Code t-16 shows on display and also will show door opening or closing but doesn't
SOURCE: hp laserjet 2600n printer showing message door open
there door censer problem. i fix new censer
Posted on Jul 10, 2008
SOURCE: GBC Shredmaster 5260X - door is closed by light indicates otherwise
This shredder has a magnet built into the door. If you open the door you'll see a metal strip on top right side of shredder. Either the magnet is not getting close enough to activate the reed switch or the hinges have came loose allowing a door sag condition. Also, if the shredder isnt that old, just contact GBC for some warranty work at 800-790-7787
Posted on Feb 10, 2009
SOURCE: rear hatch door won't lock dash light showing
You need to tighten the lock mech on the boot lid. this will close the boot just enough more to turn the light on. It's no biggy, you might need a star driver depending on bolt head. move it into the boot lid approx 4mm to start. then 1mm until 10mm. if no joy then it may be the sensor.
All the best
Ally A
Posted on Jul 25, 2009
  • 3051 Answers
SOURCE: how do I unlock the
Hello there:
This is a fairly common issue with ovens like these
You will need to unplug the oven from the wall or if it is hard wired find the breaker that feeds it and trip it now you will have to wait for 1 hour to allow the ovens internal reset feature to reset the oven controle panel now after is up AND NOT BEFORE plug in the oven AND YOU MAY HEAR A AUDIABLE BUZZ OR CLICK WITH IN ABOUT 5 MIN if so simply press the cancel button or if you have a reset button on it press it and now you will be able to resume what you were doing ok>
Hope this is very helpful for you
Best regards MIchael
Posted on Oct 10, 2010
SOURCE: Hoover washer/dryer VHW854D SHOWS ERROR
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
Posted on Dec 20, 2010
My BOSCH Axxis 24201UC washing machine displays "E:16" (which means "Door not closed properly") all the time, no matter what, and is inoperable
Check that the door switch is closing when you close the door with the latch mechanism. Unit will be dead unless the switch is closed.
Sep 20, 2017 | Bosch Washing Machines
Asko d1756 power trips when door is closed
The switch in the door may have a bare wire touching the sides causing a short. Check a schematic for the proper way to remove and test the switch. Look for bare wires or any insulation cracks.
Mar 15, 2014 | Dishwashers
Pioneer CJ-V51 CD jukebox error 1
1 Open top door (display shows OPEN)
2 Press and hold SERVICE button until beep (display shows P5)
3 Press and hold CLEAR button until beep (approx 25 seconds)
4 Press and hold SERVICE button until beep
5 Close top door
Apr 06, 2012 | Pioneer AVH-P4900 Car Video Player
The microwave display shows "Door" and it won't
I could have been more specific with a model number, but if this general answer doesn't do the trick, feel free to contact me with your full model and specific symptoms here.
It's usually a bad door switch or door switch mount. My helpful text file on door switches is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it's one of those overdesigned Whirlpools, it can be one of many components. See the example photo at the bottom of this reply.
Aug 03, 2011 | Whirlpool GT1195SH Microwave Oven
Erorr code -Err 1 is showing on our machine. Any ideas? Thanks.
Is this a Haier Washing Machine?
'coz I found an answer on their site..
"Q. The display shows Err 1. A. The door is open or not properly locked shut. Open and close the door, or firmly push the door shut until you hear a 'click'. If the problem continues, call the customer help desk or an approved service engineer."
Hope this helps.. :)
Jun 09, 2011 | Washing Machines
My GLTF2940ES0 WON'T START it's cycle. An error code "ddo" displays
The meaning for ddo error means "Dispenser Drawer Open"
To rectify this problem you should try opening and closing the door shut. There will be a magnet which shows that the door is closed or open.The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself to view the magnet. If the magnet is missing you have to replace it.
Thank you !!
Jun 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
After a power failure I am getting the code e1 f1 flashing on my display board and it will not go away.
q.gif Why is the display showing E"#"-F"#," for example, E1-F2?
Answer Is "PF" displayed on the control?
A temporary power failure has been detected. Press the Stop/Clear keypad to reset your control. You may need to reset your clock.
Is the display showing E0-F5?
The Self-Cleaning latch may be interfering with the oven door causing the Self-Cleaning cycle not to work. If the oven door is open and will not lock, press Stop/Clear to clear the display, press and hold the door switch plunger (located in the upper-right corner of the oven front), and the door latch will unlock. If the oven door is closed and locked, press Stop/Clear to clear the display; apply pressure to the upper-right corner of the oven door, and the door will unlock.
Is the display showing E"#"-F"#," for example, E1-F2?
You will need to schedule service.
please do not forget to rate and comment about your experience today. Thank you
Sep 03, 2008 | Whirlpool Kitchen Ranges
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
