Question about Kenmore Sewing Machines
I NEED TO FIND OUT HOW TO THREAD A KENMORE 15819802 SEWING MACHINE
  • Kenmore Master
  • 11,756 Answers
There are multiple web sites that show how to thread Kenmores. Most machines from the same era (ie model 158) will thread similarly. (Nice, reliable machines for the most part.) Just be sure to Always raise the presser foot when threading the upper thread. Also, clean and oil (1-2 drops fresh good quality oil every place where metal rubs on metal--except AVOID oiling belts, plastic gears, and CAMS) to keep your machine running smoothly.
kenmore 158 threading Google Search
Posted on Jan 03, 2017
    Habit-Forming:
  • 50 Answers
Take the machine to a Hancock, Jo Ann or similar sewing crafts store and they will be happy to show you how to thread the machine.
How do I thread a kenmore 117 552 sewing machine ? Also how to thread the bobbin ?
How to Thread Kenmore Sewing Machine
Check with Sears. They carry manuals for most of their machines and most times they are free to download.
Aug 30, 2017 | Kenmore Sewing Machines
How Do you thread a Kenmore sewing machine model #12116690
Search internet for:
Make + Model + the word "Manual"
Or go to YouTube and search videos for your make/model machine plus threading instructions. Many machines from like eras will thread the same way.
Kenmore sewing machine thread Google Search
Jan 18, 2016 | Kenmore Sewing Machines
How do I refill the thread bobbin on a Kenmore sewing maching,,model 148-19371
You can try a couple of YouTube videos:
Loading thread on the bobbin old Kenmore sewing machine
(do not wind the bobbin as fast as he does as it tends to stretch the thread and also could cause the spool to fly off the machine!)
How to wind Bobbin Winder Sears Kenmore Sewing Machine 158 12270 158
or order an Owner's Manual for your machine:
... Sewing Parts Online Search
Sep 04, 2015 | Kenmore Sewing Machines
I need help on how to thread machine model 117-812 kenmore sewing machine
Thread, thread guide, thead guide, tension, take up lever, thread guide, thread guide, needle.
Aug 24, 2013 | Kenmore 15208 Mechanical Sewing Machine
I have a Kenmore sewing machine - 12 stitch model which I bought in the 70's. I am having a tension problem and can't seem to fix it. What is the normal setting for the top, and bottom?
Hello
Load your Kenmore sewing machine with the right thread and bobbin thread for your project. If you use the wrong weight thread for your fabric or severely uneven weights of thread, this can cause the appearance of a tension problem when it is, in fact, a thread weight problem or a problem with your sewing speed. If you go too fast, you will break the thread. If you go too slow, you can cause loops. Uneven pressure can cause stitches to vary greatly.
Test your Kenmore sewing machine's tension by sewing on a piece of scrap fabric. If your tension is way off, then test on some basic cotton or a firm blend simply to get your tension right. Do not try to start adjusting your tension on silk or leather. Get a base adjustment on a more standard fabric first.
Look at the top threads and bottoms threads. If the tension is off on one side, it will usually affect the other side slightly. So select the side that looks more maladjusted to start adjusting the tension.
If the top thread is too loose or too tight, you will need to adjust the tension dial. This dial is usually located a few inches above the needle on the Kenmore machine body. Usually, your machine will have markings to indicate which direction tightens the tension. If these have worn off over the years, watch the dial as you turn it. If it appears to move toward the machine body, then it is tightening.
If the bottom thread is too loose or too tight, then you will need to open the door to the bobbin case. On some Kenmore models, there is a little screw near the bobbin case that can be adjusted slightly to adjust the tension. On other Kenmore models, there is a screw on the bobbin case itself--not on the bobbin, but on the bobbin's casing. This will also adjust the bottom thread tension. Adjust the bobbin thread tension to make slight changes.
If the thread is looping severely on one side, the thread weights might be off. For instance, look to see if you have a lightweight thread on the bobbin and a heavyweight one on the top. If the thread keeps breaking, the top tension or bottom tension could be too tight or the thread is too lightweight for the material you have selected. Check your combination of threads and material. Also make sure you are using the right weight needle and the right foot for the sewing step or project you are working on.
If your Kenmore sewing machine's tension is off severely or if you have not used your Kenmore in a long time, then you might need to take your machine in to be serviced. Sometimes, the inner parts need to be oiled or the entire machine might need to be cleaned and calibrated by a professional. If you sew a great deal or if your machine sits idle a lot, both situations will usually require some servicing to keep your Kenmore sewing machine and its tension in perfect working condition.
Jul 11, 2011 | Kenmore 15358
Older Kenmore sewing machine stops due to threads bunched
Mary, just re-thread the upper and make sure the threaded is seated between the tension disc
Aug 01, 2010 | Kenmore 11101 Mechanical Sewing Machine
Kenmore Sewing Machine: stitch not forming bobbin thread problem
sounds like it needs a service call. if you do not have a sewing repair man you use regularly to clean machine the local fabric store should know who you could call.
Jul 20, 2017 | Kenmore Sewing Machines
I need a manual for a kenmore sewing machine.
hi there,
manuals for kenmore on internet go to search box type " Kenmore sewing machine manual"or you can shown actual threading,dial tension adjustment etc.,...on www.youtube.com
on search box type "Kenmore sewing machine repair" happy sewing,regards
Jul 05, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
48 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
