Question about Grilling
Just got a Traeger and Im trying to do the initial firing. Ive plugged it in, turned it on and turned the dial to smoke mode, however, the auger is not turning. It seems the auger does not engage.
john224
  • 1378 Answers
SOURCE: Smoke or vapor coming from new h400fdn hayward pool heater.
Not at all uncommon. New heaters have to glaze over the file tile in the burner chamber and will often smoke and smell during the first week or so of operation.
Using a mirror, check to see that your flames are about 4" proud of the burner tubes when running. As long as they are and the color is a nice blue with little to no yellow/orange color, the heater is fine.
Posted on Jun 14, 2009
wireguy212
  • 1627 Answers
SOURCE: Auger blades won't turn
You need what they call a "friction wheel" replaced.
Posted on Oct 31, 2009
  • 332 Answers
SOURCE: When I turn my traeger on, the auger turns for
Call Traeger direct. I had the same problem with mine and the sent me a new control unit. Install time 15 minutes fixed the problem
Posted on Mar 07, 2010
Testimonial: "thanks for you help!"
  • 34 Answers
SOURCE: How to charge an auger on traeger grill
Turn the control on high and wait about three minutes. Shut contol off and restart in about 1 minute, This should have enough pellets in the auger to start before the hot rod shuts off. You can also put a hand full of pellets in the burn pot and usually bu the time these pellets are burned out the others are there. A couple of cycles usually will start them.
Posted on Apr 17, 2010
  • 34 Answers
SOURCE: I have an electric Traeger grill. I plug it in
Make sure your grill is unplugged. Them take the controler out and there is a fuse on the back side of the control. There is also a new fuse there to replace the old one. If the fuse is blown, you could have a bad hot rod or other component that is bad. Usually the hot rod is the problem and they should be under warrenty so call Treager and get a new one sent. If the fuse blows after it is replace, you can un hook the purple wire and replace the fuse and see if it will work them. If it does, it is the hotrod.
Why does my Traeger Smoker not hold temperature.
The Traeger has no thermostat, it works by approximating how often the auger needs to push pellets into the fire box. If the temperature is within 20 degrees, Traeger considers that within range. If you live somewhere with extreme weather, this could affect your Traeger's performance. If it's cold outside, set the Traeger to a higher temp (or get one of their insulating blankets). If it's hot, set the Traeger lower. I hope this helps.
Dec 31, 2017 | Grilling
New traeger auger wont turn when plugged in
Did you set the dial to "smoke"? The auger doesn't turn unless it's set to something, and even then, it only turns occasionally for 15 seconds, depending on your setting.
Nov 23, 2017 | Grilling
Why is there no power to my Traeger grill
There is a fuse that you can check. There is a possibility that it is the ignitor, the auger motor, the controller, or the fan.
The process to tell which item is bad, is to disconnect all but the power and the RTD wire, plug it in and turn it to smoke, If the fuse blows it is the controller, if not turn it off and start hooking up the other wires one at a time, When you find the one that fries the fuse, you know what is bad.
Aug 08, 2016 | Traeger Industries BBQ125 All-in-One Grill...
Auger is not working . How do I trouble shoot
You may want to try vacuuming the area around the burn chamber or turn the auger to see if it is froze up. Same thing as a pellet furnace.
Apr 13, 2016 | Traeger Lil Tex, Elite, Deluxe Pellet...
I have an older traeger and it doesnt seem to heat up on high mode. it has 2 fans and both work but one seems to knock now and again. when i cook chicken on high it will take 2 hours to cook.
The Traeger website at http://www.traegergrills.com/ has an FAQ about grills not reaching the appropriate temperature and how to adjust the augur to fix the problem. Here's what they say:
Q. I've been noticing that my grill temperature keeps dropping lower. What is the problem?
A. You need to "true" your auger. To do this:
  1. Run the unit out of pellets.
  2. Remove the allen screw and nut out of the auger and motor shaft.
  3. Try spinning the auger shaft over the motor shaft. The auger shaft should spin freely over the motor shaft without binding.
  4. If the auger binds, loosen the 7/16th inch bolts on the motor bracket and move bracket until you can rotate the auger shaft over the motor shaft. Then re-tighten 7/16th inch bolts. Make sure auger shaft still rotates over motor shaft, or repeat step 4 again until it does.
  5. Reattach auger and motor shafts using the screw and nut which you removed in step 2.
Hope this helps
Hope this helps
Jun 11, 2014 | Traeger Industries Grilling
On smoke setting my temp goes up over 300 degrees
Traeger suggests realignment of the augur for grills that are not getting hot enough. I wonder if this might be the same solution for grills that are getting too hot.
Here's their solution which I copied from the Traeger website at http://www.traegergrills.com/.
You might want to contact Traeger at their website to verify that this is a solution for overheating. In the above case, the improperly aligned augur was not dropping enough pellets in the firepot. In your case, it sounds like it may be dropping too many. This sounds like a routine maintenance thing that ought to be done periodically anyway.
May 12, 2014 | Traeger Industries Grilling
Treager smoke auger won't turn
If the auger won't turn because it's jammed, here's details direct from Treager
Elswise, I would check your electrical on the back of your control panel. There should be three sets of two-wire leads: (1) Purple/White=Hot Rod; (2) Orange/White=Induction Fan; and (3) Red/White=Auger. Obviously, check the Red/White leads for voltage and continuity.
Dec 10, 2013 | Traeger Industries Grilling
MY Traeger is less than a year old. I started smoking some salmon alot of smoke was bellowing out the stack. It was so much smoke I could not see the grill with the salmon when the lid was open. I close...
Sounds like you've got grease in the bottom that's catching on fire. Take the grill apart and clean out the bottom of the barrel. You'll probably need a shop vac to clean out the ash, too.
May 25, 2017 | Traeger Industries BBQ070 All-in-One Grill...
I'm getting an "Err" message on my digital temperature reading. The grill starts up but then shuts down when the "Err" message comes up.
Remove your grill, inner shield and outer dip plate from the Traeger. Start the Traeger in smoke mode. Observe to see if the blower fan is working. Is the auger turning? Are the pellets dry? Condensation can make the pellets swell and cause plug ups.
Aug 13, 2010 | Traeger Industries BBQ100 All-in-One Grill...
Grilling Logo
96 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
