Question about Husqvarna Garden
On a husqvarna 327pt5s pole saw, engine runs great but shaft doesn't turn.
    Welcome Back:
    Visited the website for 2 consecutive days.
Which shaft?
Posted on Jan 03, 2017
How do you seperate pole from engine on husqvarna 327pt5s chainsaw?
The end going into the clutch is splined. It is held in place by a spring clip. Carefully pull the shaft from the clutch, do not force it. If it does not snap out, you may have something stuck on the clutch side.
Dec 31, 2016 | Husqvarna Garden
Remington Pole Say
check for a roll pin in the gear or shaft that has sheared off
check that the square end of the drive shaft is not rounded off or that the square drive in the gear is in fact locking on the drive shaft and not turning from worn out
Jun 20, 2016 | Remington Electric Pole Saw
STIHL pole saw 101
Hi Little Bird
Chances are that the clutch needs servicing or replacement.
Here's a link that explains:
http://www.lilredbarn.net/Stihl-HT-101-Pole-Pruner-Clutch-s/29554.htm
Cheers
Jun 06, 2016 | Stihl HT101 Pole pruner
Husqvarna 350bt blower runs great but goes dead at half tank of gas.
I had a Husqvarna saw with a similar issue. Turned out to be a deteriorated fuel line. There was a hole in the line, sucking in fumes then cutting out the engine.
Dec 05, 2014 | Husqvarna 350BT 50cc Backpack Blower 50cc,...
I have a RYOBI pole saw that starts fine, but there is a disconnect between engine and saw blade. The blade will not turn.
I assume you have the Ryobi powerhead with the multiple tool shaft (can use it with an edger, blower, trimmer, and pole saw) If so, does the powerhead square drive spin when you squeeze the throttle trigger? Does the chain move freely on the saw end when not connected? Is the attachment fully inserted into the powerhead shaft (small spring-loaded button should pop out of the hole when fully inserted.
Aug 26, 2011 | Garden
How to replace accessories from a husqvarna power motor
Straight from Husky, the pole saw runs about $200...or if you have the straight shaft, you can get just the head for $185:
http://www.husqvarna.com/us/homeowner/products/trimmers/popular-accessories/
May 05, 2010 | Husqvarna 28cc Gas Line Trimmer
My husqvarna 51 will not idle after cylinder replacement
Did it receive a new piston and rings at the same time? Is the carburetor firmly mounted to the cylinder? Check for muffler plugging. Did you make any adjustments to the carburetor jets? Try turning the idle-speed-screw CW a turn or two. Are you running fresh fuel mix? If the ignition module was removed, set the pole gap with a thin business card and have the magnets under the pole pieces. Hope some of this helps!
Apr 09, 2010 | Husqvarna Chain Saw 20" Bar
Runs great for 30 sec. to 1 min. then dies slowly
Is it your chain saw Husqvarna 40?
Try carb adjustments H-3/4 turn ,L-2 turns and T a little higher
I presume that compression and ignition sistem is adequate for the engine to run.Good luck
mihai
Apr 04, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
44 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
