Question about Royal Vacuums
Royal canister Bag was full and it just stopped running?
    Genius:
  • Royal Master
  • 1,069 Answers
It may have overheated. Put in a new bag.
Posted on Jan 03, 2017
reddevil6
  • 1673 Answers
SOURCE: loss of suction and bag full
Sounds like you still have a clog, either in the hose, drop something down it to see if it comes out the other side. The other place is the dirt inlet by the brush roll. Take off either the top cover or the bottom plate and you can check it out.
Posted on Feb 19, 2008
ginko
  • 19396 Answers
SOURCE: Model 2100 canister: Red
try this
Electrolux LE, 2100 Hi Tech Canister
Posted on Apr 26, 2008
advacak
  • 125 Answers
SOURCE: what bags do I use for Royal canister vacuum #3004
uses a royal or dirt devil type R bag
Posted on Dec 08, 2008
  • 566 Answers
SOURCE: Electrolux #1521 Canister Vacuum won't stay closed
hi from uk your problem with the canister cover/door coming off whilst vaccing ? you have renewed bag ? ok but there is a filter/gauze also inside the canister where bag is fitted if you check inside you should see the filter at opposite end from where bag is secured it is usually fitted behind a slotted pull out plastic gate ? this filter/gauze is to allow air out of canister when vaccing and the filter traps any dust that may accumulate inside the canister case so the dust does not get blown out to atmosphere/rooms SO if this filter is clogged it will not allow vacced air to escape out of canister so result is build up of pressure within cylinder and eventually cover flips open ! so for now you can remove filter/gauze and wash then dry refit this will allow air to escape from canister but still retain dust particles from escaping as it is designed for however may i suggest you replace filter when convenient ? all above is on assuming that the latch on cover is working ok and not now damaged ? hope this helps best wishes
Posted on Mar 01, 2009
  • 430 Answers
SOURCE: Electrolux model 2100 shuts off with slightest suction blockage
This is exactly the symptom you would expect from a defective bag control valve. The actual control valve sits under the dial on top of the vac and often cracks internally. It can be replaced in about 15 minutes by a good tech with genuine parts from AERUS Elctrolux dealer or repair center.
You can open the vac front to rear like a **** shell by sliding the bumpers out the front with the bag door open, however you must be careful not to disturb the wiring harness and to mark wiring locations. The body must be carefully realigned for closure. If it is not perfect you will not be able to slide the bumpers back in.
Posted on Dec 17, 2009
Using hoover, stopped working. Bag very full so changed. Hoover seems very hot. Will not work. Checked fuse
Give the vacuum time to coold\ down, then try again. If it still doesn't work, take it to a repair shop to be checked.
When a vacuum is used for long after the bag is full, the motor can overheat to the extent that the motor burns out. This is one of the benefits of having a vacuum that shuts off when the bag is full.
You should also check the hose for clogs. Disconnect at both ends and drop a coin in one end. If it fails to fall through, there's a clog that needs removed. This is likely to happen at the canister end when the bag gets too full.
Apr 04, 2011 | Miele Cat & Dog 326i Bagged Canister...
Put in new bag but as soon as we turn vacuum on motor stops red light comes(bag full)
make sure the bag is installed properly and the bag door is making contact with the small switch by the bag.
Jan 03, 2010 | Electrolux Guardian Bagged Canister Vacuum
Stopped working, lights work, shows full light when not full.
Remove the bag and put in a fresh bag. Then rotate the dial on top of the vac to the middle position. When cleaning fine dust the vac will shut off before the bag is full as it is sensing a clogged bag and cannot sense proper air flow through the bag. If this persists the sensor under teh top dial may be damaged and need to be replaced
Sep 08, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Bag full indication comes on; changed bag; still wont run.
Turn the knob on the top of the vacuum all the way to the right and try it again
Jun 15, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Belt needs fixed after sucking up a soft rug.
if its a canister model there probably is no belt just suction.open the canister and if it has a bag feel the bag ,if it feels kind of hard then the bag is full.take the tool off the end of the hose and turn it on to see if you have suction if you do then the tool is blocked up.take it to the sink and run some warm water through it and maybe use a little brush to clear out the dirt.full bag will cause your vacuum not to have suction or not as much as it should
Apr 09, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Mar 01, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux 2000 Mod# c151c
Turn the knob on top all the way to the right
Jul 04, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Vacuums Logo
23 people viewed this question
Top Royal Vacuums Experts
Electroboy
Electroboy
Are you a Royal Vacuum Expert? Answer questions, earn points and help others
