Question about Tablets & eReaders
No isn't ructions to sync ONB15TA203 keyboard folio to my iPad. How do I do it? Is there a manual I can download?
Light stays on charging, doesn't shut off..... Doesn't hold a charge
Hello, Pull the electric cord and let the battery run all the way down. Pull the battery out and try powering up and down on the switch without the battery in. If that works then you have a bad battery.
Oct 04, 2015 | ZAGG Apple Folio Case With Keyboard For...
Transfer books from Kindle to iPad
You are able to move the books to computer, and then sync ebooks to iPad with iTunes. When the Kindle users connect their Kindle tablets to computer with the USB cable, their computers will recognize their Kindle tablets as external hard drives. Then the users can copy and paste the ebooks from Kindle to computer easily. After that, the users are able to sync the books from computer to iPad with iTunes.
This is easy to be done. But when users begin to sync their iPad with iTunes, they may come up with the sync problems of iTunes. The problem may come up when users sync ebooks from iTunes to iPad. During the sync, iTunes will erase all the non-purchased items in your iPad mini. If you are new to iOS devices, you will probably lose files during the sync with iTunes, so you'd better close the auto sync and manually sync the ebooks to your iPad mini with iTunes. The following tutorial will be helpful if you aren't sure about how to accomplish the task:
  1. Start iTunes and go to "Edit > Preference > Devices", and check "Prevent iPods, iPhones and iPads from syncing automatically".
  2. Plug iPad into computer via USB cable, and the software will recognize your iPad and display the iPad icon at the upper right corner.
  3. Click the iPad icon and choose "Books" in the summary panel. Choose the books you want to sync to iPad in the list below, and click "Apply" to start.
How to Transfer Ebooks from Kindle to iPad mini
Sep 29, 2015 | Tablets & eReaders
Can you change batteries on a Logitech solar kb folio?
You won't be replacing batteries on Logitech's newest iPad keyboard case. As its name implies, the Solar Keyboard Folio uses light to maintain its battery life, which is two years on a complete charge, claims Logitech. Two small solar panels integrated into the Folio use either indoor or outdoor light to keep the Bluetooth keyboard juiced up.
Nov 18, 2014 | Tablets & eReaders
Lost charger for keyboard
You could go to a computer shop and ask if they have any in there recycle bin. I did this for my phone charger and the guy was happy to help me.
Apr 02, 2014 | Cygnett Lavish Connect Folio Stand Case...
Cannot get ZAGG keyboard pair to iPad
Check that the keyboard's battery is working and it's on. Turn on Bluetooth on the iPad (Settings > Bluetooth). Press the keyboard Connect button. Choose the ZAGG Keyboard on the iPad, and type the code on the keyboard.
This doc describes the process: http://cfprod.zagg.com/downloads/ZAGGfolio%20instructions/ZAGGfolio%20instructions.pdf
Good luck! :)
Mar 25, 2014 | Apple iPad Tablets & eReaders
Adding music to iPad
You can add music to the iPad by directly downloading from the iTunes app or by importing your music into iTunes on a computer. Once your music is imported/downloaded into iTunes on a computer, you then just need to sync the music by connecting your iPad to a computer.
Oct 15, 2012 | Apple iPad 32 GB WiFi Tablet PC
Transfere photo from laptop to apple ipad
To transfer photo from laptop to iPad, follow this steps.
1. In the iPad management screen, click the "Photos" tab at the top.
2. Check the "Sync Photos" box at the top.
3. From the drop-down menu next to that, select the program or folder that contains your photo library.
4. Once all your settings are correct, click the "Apply" button at the bottom right corner of the iTunes window to sync again and add photos to your iPad.
5. Photos will consume space on your iPad, so keep that in mind as you select between syncing all photos and individual albums and videos.
May 09, 2012 | Apple iPad (16 GB) WiFi Tablet PC
I purchased Pages using the safari on the ipad. When I tried to install it on my ipad, I got a message saying that I need to open itunes on my computer. So I did. Then I downloaded Pages onto my computer....
Now you have to sync your iPad with your computer. With the 30 pin to usb connector that came with your iPad. When you hook up your iPad to your computer iTunes should automatically pop up with the iPad sync page when that happens choose sync from the page and wait until it's done.
Jan 12, 2011 | Apple iPad (16 GB) WiFi Tablet PC
I want to synchronize my email on my PC's Outlook to the email on iPad. MobileMe does Contacts and Calendar but not the email. Is there a program or technique which will do it all?
Hi Sir
You Can Use The Itunes App To sync Your Ipad
Now , How to Sync iPad with iTunes 9.1?
There Are 4 Steps .
1. Connect your iPad with the USB cable.
2. Open iTunes and wait for it to recognize your iPad.
3. Depending on your configuration, auto-sync should begin.
4. If not, then manually select whatever features you like to sync your iPad with and press the Sync button.
That’s it! Like I said, it’s the same method like you sync your iPhone or iPod Touch.
Aug 09, 2010 | Apple iPad 32 GB WiFi Tablet PC
Can I sync ipad with outlook? i'm using outlook 2007 and I really would like to sync it with my new ipad.
Hi
I had the same problem, outlook on ipad or syncing ipad with out look is very easy, just follow those few steps, Good luck!!!
I'm using iTunes in order to sync ipad and outlook, make sure your itunes is up to date (help ---->"check for updases") .
How to Use iTunes to syncYour iPad With Outlook Calendar.
* Connect your iPad to your laptop or desktop using the cable that you got with the ipad.
* iTunes will launch in the PC automatically.
* You'll need to find the itunes source list, choose "iPhone" and click on "Info" tab and then "Sync Outlook calendars" option.
* Notice in the lower right corner of your screen the "Apply" button. click on it.
Now your computer is synced with the ipad and the outlook!
Feb 11, 2010 | Apple iPad 32 GB WiFi Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
