Question about Frigidaire Dishwashers
Does the control panel on the Frigidaire dishwasher light up during operation?
aborcass
  • 2651 Answers
SOURCE: Maytag Dishwash - No lights will light up on the control panel
first off ck the breakers ofr tripped breaker, next remove lower acess panel and on right side is main wire connection remove box cover and make sure connection is good. ck fro 110 v there if not you got an electrical issue. next would be to check the door switch assy's.
Posted on Mar 08, 2008
  • 89 Answers
SOURCE: frigidaire dishwasher
Next thing to look at--considering all the power is good--although that's what I'd check on again, would be the door switch. May have to remove the control panel cover or the door interior.
Try www.repairclinic.com if you need parts.
Posted on Oct 28, 2008
  • 311 Answers
SOURCE: dishwasher won't go on
The electronic control is bad; probably not worth the expense to fix as the next thing to go is the touch-pad.
Posted on Nov 28, 2008
localwonder
  • 6784 Answers
SOURCE: CONTROL LIGHTS BLINK BUT WONT OPERATE
Anytime the lights blink simultaneously on this model, it is because of a major control fault that has occurred.
unplug the unit or shut the breaker off for 3 minutes. if the lights continue to blink after the 3 minute reset, replace the control/timer module asap.
Posted on Jun 03, 2009
SOURCE: My Frigidaire dishwasher won't start.
Did you ever get an answer to your problem.
I've got same issue where I turn the diswasher on and nothing happens ... the time just start going down but nothing is happening?
Posted on Jul 25, 2010
Lights are blinking when trying to start frigidaire dishwasher
First, confirm that the display is working. If the display is still working, try pressing some of the touch-pad buttons. If some of the buttons respond correctly but others don't, it is likely that the touch-pad is at fault. (Some manufacturers sell the touch-pad separately from the control panel. Other manufacturers require that you purchase the touch-pad and control panel together. If you cannot replace the touch-pad individually, replace the touch-pad and control panel.) Frigidaire Dishwasher Lights Flashing or Blinking
Oct 28, 2017 | Frigidaire Dishwashers
Ongoing problem with Frigidaire Dishwasher FDB1050REC.
Let see if I can help!
If the light stays lit it would mean that the latch switch is defective and is not opening (electrically) when the door latch is cycled. When you go through the power off circuit breaker it performs the same function as if the latch switch was cycled hence the machine will operate until the next time the end of cycle clean light appears.
During your earlier repairs the inner panel of the door is removed and it is possible the switch operation was interfered with either allowing it to work or disabling its operation.
When the door latch is cycled at end of cycle the clean light should go out.
Check switch operation, installation and adjust or replace switch if defective.
If the washer is currently not working and you had smelled burning you need to check the following.:
  • Electrical connections to the control board, pump and heater. After the maintenance of removing the connectors may had been dirty and do to a high resistance connection overheated and failed.
  • Check the control board for PC track failure where the copper traces and connections have failed. Replace control board
  • The motor for a shorted winding. Replace pump motor.
These machines are very good and I would repair.
Hope this helps?
Oct 03, 2016 | Frigidaire Dishwashers
Frigidaire dishwasher no power
Hello Tammy, I appreciate your post!
From my understanding your Frigidaire dishwasher has no power. You may need to review your circuit breaker located inside of your home to assure that the breaker has not been flipped. If the breaker is operating properly it could be a possible issue with your control panel or wiring. I would recommend having a professional out to your home to assure a proper diagnosis has been completed on your dishwasher. I hope that this information is helpful to your dishwasher repair. -Matt
Apr 21, 2016 | Frigidaire Dishwashers
Frigidaire dishwasher fills but then the motor is not running for the wash cycle
Hey Gary, thank you for your inquiry!
From the information you have provided your Frigidaire dishwasher fills with water and then the motor will not run to complete the cycle. This could be an issue within the control panel or motor of the dishwasher. Which lights are flashing on the control panel of the dishwasher? Can you provide me with your model number as well? Once I have that additional information I would be able to assist you. -Matt
Apr 18, 2016 | Frigidaire Dishwashers
Fixing a Frigidaire Dishwasher (FMB33ORGCO)
Hello Paulus!
From what you have described your Frigidaire dishwasher is will not start and you have performed a reset. This could be a possible issue within your control panel or wiring harness. Since it could be an issue within the electric components I would suggest you speak with a professional technician, they would have the appropriate tools needed for proper disassembly of your dishwasher. Hopefully this is helpful. -Matt
Nov 29, 2015 | Frigidaire 18 Inch Dishwasher White ,...
Frigidaire dishwasher has blinking codes. we replaced the main control panel and the pump is and heating element are good What next?
Thank you for your inquiry, Geri!
From the information you have provided your Frigidaire dishwasher is blinking codes and you have replaced the control panel. What lights are blinking on your dishwasher? Could you provide me with your model number please? The model number can be found on the serial tag which is located on the inside left hand tub wall. With that information I would be able to assist you further. -Matt
Mar 07, 2015 | Frigidaire Dishwashers
My Frigidaire dishwasher won't start. I just moved into a condo and the dishwasher worked during inspection but now it's not...wondering if it's something I just don't know about. The model number is...
May 22, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Jun 02, 2009 | Frigidaire Dishwashers
When trying to start the dishwasher the normal load light,heat light, and other lights blink and nothing happens.
take the control panel off and re-seat the ribbon cable back on the board if that does not change anything replace your control panel.
Feb 20, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
42 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
