Question about Exercise & Fitness
Where do I find a manual for a evo8000 healthstream treadmill?
  • 6,694 Answers
Www.manualsonline.com
If you wish to get some details ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Dec 31, 2016
How do I fix E7 error message on Healthstream Elite treadmill?
If you wish to get some details about treadmill error codes; check the site linked here. Pull up older posts.
Aug 04, 2016 | Exercise & Fitness
Want to download a manual for the healthstream GS1180T
Your model doesn't seem to be listed on the manufacturer's website. Contact them directly for additional support.
http://www.healthstream.com.tw/index.php?act=contact
Feb 24, 2015 | Exercise & Fitness
Healthstream manual I have a GE3400T healthstream
go please to www.fitness.manualsonline.com or www. retrevo.com
and download for free.
God bless you
Oct 31, 2013 | Exercise & Fitness
Healthstream GS1165T treadmill, where do I have to lubricate it, i have lost the manual
see the video and proceed according. lube the rollers bearing front+back +drive belt motor test , and replace the belt if necessary.\\God bles you
Jul 05, 2013 | Exercise & Fitness
Healthstream Elation HS 2200T - E3 code - incline not working
1) Lube the shaft and gear from elevation motor
2) Tight the connection motor very well.
3) Adjust the potentiomenter from elevation motor
4) Measure the voltage input.
5) Try to RUN the software calibration for diagnose, and troubleshooting see the block diagram.
God bless you
Jun 13, 2012 | Exercise & Fitness
Error E6 on Healthstream treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
Mar 16, 2012 | Exercise & Fitness
Owner manual for Impuls T790 Treadmill
Hope this is what you need.http://www.healthstream.com.tw/upload/2011/01/20110128111522.pdf
Sep 15, 2011 | Nordic Track Nordictrack Exp 1000...
How can fix my healthstream LS720T treadmill? my healthstream LS720T treadmill after i turn it on it slowly run then it will go faster then stop and will indicate error message E1, what is wrong with it?
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Jul 30, 2010 | Exercise & Fitness
I have a healthstream treadmill model LS3T and it has just come up with a fault ER01 which the owners manual says is a communication error. Where should I start looking
if you take the motor shroud off the front of the treadmill, you'll find wiring and connectors. check them and make sure none are loose, cracked, corroded, pinched, rubbing, or frayed and touching metal. also check under the display, there should be an access panel you can unscrew and remove to check the connections in there as well.
Feb 17, 2010 | Exercise & Fitness
Exercise & Fitness Logo
48 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
