Brookstone pocket projector pro. Can you mount on ceiling?
chris5563
  • 37 Answers
SOURCE: picture upside down b/c of ceiling mount
I assume you mean a VT491?
Manual link below:
http://www.necvisualsystems.com/cms/documents/UserManuals/RS232BaseMasterProjectors_rev3.0.30f.pdf
Posted on Nov 09, 2007
devocap
  • 201 Answers
SOURCE: I mounted the projector on the ceiling and need to flip the image
Hey there jpotto, You will need to use the installation menu. Inside you will find an option called image flip. Options are HV, H, V. Check it out. It specifically is used for ceiling mounts. Good Luck!
Posted on Feb 02, 2008
SOURCE: hitachi projector cp - s210
hi there,
I have just done the exact same thing today. Press menu button on projector. Scroll (navigate) to the mirror option. This give you the options to mirror image left to right or up and down.
This should fix any of your problems.
Cheers
Luke
Posted on Feb 03, 2008
SOURCE: invert image on projector
Somewhere in the menu or setup screen, you should be able to choose Orientation. Check that.
Posted on Aug 01, 2008
  • 69 Answers
SOURCE: Hitachi projector image is upside down
you can chance it in the menu
Posted on Apr 21, 2010
Projector turns on, displays Brookstone logo and then turns off. It's not the power; the unit is plugged in.
It is most likely your lamp. If you replace the lamp then you need to reset the lamp timer back to zero or it will keep shutting off on you.
Jan 15, 2016 | Brookstone AAXA 50 Lumen HDMI 720p P3 Pico...
Brookstone pocket projector wont turn off
i'm having the same issue. it 1st started with a No Signal error. then this started...ugh!
Feb 10, 2014 | Brookstone Pocket Projector for iPhone 4...
Hdmi pocket projector color off blue displayed as red
I bought 1 today. This evening I tried it with my camera Sony HDR250V And I noted It has the same problem You Have. How did You solve it?
Jun 21, 2013 | Brookstone HDMI Pocket Projector
Projector is mounted on ceiling mount. Projector
try it without the ups unit, just in case the ups unit is dodgy
Jun 09, 2011 | ViewSonic PJ506D DLP Projector
How do i mount my hopper projector sv 10 to the ceiling
Yes it should be mounted upside down as you would not want to see the bottom of the projector all the time, unless the bottom is as good looking as the top, which I doubt. I wonder if you bought or got a ceiling mount rack with it. First mount the rack on the ceiling and then fasten the projector to it. And before that its picture has to be turned upside down too.
Aug 11, 2009 | Philips Hopper SV20 Replacement Lamp -...
Settings on ViewSonic PJ513D Ceiling Mounting
The user's guide says for ceiling mounting,
"Set Front Ceiling in the System Setup: Basic > Projector Position menu after you turn the projector on."
The user's guide is on the CD included with the projector as a pdf file. You can also download the user's guide here:
http://www.viewsonic.com/assets/006/5619.pdf
If you find this solution gives you what you needed, please take a moment to rate it. Thanks for asking here!
Feb 22, 2009 | ViewSonic PJ513DB Projector
Projection issue
sounds like you might need to change the KEYSTONE settings
Nov 14, 2008 | Sanyo PLC XU35 Multimedia Projector
62 people viewed this question
jasbo
jasbo
