No color only black and white picture. How can i fix this
  • 4,099 Answers
Check color system check NTSC if it is PAL it will do this if they do not match
Posted on Dec 31, 2016
I have a picture, but no color.
it will cost more to fix than a new flat screen lcd
Mar 28, 2015 | Televison & Video
The tv on;y shows a small pip window in color if it is a large picture the picture is in black and white how to fix?
Whatever input video signal you're using, PIP should be in color. What are you using out of your dvd for the second video input source, composite or component? Composite you should always have color, Component, if you have a bad red or blue, and just the green is working, you will get black and white. The green is the luminence signal.
Nov 23, 2011 | Televison & Video
Picture black & white menu color #26mf231d/37
I have the same problem too. Need a fix. This tv isnt that old and is not used that much. does not seem to be the cables or cable box. the menu has color to it but the channel picture is in black and white, flickers a bit, and seems to be in a very large pixle form. it this able to be fixed? Please Help.
Nov 10, 2009 | Philips Magnavox 27MS343S 27" TV
Screen is Perfect just Black and White only...No Color
well a dvd player is only going to playback the media it is reading. So if the dvd is a reproduction of a b/w western then b/w is correct but if you play a dvd from the present then it should be in color unless the tv it is connected to is faulty. Try connecting to another tv to see if problem repeats on another tv
Aug 15, 2009 | Protron PD-800 DVD Player
Distorted picture. changes from color to black and white.
Hi, this is a bad main board that is causing this issue you are experiencing. simply replacing this board will fix this issue.
Click Here
May 21, 2009 | Mitsubishi WS-55511 55" Rear Projection...
DVD hookup to LCD monitor only appears in black and white!
I have a RCA flat screen television and my dvd player when hooked up is in black and white. How would i fix this and if so plz be more specific then these other people.
Jan 02, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Loss of colour
Hello judithprust
The IC (integrated circuit) that controls color might be bad or the filter for the color burst might be defective. In either case a qualified TV repair person should be enlisted to fix this problem. The color burst signal uses vector mathematics to control the color output of your device, it the color burst is removed the picture will display a monochromatic (black and white) picture.
Thank you,
Shuttle83
Jul 11, 2008 | Panasonic DMR-E55 DVD Recorder
Hitachi 50 Rear Projection color TV
the easiest way is to turn the color all the way down to zero. Then notice the overall color of the screen, if it doesnt appear as a good black and white picture you will have to adjust the screens. To do that you have to remove the speaker grill cover and the small access panel, then depending on the chassis you will see a small square with 6 dials on it 3 on top and 3 on the bottom it will have screen stamped on it. adjust those 3 untill your screen appears the best black and white picture as possible. Now if your chassis only has 3 dials on the sgaure control box those are focusdont adjust them. . then the 3 CRT boards will have the dials you need adjust those for the best black and white picture. when your satisfied that you have a good black and white picture. then turn your color back up and adjust the tint.Let me know if you need more assistance.
Jun 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Color vs. Black/White picture issues
If the trouble is black and white looseboard in CRYSTAL. Loose need to resolder.
Apr 16, 2008 | Toshiba CF36G40 36" TV
Toshiba Color Television....now picture is black and white
Good day.
The missing color issue can be resolved by resoldering the loose contacts in your units circuitry. Your unit is still worth to be fixed.
Response is highly appreciated.
chris
Mar 13, 2008 | Toshiba 32A50 32" TV
Televison & Video Logo
Top Televison & Video Experts
