How do I change my hd format to standard. It is currently in stretch format
    New Friend:
  • 25 Answers
Si Te funciona bien el control remoto del tv ve a configuracion de pantalla y desactiva el zoom o funci?n de estiramiento si no esta activada entonces ve a configuraci?n de pantalla y ajusta en el men? tu tipo de pantalla o tambi?n resetea el tv en la funci?n que trae de factory reset espero q resuelvas saludos.
Posted on Dec 31, 2016
In hd the picture is curved on bottom and top
Is there a place for you to change the format of the tv,ie: zoom, standard, stretch, etc?
Feb 10, 2011 | Televison & Video
There is about an inch on each side of my screen that is cut off and I can't see it. What do I do because I don't have the remote? I have the Insignia NS-27HDT 27". thank you.
you need to set pix format you might try using a universal remote or check menu on tv for pix format and size like full zoom etc.
Oct 10, 2010 | Insignia NS-27 TV TV
Good evening, I've gone through the manual and I can't get my TV to show 100hz (always 50hz), also on some channels I cannot get the picture to fit the screen (it's 32''). Any help would be greatly...
Well, first the 100Hz issue. Your TV will display a descriptor or the signal it is receiving, not a descriptor of the picture you are watching. Your TV panel has a native resolution and frequency. In your case, that frequency is 100Hz. Everything, like it or not, must be converted to 100Hz for the TV to work. In your manual, you are simply adjusting setting which smooth the picture and make it flow better than it would at 50Hz. This feature is slight of hand and is probably working just fine. As for the picture fitting the screen; HD programs fill the screen of HD channels.... SD (Standard Definition) programs use black bars on each side when on HD channels. You can use any available wide or picture size feature your TV may have to stretch the picture. You may be unable to stretch the picture, due to restrictions (some TVs will not resize HD formats).
Mar 15, 2010 | Televison & Video
I re-scanned my channels this weekend because I lost HD on 2 of my local channels. Now I have HD back, but I have 2 black lines on each side the picture on all of the HD channels. How do I get rid of the...
A broadcaster will transmit an HD channel in 1 format. This may be 720p or 1080i, both of which are HDTV formats. HDTV formats have an aspect ratio of 16:9. SDTV or standard definition broadcast have an aspect ratio of 4:3. Because not all content is record in an HD format (ex: Judy Judy), the broadcast is faced with 2 options. #1, stretch the 4:3 picture do that it fills the 16:9 canvas. #2, simple place black side bars on each side of the 4:3 image. What you are seeing is the latter of the 2 options. You will notice a change during the evening programming. The bars are only there when the content is not HD. You can use the WIDE feature of your TV to stretch the picture so that it fills the screen, just like broadcaster option #1 above.
Mar 15, 2010 | Vizio VW37L 37 in. LCD HDTV
It say 480 stretch on the screen how do I turn it to 1080 for my Hd tv
Make it sure that you have a 1080 signal from your source(eg. HD receiver, bluray player etc.). Try pressing format button on the remote until you get full picture . Or try changing the format or aspect ration in your satellite or cable box.
Dec 29, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Trouble using Motorola DCH6416 HD DVR with standard def. tv
I fixed the problem! I found a posting on a message board by someone who had the same DVR and a similar problem. This person found a way to access a secret menu in the DVR to override the format which is automatically assigned. I followed the same steps to access the menu on my DVR and then tried changing a few settings until I found the ones that worked--changing the automatic setting from OVERRIDE to STRETCH and changing the output setting from 1080i to 480p. (It's pretty pathetic that no one at Charter could fix this problem!) Here is the link to the posting that I used:
Oct 01, 2009 | Motorola Televison & Video
Mitsubishi 55" - Stretches screen
on the frount you should have ch up , ch down,
same for volume , and menu. press menu
and scroll down to VIDEO or SET UP
try one of thoes sub menu will have FORMAT
4:3 - 16:9 seting its a little differant on
on same make diferant models , you may
have to do a little hunting to find the setting
Jul 02, 2009 | Mitsubishi WS-55807 TV
Picture doesn't fit screen
If you haven't tried to change the format yet, try that first. Most of these tv's have a wide range of options from full to wide to split etc. Stretch would probably work in most hd formats.
Nov 23, 2008 | Mitsubishi WS-55511 55" Rear Projection...
I have a DVD player Panasonic DMR ES20D which is working OK but I have just been on the Amazon site to make DVD a purchase and the site has a warning in red reading " Warning this HD-DVD will not play...
Even though you have an HD TV, the DVD player is not HD-capable. You will have to upgrade to an HD set to use those discs. (You might consider that Sony's system, "Blu-Ray, is now the format winner in this case, and therefore try to find your disc selection in the Blu-Ray format.)...accordianman
Jul 20, 2008 | Panasonic Televison & Video
High Def disks
No! This player is not equipped with the blue laser and format to read HD. Currently there are two format es for HD. Blu- Ray and HD/DVD. Only these are capable of reading HD disk. Blu-Ray is going to be the industry standard
Jan 16, 2008 | Cyberhome CH-LDV 707B Portable DVD Player
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
