Question about Dishwashers
Not letting in water to its wash have water running to it
    Sergeant:
  • 247 Answers
Check the fill valve should have an ohm reading of some sort,if none the coil probably burnt out
Posted on Jul 21, 2009
There comes black stuff out of the washer when i spin. Isit the stasoft?
Fill your machine with hot water (if you only have cold water connected, then add hot water with a bucket) until the machine is filled to the top mark. Add a cup of dishwasher powder and stir it to dissolve. You can also let you machine run a short while, but be carefull that the water is not pumped out. Turn the machine off and let it stand overnight. Then turn it on the next morning and let it wash a complete cycle. You don't have to let the rinse part of the cycle complete. Just turn the machine off when the first water has been pumped out.
What this does: The machine builds of a residue between the drum and outer housing which is not removed in the normal wash cycle, especially if you don't wash with hot water. LG recommends that the machine is cleaned in the above way once "fluff" or black residue is starting to show in clothes after washing.
Mar 11, 2015 | LG WFT1071TP Top Load Washer
What the cause when machine loads water but won't wash,
if the motor runs but dont adjitate its poss.the coupler if it dont run may be in the lid swich or timer
May 06, 2014 | Magic Chef CAV2000 Top Load Washer
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
No water inside washer
Does the water run right through the machine? There must be a way to let it stop inside and do what it is supposed to do. Have you tried to put it on the programme to empty all water? Then I think I would try to let is wash the shortest programme( no washing in the machine) At last let it spin You have before of course checked that all plugs are where they should be, that the water is on, the machine is closed. Kolbrun
Sep 19, 2013 | GE Washing Machines
The dishwash is not washing, it's running but there is no water. The washing cycle is completed but nothing has happen, this recently started.
Sounds like a bad water valve or the water supply is cut off. If the water supply is not cut off then try hooking up 120 volts to the water valve. It should buzz or hum and let water in. If no water goes in then change the valve.
May 15, 2010 | Dishwashers
GW52F Fisher and Paykel Washing Machine Col...GW52F Fisher and Paykel Washing Machine Cold water valve does not seem to be letting any water into the washing machine, so it does not spray rinse or deep...
You are better off swapping the valves over in the machine until you can buy a replacement valve. I've done this for a month or so until I replaced the valve. Works as long as you only use a cold wash and your cold water is not too cold as to make the machine want to add some hot. If it does this then simply press start to clear the fault.
Jan 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Face Clothes and Towels are smelling bad after being washed and dried in my Kenmore HE3 washer and dryer. Have tried running an empty cycle with bleach only, washed small loads with hot water, pre-wash and...
Try running an empty heavy duty wash cycle with a pint of vinegar added to the water, run wash cycle for two or three minutes then turn the machine off for thirty minutes then restart and let finish the full wash cycle
Aug 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washing machine letting water out on large loads
this sounds like the hose that connects the soap drawer to the drum has a split in it, within the folds, when the machine is empty the folds are closed and the water runs where it should, when loaded the folds are open so the machine leaks, check the hose and replace it, make sure it is located at both ends properly, that is the problem,, if i have helped rate me pleeasse
Sep 25, 2007 | Washing Machines
Water in my washing machine
u will need to replace the water solenoid that is letting the water in it is a fault that does occur with all solenoids,theses are were the water pipes connect to
Sep 10, 2007 | Maytag PAV2300 Top Load Washer
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
