Question about Lexmark X4270 All-In-One InkJet Printer
Massage unsupport ink on lexmark X4270
Dear all
i have problem which a serious problem ,initially pot is clean ink then we reffiled,for a few week can walk but then there are massage of unsupport ink.since thereare the massage printer cannot be used for copi or print
  • a_sof Nov 20, 2007
    dear all
  • 42 Answers
Sadly, not all inks are created equal, and even inks that are claimed "compatable" are not allways safe. My HP photo printer worked great for 2 years, then I put in a "will fit" from a name brand office supply store, the printer nozzles plugged on the second print, never to print correctly again. My replacement printer is a Kodak 5300 all in one, chosen for low ink costs/ hi-output, and I get photo-lab quality, borderless prints day after day. (I'm a photographer/artist) I have run 6 color and 5 blacks for thousands of graphics, in a period of 2 months getting ready for a showing, with maybe 1 or 2 misprints.
Posted on Dec 09, 2007
Brother mfc-240c - getting massage cleaning impossible how to solv ?
The purge counter has reached its maximum and the waste ink container needs to be emptied and the pads cleaned or replaced. It is not overly difficult but seriously messy. look for brother waste ink reset on google for instructions on the keycode to reset the ink counter.
Nov 07, 2017 | Brother Office Equipment & Supplies
My kyocera fs 1120 mfp all in one lasser printer showing massage out of toner after riffil toner why?
you hv refilled toner only,you should change complete cassette of toner,including electronic chip circuit
Dec 11, 2014 | Kyocera Office Equipment & Supplies
How to reffil ink cartridge
I don't recommend refilling ink cartridges for a multitude of reasons.
The ink isn't always the correct quality/viscosity so the heads can get blocked. It only takes one cartridge to be refilled badly to go on and ruin your printer. The process can be very messy.
Mar 26, 2014 | Office Equipment & Supplies
Bunn automatic coffeemaker leaks water after making a pot
Tank and tank components should be delimed regularly
depending on local water conditions. Excessive mineral build-up
on stainless steel surfaces can initiate corrosive reactions resulting in serious leaks.
Feb 02, 2013 | Bunnomatic Corp. 10c Professional Brewer...
I have reffile the toner but printer massage is Toner Empety
You need a new cartridge original samsung to clear the message ''toner empty''.
Mar 04, 2011 | Samsung SCX-4720FN All-In-One Laser...
The ink cartridge in my Canon MultiPASS F50 ran out. I replaced the cartridge correctly, but now when I try to copy a document using either the laser copier or the fax part of the machine, the papers come...
...I try to copy a document using either the laser copier or the fax part of the machine...
These isnt laser copier, you probably refer to scaner assy... but never mind.. lets solve your problem!
First, new inks are reffiled or original?
Remove inks and look for small hole, ussually on top of crg. and blow in it verry hard.After that from crg. must start to drop ink. Put the ink back in and try to copy/print something.Also run head cleaning for few times.
If now it works that could mean two things:
1) the ink was for long time on warehouse, and nozzles are clodged.
2) your purge unit is faulty and it cant drain ink from crg.Replace purge unit, wich isnt cheap solution.
Or,... buy new LASER Canon multifunctional copier that uses TONER.
Hope that helped!
Aug 09, 2010 | Canon Office Equipment & Supplies
Brother Mfc 240c will not print using black ink... cleaned and reinstalled ink cartridge that is full, but has been refilled. Any chance this is an easy fix issue?
we can refill 100 times but it woks.probly refiling methood is mistake. one time pul out all ink and gas of cartage by sering.and reffil again.
Oct 28, 2009 | Brother MFC 240C All-In-One InkJet Printer
'Carriage jam' error always seen on power on
The cleaning station is designed to take care of that ink, it's not a problem. When powering the printer on, see if the cleaning station is moving and what causes the cartridges to be jammed. The cleaning station can lock the carriage if it's incorrectly initialized (ie, after disconnecting the printer if it wasn't turned off). Try to manually move it (with a pen or something) to the back of the printer, that would unlock the carriage.
Jan 15, 2008 | HP Photosmart 2710 All-In-One InkJet...
Ink jets clog after periods of non-use
You need to run inkjet printers regularly. I expect your brother is right - for once?
If you can't get them clean, replace the cartridges, and print a test sheet at least, every week or so.
You may get away by standing the bottom of the cartridges in windex, or other mild solvent, for a couple of hours. It may save a few teaspoonfuls of ink, but the initial prints will be rubbish ;-)
Dec 21, 2007 | Lexmark X75 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
