Question about Janome Sewing Machines
I have an overload message on my janome 8000.If you turn the machine off you cannot push the auto lock button.What do I do?
SOURCE: Janome 8000 mc
Solution #1 worked for my Janome 8000 Thank You
Posted on Jan 10, 2008
  • 1388 Answers
SOURCE: stepping motor error
There are several possibilities, take a look at earlier solutions page for similar problem Here
I would also suggest a Q-tip or cotton bud dipped in metholated spirit to clean the bobbin case area, especially the recess track where the bobbin case spins.
If there are any needle strikes on your bobbin case which have spoiled the smooth surface required for efficient thread movement over the top, get a replacement for a few dollars.
For the record, Janome gives a 5 year warantee on circuit boards, so in the unlikely event that they fail, free replacement.
Posted on Jan 20, 2008
  • 191 Answers
SOURCE: janome 8000 will not switch on, is there a fuse
Yes, there is a slow burn fuse in the power supply.
Posted on Apr 14, 2010
  • 1388 Answers
SOURCE: I need to download a free manual for the Janome Memory Craft 8000
It is not going to happen for free.
A printed manual is $36-00 AUD HERE
Download $10-00 USD HERE
Posted on Dec 13, 2011
SOURCE: where is the auto lock button on the janome memory craft 8000
here's a link for a manual
Posted on Sep 16, 2012
Screen won't respond
Probably needs a replacement Touch Screen...please
Contact Us at Bargain Box
Mar 31, 2014 | Janome Memory Craft 5700
Overload message on my janome 8000
I know you said you have performed the reset sequence, but try these steps and see if the unit goes through the diagnostics correctly.
  • Turn off your Janome MC8000. Wait for a few seconds.
  • Press and hold the "Start," "Reverse" and "Auto lock" buttons at the same time.
  • Release the three buttons once your Janome MC8000 turns on.
  • Locate the plus (+) sign on the machine screen. Press the plus sign when prompted. Wait till you receive a message that says "Test Complete."
  • Turn off the Janome MC8000. Wait for a few seconds.
  • Turn on the Janome MC8000 once again. This will prompt the embroidery machine to conduct a diagnosis. Wait till it finishes the diagnosis and troubleshoots the errors you were encountering before.
Nov 10, 2013 | Janome Memory Craft 5700
The sewing advisor screen on a Janome 8000 is getting dim.
When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.
Janome no longer stock this item direct, but there is an affordable replacement available.
Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.
Check this Link
Also includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
Jan 26, 2009 | Janome Memory Craft 9000 Computerized...
Display screen has gone out on Janome 8000 machine.
The part is an LCD screen that needs to be rebuilt by the Janome Company. You will need to take the machine to a Janome dealer for this repair because Janome only sells to it's Dealers.. Plan on spending more than $300.
Dec 11, 2008 | Janome 8080 Computerized Sewing Machine
Janome 8000 on but witout functioning
Turn on the power switch while you are pressing the start/stop key,reverse key and auto-lock key.The LCD screen indicates(Press + Mark) You should see a ( + ) on the screen.
Press the center of the plus mark with a non-sharp object. The mark moves and the machine beeps.Do this until the screen says Adjustment END.
Turn off the power switch. Wait 10-15 seconds and turn on the power switch and see if you can select stitches.
If this doesn't solve your problem and you can see the patterns on the screen you have another problem which will probably involve a visit to a technician either Janome or Elna trained(Model CE20)
If you can't see any patterns or they are faint then the LCD board needs to be rebuilt and an authorized Janome Dealer can remove the board,send it to Janome for a rebuild and reinstall it for you.Plan on spending more than $300 for this. If the machine works well, it is well worth if as it is a very nice machine.
Nov 05, 2008 | Janome 8080 Computerized Sewing Machine
if you ever have this problem, it is because you have had something in the way of the embroidery arm at the back of the machine, so it has not been able to move freely; you'll get a terrible noise as the machine is unable to do what it wants, slips gears or something and then can't bring the arm to its home position. But fear not, i have found if you turn the machine off and gently push the arm back home to touch the machine as it is the start position, when you turn it on, it will work fine and no harm done. just make sure the arm can move freely before you start embroidery!
Jul 11, 2008 | Janome Memory Craft 9000 Computerized...
Janome 8000 mc
Sep 12, 2007 | Janome 8080 Computerized Sewing Machine
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
