What is the configuration of the powercord on photosmart 2510. it is a grey plug with 3 pins
I would like to check the pins with a voltmeter to see if powercord is bad
I have a old tube cb base station gemtronics 5000gtx i found in trash years ago its missing the ac powercord but has the round plug that a powercord would be soldered onto was wondering how you would...
My book shows 3 different configurations on one all but 2 of the pins are hooked up. If you want you could look the hook up info online. Or call the folks at (706) 270 3829 they will send you a email with it in it for free.
Sep 06, 2010 | Radio Communications
How can I get the mac address for my printer ( HP PhotoSmart C4385 )
Look through the menus on the device for printing a "Network Configuration Page"
Look for "Hardware Address" on the page that prints out.
Hope this helps you!
Leave a rating if so!
Mar 04, 2010 | HP PhotoSmart C4385 All-in-One Printer
P0340 code. I Changed cam sensor and checked wiring. what else could be wrong? Jeep cherokee, 6 cil
A code P0340 could mean one or more of the following has happened:
•a wire or connector in the circuit could be grounded/shorted/broken
•the camshaft position sensor may have failed
•the PCM may have failed
•there exists an open circuit
•the crankshaft position sensor may have failed
With a P0340 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
•Visually inspect all the wiring and connectors in the circuit
•Check for continuity in the circuit wiring
•Check the operation (voltage) of the camshaft position sensor
•Replace the camshaft position sensor as required
•Check the crankshaft position circuit as well
•Replace circuit wiring and/or connectors as required
•Diagnose/replace the PCM as required
Feb 20, 2010 | 2000 Jeep Grand Cherokee
Hp 2510 wireless printer function is disabled. I
Yes there is a hp psc 2510 photosmart all-in-one.
I have had one for years--although it is not functioning properly now.
In answer to your question, though, go to the website and to america then to support/driver site. enter hp psc 2510 photosmart all-in-one in the search section and go to downloads. download the entire software. this takes a lot of time--even more if you do not have dsl.
follow the instructions. also, download the manual if you do not have one.
Sep 04, 2009 | HP PSC 2510 All-In-One InkJet Printer
Need a new power cord, how much ?
Here you go:
Compatible Part No:
  • HP 0957-2094
  • HP 0950-4466
Compatible Printers:
  • HP OfficeJet PSC 1350
  • HP OfficeJet PSC 1355
  • HP OfficeJet PSC 2410
  • HP OfficeJet PSC 2410xi
  • HP OfficeJet PSC 2450
  • HP OfficeJet PSC 2510
  • HP OfficeJet PSC 2600
  • HP OfficeJet PSC 2610
  • HP OfficeJet PSC 5510
  • HP OfficeJet PSC 5510 all in one
  • HP OfficeJet PSC 5850
  • HP PhotoSmart 1315 all in one
  • HP PhotoSmart 2510
  • HP PhotoSmart 7960
  • HP PhotoSmart 7960w
  • HP PhotoSmart 7969
  • HP PhotoSmart PSC 2510
  • HP model numbers Q3435AR, Q3435A, Q3501A, Q3087A, Q3090A, Q3094A, Q3020AR, Q3020A, Q3023A, Q3024A, Q3021A, Q3022A
  • HP Bundle PSC1315+M307 Q5776A
  • HP OfficeJet 5500 Series All-in-One Q3434A, Q3435AR, Q3435A, Q3435P, Q3436A, Q3437A, Q3438A, Q3440A
  • HPPSC 1300 Series All-in-One Q3492A, Q3493A, Q3495A, Q3500A, Q3501AR,Q3501A, Q3502A, Q3503A, Q5532A, Q5534A, Q5763A, Q5765A, Q5766A, Q5767A,Q5768A, Q5769A, Q5770A, Q5771A, Q5772A
  • HP PSC 2410 PhotoSmart All-in-One Q3087A, Q3088A, Q3089A
  • HP PSC 2500 Series PhotoSmart All-in-One Q3094AR, Q3094A, Q3095A
  • HP PhotoSmart 7900 Series Printer Q3020AR, Q3020A, Q3021A, Q3022A, Q3023A, Q3024A Q3090A
For HP 0957-2094 PhotoSmart 2410, 2510, 5510 Printers and much more.Come with power cord. Power Rating: 32V 940mA and 16V 625mA
Note: Amps and Watts are maximum load tolerance. Devices only draw as many Amperes or Watts as they needed
For purchasing you might also contact this link below:
Hope you like my info
May 25, 2009 | HP Photosmart 2610 All-In-One InkJet...
No power at all. Changed PSU and still no luck. MOBO light comes on but nothing else. I need to check the connections to the J9G1 jumper too.
If you changed out the power supply, and checked all the cables, checked and made sure the power switch was on, checked the switch for 110/220 on back of computer, confirmed it was plugged into a good socket, check the cable that connects the motherboard to the power supply with a voltmeter that may help in isolating the problem. The small motheboard light is on beause the CMOS battery is still supplying the board with some electricity.
On the jumpers, couldn't get you a diagram they are not avabilable; cover pins 1-2 is normal mode; cover pins 2-3 is to configure BIOS; none the BIOS will attempt to configure itself but you have to boot from a cd rom or diskette. Hope this helps. If none of those works then its the motherboard.
Pls rate this solution.
May 07, 2009 | Computers & Internet
Printer not printing properly
When you changed the cartridges, the printer automatically prits a test / calibration page. This page must be placed in the scanner, then you have to press the "scan" key (the green one). It will calibrate an align the system. Then you'll be able to print.
May 03, 2008 | Office Equipment & Supplies
can you do a test page to verify if you have a printer or software driver problem...
Press and hold the Cancel button for about 2 seconds.
A demo page prints out.
Make sure that the
Online LED on the
control panel lights
• If the Online LED is off, check the power
cord connection. Check the power switch.
Check the power source by plugging the
power cord into another outlet.
• If a demo page does not print, check the
paper supply in the tray.
Print a short document from a software application to verify that the computer and printer are connected and are communicating correctly.
• If the page does not print, check the cable connection between the printer and the computer.
• Check the print queue or print spooler to see if the printer has been paused.
• Check the software application to ensure
that you are using the proper printer driver
and communication port.
more info required
Nov 13, 2007 | Samsung ML-2510 Laser Printer
