Question about Building Materials
My neighbor's 2008 Camry is suddenly opening and closing my Craftsman garage door opener. He lives about 200 yards from me. How do we get it to stop? Thanks.
  • 16,608 Answers
You did not post the model of the opener but there should be a set of switches that are very small and you use those to set the encoder frequency on both the remote and the opener.
Posted on Dec 31, 2016
  • Richard A SCHROEDER
    Richard A SCHROEDER Dec 31, 2016
    Thank you for responding. He isn't using a hand-held remote. It's his Camry's built-in Homelink that's suddenly (after 8 years) operating both his door and mine. After reading some responses to other similar issues, I think I'll try holding my learn button for 8 seconds to clear all of the codes. Hopefully his Camry's button won't work on my door anymore and I can just reset my remotes.
  • Brad Brown Dec 31, 2016
    This is why posting the model info is so important.
Whisper Drive garage door opens and closes by its self
try changing frequencys you might have a neighbor close by that is using same frequency as you causing your door to open when they open theirs
Jul 18, 2012 | Home Security
I live in a 4-unit condo building constructed in 2008. Recently, after I trained/programed a garage door opener incorporated in a new car I purchased, I discovered that my garage door started to be...
I would recommend this. I'm not sure this will work, but I think it will.
Try starting from scratch. Reprogram the unit to the car again, I think the codes change each time it is done. If not, it's not too difficult to try.
Jan 01, 2011 | liftmaster Chamberlain Garage Door Opener...
I really need your help. My Craftsman unit model number is 139.53615SR manufactured 1/92. I have a three car garage. The original two remote controls were lost and since then I've used the setting in my...
Have your neighbor bring over his remote and open or close your door with it. Then hold the smart/learn button in for 6 seconds on your opener. Then see if he can open your door. He shouldn't be able to because that procedure erases the memory in your opener. No remotes should work. You need to get that remote #53778 back and program it and then see if your neighbor can open your door. If he can open your door at any point after you have held that button in for 6 seconds you need to get a new door opener.
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened by neighbor
Have you seen the neighbor open your door? The reason I ask is because it is almost impossible. The most common cause of a door opening by itself is a bad wall control or the wiring leading to it. You can temporarily eliminate both possibilities by removing the wire from terminal 1 at the rear of the motor unit. Do this and ask your neighbor to bring over his remote and try it on your opener.
Jun 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door openers gone haywire
do not understand what you mean by can't reprogram openers, How old, Dip switches inside. Security plus. Need more info.
Sep 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman (older model)
Do you have the option to change the electronic codes on your garage door opener system? My father-in-law had the same problem a number of years ago. He had not reset the code (equivalent to the combination on a lock) from the equivalent of 0-0-0 (which his unit shipped with). Turned out that a neighbor (or neighbour - in Canada) had the same /similar unit and when the neighbor opened 'his' door, my father-in-law's door would also open. You don't have to see the person drive by - it can be the neighbors behind you as well. You may find a solution by determining if you can change the original electronic code to a different one of your own choosing.
Hope this helps.
Dec 17, 2007 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
52 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
