Question about GE WBSR3140DW Top Load Washer
Washer working thenstopped - burning rubber smell
Washer stopped working with wet washer inside could this be a case of the motor being burnt our
    Problem Solver:
  • 17 Answers
I happened to me once and it was a case of a shoestring getting sucked into the pump. I had to disassemble the pump to get it to work again.
Posted on Jul 21, 2009
Washer smells like burnt rubber
What is the make and model of your washer? I had a similar problem with my Maytag - there was a burnt resistor on the control board. We ended up just buying a new washer since the cost for parts alone was close to $400...the labor would have been a DIY-thing (15 minutes easily for the greenest amateur).
Nov 28, 2011 | Washing Machines
Smell like burning rubber
if it smell's like rubber it likley is .. smell's like a belt driven and it needs a replacment belt & idler .. remove the two screws at the bottom of front panel an remove .. in the front center at the bottom .is the motor / belt and pump .. if there is black rubber in bottom / wala . the belt is burning . / look for pump leakage / this would get belt wet and slip.. thanks mm .
Dec 02, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Smoke and it smells comes out of vents when ac on nissan altima
Smoke from under the hood ?
Smells like burnt rubber ?
Either the compressor or the comtressor clutch is bad so it locks up wen you urn it on and the fan belt is burning..
have the ac system inspected..
Aug 20, 2009 | 1998 Nissan Altima
Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
May 18, 2009 | Maytag Dependable Care LAT9416
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Burning rubber smell followed by a hum and the washer stopped
Hi, there was some sort of gear trauma inside the gear case that locked up all rotation during full motion. I'm sure this destroyed the motor and all the windings inside the motor. the clutch was damaged as well. you may have to replace the entire drive assembly and motor. if you have a warranty, im sure this will be covered if the warrenty is still good.
Mar 14, 2009 | Washing Machines
Replaced Motor Coupling but now I have electrical smell when running
You can test the washer with the case removed by by-passing the lid switch. You will need to jumper the two BLACK wires at the lid switch connector (where it connects to the timer).
With the case removed, and the washer UNPLUGGED. Locate the lid switch connector and jumper the two BLACK wires. Plug washer back in and carefully turn the timer on to start. You will be able to visibly inspect the washer while it is running. The Drive Motor should not start running until the washer fills completely. Set the washer on the lowest water setting to reduce fill time. Usually electrical smells are attributed to the Drive Motor and/or Start Capacitor. Make sure the connectors are all on properly and not loose. Loose or corroded connections can cause arcing and/or burning. Inspect all the wiring for any signs of chaffing or burning. Use caution not to touch any of the electrical connections while the washer is running or energized. Running the washer with the case removed is primarily for giving you a visual for any obvious signs of problems. Any wire and connector checks should be done with power removed. I hope this information helps you. Please post back if you require further assistance.
Jun 05, 2008 | Washing Machines
GE WBSR3140DW Top Load Washer Logo
268 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
