Question about RCA Audio Players & Recorders
Rca RTS739BWS sub woofer won't pair - RCA Audio Players & Recorders
SOURCE: Sub Woofer Won't Work
mbruno did this work? I have the same issue
Posted on Jan 16, 2008
SOURCE: SPEAKER CONNECTION
problem with connection
Posted on May 08, 2008
  • 3 Answers
SOURCE: RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Posted on Aug 28, 2008
tech240
  • 169 Answers
SOURCE: bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Posted on Sep 20, 2009
  • 60 Answers
SOURCE: How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Posted on Mar 07, 2010
RCA RT2770 Sub-woofer sound doesn't come
The sub should generally have its own power supply, is it plugged in ???
Feb 16, 2016 | RCA RT2770 Theater System
Broken connector in subwoofer connection on receiver
The only thing you do is to open your receivers,then locate the output connector if you see the female RCA jack ,then push it out the broken piece ,that's it
Jul 27, 2008 | Audio Players & Recorders
No sound comingout now on my HT BD2T subwoofer,just humming.
Try reconnecting; then replacing the audio cable for the sub woofer. I think it is just a standard RCA cable.
When you disconnect the RCA cable does the sub woofer still hum? If so the sub woofer may be bad. If it falls silent chances are it's just the cable.
Mar 08, 2011 | Samsung Audio Players & Recorders
Some weeks ago the sub stopped working. Thought dog had chewed the coaxial driver cable, but not shorted (now). Tried another sub w/o success.
Hi, I went to the Denon website and they have no documentation there for your receiver.
But do not frown, I have some good suggestions for you.
0 Don't beat the dog. After all, it's their job to chew things.
1 Get a new, un-chewed cable and see what happens between the sub output and the sub woofer. If it works, your in business. If it does not work. Don't be discouraged . Go to step #2
2 If the sub output on the Denon has failed, and everything else is good. There is another way to use your sub.
Install a patch system using the Headphone output from the front of the Denon. It may seem odd, but it works exceptionally well for the following reasons. It works on all signal sources. So if you are not playing a home theater source, you still have the use of your sub.
You will need the following adapters.
1 A Male stereo phone jack to female mini-phone jack. (Something that would accept typical small headphone sets such as those on an iphone).
2 A stereo "Y" connector that that has a single stereo male mini-phone jack that has two "RCA" female jacks.
3 A simple RCA male to male stereo cable pair as is commonly used to connect CD players, etc. i.e. separate red and white RCA connectors at both ends.
1 and 2 above may be available as a single unit combined with each other.
Take these adapters and connect the Item 1 into the Receiver, Item 2 plugged into Item 1, Item 3 plugged into Item 2 and finally the other end of Item 3 plugged into the two female RCA jacks mounted onto the back of the sub-woofer. If the sub only has one female RCA connector, get a RCA "Y" connector that has a single male end to 2 female ends.
This setup will work perfectly with any sub. The reason is as follows. Most decent subs have an adjustable high frequency cut off. So you can vary it from about 20Hz up to about 140 Hz.
I recommend that it is cut off at 80 hz. This way the bass transition is usually seamless between the woofer and the rest of the system. .
Then adjust the woofer volume control in a similar manner.
If it all works out, give the dog a treat and enjoy yourself.
I really hope this helps, I love my sub woofer as well.
Let me know how this turns out.
If you have any questions please post them on the site and I'll get back to you ASAP.
Best Regards,
Mark
Jan 22, 2011 | Denon AVR-3600
Feb 20, 2010 | Yamaha HTR-5630 Receiver
AV receiver single line output to two line input on sub woofer
You are trying to connect the powered sub output of the receiver to a standard (unpowered) subwoofer. Can't be done.
May 05, 2017 | JVC Audio Players & Recorders
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
RCA Sub-Woofer
Jul 26, 2008 | Sony STR-DE445 Receiver
Sony subwoofer model# sp-pwm505
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver allenfreedman@yahoo.com
May 15, 2008 | Audio Players & Recorders
137 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
