Question about Coffee Makers & Espresso Machines
Same thing Kuerig Rivo just stopped puncturing the cups. The machine uses a small cup exclusive to this model. any fixes out there?
  • 9 Answers
SOURCE: b60 just flashes not ready yet ,have unpluged and
There has to be water in it first off. See my solution on the B50 with a similar problem. Before the lights blink ready the top (K-Cup Holder)has to opened and closed. Then the lights should blink and it should say ready to brew. I wish I had included that in the previous solution on the B50.
Posted on Mar 05, 2009
  • 211 Answers
SOURCE: coffee ground are coming out of the k-cup area
Make sure the needle in the bottom of the K cup holder is not missing, broken or bent. Also, look at your used K cup when it comes out. Is there a hole in the top and the bottom? It sounds like the pressure is building up within the K cup due to a backup at the bottom of it. This could also occur if the bottom needle hole is obstructed. Be careful...the needles are sharp!
Posted on May 28, 2009
  • 3600 Answers
SOURCE: keurig B70, the my k cup , weak weak coffee !!!!!
It is best to take it to the store you bought it from and have them fix it and watch or replace at no cost to you. Tell the store what they said to you and have them show you how to do it. If you work on it and break it you own a broken machine. Hope this helps.
Posted on Aug 26, 2009
  • 186 Answers
SOURCE: Coffee Maker only brews 1 cup at a time
Hello. I just talked to Cuisinart and they recomended running a solution of 1 part vinegar and 3 parts water through the brew cycle,then a full pot of plain water to rinse, to remove hard water deposits. The phone # to Cuisinart is 1-800-726-0190. I hope all works out for you.
builderdale
Posted on Jan 12, 2010
SOURCE: the small and large cup buttons are alternatly
I had the same problem and was told it needed to be repaired by Nespresso and the cost would be 115 euros.
Posted on Feb 02, 2010
Testimonial: "Thank you, Yes, Nespresso said that same to me, I didn't have it fixed I could have had a refurbished one for $100 or receive $125 off a new machine. "
Keurig Rivo wont puncture cup
make sure the plunger is in place both on top and bottom
Nov 29, 2015 | Keurig Rivo R500 Brewer
There is no hole in the bottom of the kuerig k-cup. Is there possibly a part missing?
The Keurig will puncture the K-cup when it is inserted before brewing. If it is not being punctured, the brewer is damaged,
Oct 08, 2014 | Coffee Makers & Espresso Machines
Keurig rivo not puncturing
Just push the cup firmly down onto the lower needle before closing the "clamshell" and puncturing the lid of the K-cup also. Read the attached link, other people have this problem.
2nd link explains problem very well.
Preventative Measures How to Keep Your Keurig Brewing Cup Barista
Fix your Keurig imsolidstate
Apr 17, 2014 | Coffee Makers & Espresso Machines
Kuerig keeps brewing without pushing button
my kuerig has water come through the k cup when I close the top without pushing brew cup size and if it does let me make a selection it brews 1/4 of cup I have descaled it 4 times locked in the water reservoir cleaned the needles turned it on and off any other suggestions to try would be greatly appreciated thank you
Nov 08, 2013 | Keurig Coffee Makers & Espresso Machines
Using the k-cup..does not brew the water splashes everywhere
That is because most likely the part that punctures the k cup is most likely clogged, try using Like a paper clip and cleaning out the small hole and should flow. Mike
Oct 29, 2011 | Breville BKC700XL Stainless Steel
Keurig B60 not brewing a full cup
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 22, 2011 | Keurig B60 Coffee Maker
Coffee overflows and grounds sit on top of pod
heatman101
May 18, 2011 | Keurig B60 Coffee Maker
Water coming out of vent of my keurig and brewing a partial cup
heatman101
Mar 21, 2011 | Coffee Makers & Espresso Machines
Coffee won't pass through pod
the K-cup is punctured at the top and at the bottom.
you can take a corkscrew, and puncture a number of holes in the bottom of the K-Cup... verify there is a hole at the top... just before you start to brew... press down on the black arm over the cup... but not too hard...Lets see what happens... if it all looks good... no problems... then we need to either adjust the arm... or shim the k-Cup up a little bit...
you may also check the rubber Seal around the top pin that punctures the K-cup...
sounds like you lost your rubber seal around the top of the K-cup...
you can re-phrase after looking and testing....
Apr 28, 2010 | Keurig B60 Coffee Maker
My coffee maker stopped working. I got it going a
In some cases, you can also get the electronics to reset by leaving it unplugged for at least 15 minutes. This may resolve whatever is locking up the machine.
Another possibility is that it may need to be decalcified, especially if you haven't done so recently. Try looking up your model number on the web or on the manufacturer website. Download the owner's manual, if need be, and view their cleaning and troubleshooting sections. If that doesn't work, contact the manufacturer during normal business hours. The unit may require service.
Mar 06, 2010 | Keurig Platinum B70 Coffee Maker
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
