not need me, join us. Next time buy something more plain.
Posted on Apr 16, 2009
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
DIshwasher stopped during wash and won't run or drain.
Sounds like a drain motor startup capacitor, or stuck pump. Try disconnecting power and turn the water pump manually. Some disassembly required. Then after a few good hand spins replug and try again.
Mar 05, 2010 | Kenmore 24 in. 17022 Built-in Dishwasher
Dishwasher fills up with dirty water after completing cycle.
does the drain line connect to the disposal?if so and dirty water is inside dishwasher the line must be looped under the sink so nothing can run back into the dishwasher,tie the drain line up higher than the disposal or higher than the point where it connects to the drain pipe so nothing can drain back into the washer.are you sure the water is draining out of the machine?fill it up and hit cancel drain and listen to see if you hear it draining in the sink,if the line isn't looped you could have a block in the drain line or in the pump
Feb 03, 2010 | Kenmore Dishwashers
Kenmore disher skips wash cycles.
HI, this is the result of a faulty timer control module. replacing this damaged device will restore the normal functions of this unit.
Jul 17, 2009 | Dishwashers
Dishwasher fills with water but does nothing else.
If your dishwasher drains and fills as it should and cycles normally, there is a problem with the spray arm assembly or recirculation pump. Esure that the spray arm is not clogged. Manually free up moving parts if the assembly can be removed.
Jun 25, 2009 | Kenmore Dishwashers
Dishwasher hums
empty out the unit and recheck the arm and rack then start it up empty and check operation --if huming but working properly --stated it does drain so motor is operating ---then its operating normal ---if arm still not working will need to remove arm and check gear or shaft for damage
Apr 16, 2017 | Kenmore Dishwashers
Bosch SHU43C installed in 2003
My Bosch SHU43C had the same exact problem. I found the below solution on this site. Perhaps you already seen it.
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Aug 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
Open Questions:
Washing Machines Logo
43 people viewed this question
Sal De
 Brian Main
Brian Main
