Question about Pool & Spa
Just had our circuit board on H400FD Haywood pool heater replaced. Heater did fire up but wouldn't go past 65 degrees and went to standby.
Heater is stuck in standby mode and can't get it out of that mode. Won't heat higher than 65
    New Friend:
  • 60 Answers
It may be wired incorrectly, there are 3 terminals for the Hayward heater that connect it to automation.
1 spa
2 pool
3 comm
If they are not wired correctly this issue can happen.
  • Pool guy Jan 02, 2017
    Also turn the temp setting on the heater up to 104, that way your automation can heat it to your desired setting without the heater itself causing interference due to a low temp setting
HAYWOOD POOL HEATER
if voltage ok coming in check transformer if ok bad display or fuses
Apr 22, 2013 | Hayward H Series Pool & Spa Heater 200k...
Hayward H400FD. Can't adjust temperature.
need new display board also check if connected to a system disconnect and try alone
Jan 28, 2012 | Hayward H400FDN Low NOx Natural Gas Pool...
Rheem 206 propane heater will not fire has code #sns what is the problem? the water is 65 degree.
SNS means the temp sensor is out of acceptable range. Could be the following:
1. Water temp is below 36 degrees F
2. The sensor contains 2 thermistors, if they are more than 2 degrees apart and SNS failure will occur
3.Loose or corroded connection at P1 on the main board
4. If the sensor has come out of the JACO fitting on the header, it may read a SNS failure.
Solution, visually inspect the connections for corrosion. If it looks ok, then replace the temp sensor.
Jan 01, 2011 | Rheem M206A 206K BTU Pool and Spa Propane...
I have an RP 2100 pool heater and the minimum temperature set point is 65 degrees. Every time the pool/spa temp falls below 65 degrees, the heater automatically turns on. How can I either disable this...
Do you have an electrical switch that turns this heater on/off?
Can the heater be unplugged?
Is the heater on a separate circuit breaker that can be shut off for the season?
Nov 27, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Hi, I have a hayward H millivolt gas pool heater that started up fine this season but now the standby light is light and I cannot get the panel to do switch..Unfortunately I misplaced the manufacturers...
There is no standby light in the millivolt heater. If you have a standby light it is an electronic fired unit.
If the board is locked in standby, try powering down the circuit feeding the heater and see if it resets itself. If not you'll need a new control board.
Jul 09, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool & Spa Logo
66 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
