Question about RCA Televison & Video
How to turn off internal speakers on rca led55g55r120q tv
  • RCA Master
  • 20,916 Answers
You can't normally if using the HDMI cable, although you could check in Settings - Sound. The small 3.5mm jack usually has a mute for the internal speakers.
Your manual doesn't mention it, so no you can't. RCA are inexpensive basic sets.
http://www.searspartsdirect.com/partsdirect/user-manuals/LED55G55R120Q-RCA-LED%20TV-manual
Posted on Dec 31, 2016
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
How do I turn off internal speakers in Haier L55B2181 TV?
The only time the internal speakers are disabled is if you have headphones plugged into that 3.5 mm jack. So the internal speakers will be disabled if you use any computer speakers that use only the computer audio out jack or headphones. You may be able to use a 3.5 mm to RCA audio adapter and the related cables to use other speakers in the same way. (The adapter could be 3.5 mm M to RCA F/F and a RCA audio cable to the speaker control (receiver) or 3.5 mm F to RCA M/M and a 3.5 mm audio cable. The difference will be in where you plug in the adapter.) For other external audio options, your only choice is to manually reduce the speaker volume to low. See page 6 of the manual; page 16 confirms the fact that there is no option to disable the speakers in the OSD menu. The manual is available online here: http://www.manualslib.com/manual/418427/Haier-L55b2181.html . (In this file, the relevant pages are 9 and 18.)
I hope this helps.
Sep 13, 2014 | Haier L55B2181 55 Class LCD HDTV - 1080p,...
How do i turn off internal speakers to hook up a sound bar?
There may be an internal speaker disable option in the initial set up routine.
Aug 13, 2014 | RCA L32HD31 32 in. LCD HDTV
Remote sends tv crazy
The volume controller may have been damaged from a power surge or internal disturbance; not related to the a remote control. Your TV has a set of External Out connections, usually RCA jacks colored RED White and/or Black. Red and White jacks are relative to Right and Left Speakers when an attached cord with RCA male connectors are used and connected to an Amp or some type of receiver. You should be able to use the TV OUT Audio to a small Amplifier and connect to a set of inexpensive speakers or any external speaker set. This method bypasses the TV's Internal speaker system as an alternative measure.
Dec 23, 2013 | LG 42" 5700 Series LED HDTV - 42LN5700
Speakers are mounted on the side of tv (mitsubishi CS 40503 1995 model) want to remove them and have them in a different location
"Speaker: Internal/External" controls which speaker (built-in or external) is available. Set to "Internal" for normal operation of the internal speaker system. When connected to external speakers or an external audio system, the speakers can be turned off by setting this function to "External."
From reading this I see that the speakers may be internal because the setup allows to switch between external or internal. A mounted speaker is either permanent, part of the case, or has something that the speaker case slips into. I had one like that. You simply lift them and set them else where. How far they can be moved will depend on the wire. The wire is either attached internal through the back or attached via connectors on the back. That can either be loose wire or RCA plugs. Normally the wire coming from the speakers is attached internal, making the removal of them impossible. The wire is usually 3 to 6 feet long. You can buy an external speaker wire that has RCA plugs (and or plain wire) that will attach to the existing speaker wire and TV.
Good luck and post back
Jun 04, 2011 | Televison & Video
Hi got a RCA 36 model F36648 get sound but no picture can bring up menu, do i need to hook up a dvd player or vcr to it
You probably have the internal speakers turned off. Here's a link to the PDF file of your TV Manual:
http://download.rca.com/FilesForRCAcom/Manuals/15491880.pdf
Page 46 of the manual describes how to switch the audio (TV's speakers) on and off.
Mar 05, 2011 | RCA F36648 36" TV
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
RCA tv.speakers internal
buy another speaker of your tv for replacement
Jun 03, 2008 | RCA TruFlat 27F520T 27" TV
Blown internal sony tv speakers
in menu(button on remotr) ,,scroll right to audio ..scroll down to speaker and turn them off!
Jan 26, 2008 | Sony KP-57WV600 57" Rear Projection...
Televison & Video Logo
212 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
