No setup button on remote - Televison & Video
How to setup phillips universal remote to a panasonic tv
Philips Universal Remote control Instructions
  1. Turn on the device (TV, DVR, etc.) you wish to operate.
  2. Press and hold the SETUP button until the red light indicator remains lit, then release the SETUP button.
  3. Press and release the desired mode button (TV, DVR, etc.).
More items...
Philips Universal Remote control codes for TV, VCR, Set-top Box ...
www.directutor.com/.../philips-sru210327-universal-remote-control-codes-tv-vcr-set-top... How to setup phillips universal remote to panasonic tv Google Search
Nov 29, 2016 | Panasonic Televison & Video
Where do I find the setup button on my Quantum Fx remote control
There is no such button with this remote control. Use the input selctor button [TV/AV]; instead. If you wish to get some details; check the site linked here. Pull up older posts.
http://electrohelponline.blogspot.com/
Sep 03, 2016 | QuantumFX Quantum FX Universal Remote...
Does anyone have the code for sky remote to tune it in to the sa-ht880 Home theatre I did have it on old remote and the volume button worked but can't find code now :-(
Step 1:
You can set up your old remote very simple.
your old remote should have a "Setup" button.
Step 2:
Next you have to have your T.V/Home Theater on.
Step 3:
While the T.V is on press and hold the "setup" button for 3 seconds on your old remote.
a light should indicate that its on "setup" mode.
Step 4:
while your remote is on setup mode point it to the T.V and press the "Power" button until the device turns off.
Step 5:
Once your T.V turns off you can press "Enter" on your remote will be setup and ready for that T.V.
Feb 06, 2013 | Televison & Video
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
There is no setup or code button onthis remote so how do i get it to program to tv manual nas been lost
The only solution seems to be: return this remote and get a better remote that has a 'setup' button. What pinhead designers produce a universal remote without a setup button?
I"m facing the same thing....
Jan 10, 2011 | RCA RCRN04GR Remote Control
Looking for remote codes for vizio sound bar and comcast remote
I have a vizio universal remote and the code that works the vizio sound bar is the first one listed under audio/vizio 0660
Oct 16, 2009 | Televison & Video
Is it multiregional
Sony are probably the most protective manufacturer of this kind of information. All manufacturers carrying a DVD logo are obliged to say "no" but will normally intentionally leak this to boost sales, particularly in non-US areas.
But try this:
  • Press the DVD button
  • Hold down the Magic button until the unit performs a double LED flash
  • Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option 3. On your DVD recorder, using the official Sony remote, select the Setup option 4. On your DVD recorder, using the official Sony remote, select the Options option 5. On your DVD recorder, using the official Sony remote, select the Command-Mode option 6. On your DVD recorder, using the official Sony remote, select the DVD1 option 7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover 8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player 9. Program your OneForAll remote with the following instructions:
  • Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
  • Press the Magic button once
  • Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
  • Press the 1 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
  • Press the 2 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
  • Press the 3 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
  • Press the 4 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
  • Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode 15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 16. Your DVD player should show the words TIMER OK 17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 18. Your DVD player should return itself to Standby mode 19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Nov 27, 2007 | Sony DAV-S500 System
Can get to region unlock menu but refuses to change.
hi try this one there are 2 versions they both have different chips.
  1. Power Up the unit with NO Disc in the tray.
  2. Press the Setup button on your remote control
  3. Press the 1 button on your remote control
  4. Press the 6 button on your remote control
  5. Press the 9 button on your remote control
  6. Press the 5 button on your remote control
  7. Press the 1 button on your remote control
  8. Press the 8 button on your remote control
  9. Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
  10. Exit the menu
  11. Press the Power Off button on your remote control
  12. Press the Power On button on your remote control
it worked for me.
Sep 24, 2007 | Cyberhome DVR 1600 DVD Recorder
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
