Question about Garden
I have a Ryobi TR 190 riding lawn mower, when key is turned start position nothing happens.
I can turn the engine by touching both terminals at the selenoid and get no spark on plug ignition switch was replaced about ahead ago.
SOURCE: I have a 1993 murray lawn tractor 12.5hp Ignition Switch????
Take an ohm's and amp. meter and go to the ohm's setting and see which terminals are off and on. If you want to kill the engine put it on the off side. If you want to run anything put it on the start and run side of the switch. Hope this clears things up a bit. donnyb60.
Posted on Mar 24, 2009
  • 246 Answers
SOURCE: MTD riding lawn mower will not start. Know for
Hello:
>>From your Description it Sounds like the Clutch/Brake Switch Bracket has Bent and the Safety Switch is Not being Moved enough to Activate this Switch.
>>The Following is an Instruction File for the Safety Switch System. Any Input is Appreciated.
>>The Color Code of the Wires May be Different than those I Use as a Reference in the Instruction File.
>>**PLEASE REMEMBER THAT THE INSTRUCTIONS FOR CHECKING THE SAFETY SWITCHES IS JUST THAT!!! FOR CHECKING ONLY.
>>I NEVER Suggest a Mower be Operated with a Safety Device or Switch Disconnected or Bypassed.
>>**Now. On Some Model Mowers you can Simply Unplug the Safety Switch from the Harness. On Other Models you have to Place a Jumper Wire Between the Harness Terminals (on the 4 Post Switch (Clutch/Brake) Jumper from Same Color Wire (Example: White to White) First and then Check for Fire, Now Include the Black to Black Wires if No Fire. Check the Clutch/Brake and the Blade/PTO Safety Switches First. Then Check the Oil Guard Switch (if Applicable). Check the Seat Safety Last. Usually the Seat Safety is Not in the System for Starting the Engine. Just to Ensure Someone is in the Seat when Engaging the Transaxle and/or Blades. Use a Paper Clip or a Short Wire to Make a Jumper.**
>>Use a Multimeter and Check the Continuity of the Switch. The Meter should Show when the Contacts are Closed and Open. The Meter will Swing All the Way Over when the Switch Contacts are Closed and Swing Back to the Rest Point when the Switch Contacts are Open.
>>Send me the Model Numbers Off the Mower, Please. With these I can Locate the Proper Manual and Better Assist you. The Model Numbers are Usually Located Under the Seat on a Sticker or Tag on the Body.
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
  • 396 Answers
SOURCE: wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Posted on Oct 10, 2009
  • 13 Answers
SOURCE: nothing happens when you turn on the lawn mower
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Posted on Apr 16, 2010
SOURCE: rally ride on lawn mower not starting. briggs and
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
Posted on Jul 29, 2010
Getting ready for summer my lawn mower didn't start. I charged the battery and have power but nothing happens when I turn the key to start
take a screwdriver and firmly touch the positive to neg. on starter...if that turns the engine over...then its the selonoid or a bad connection......possibly could be the ground on the batt.
Mar 31, 2015 | Garden
When I turn the key on to start my Troy-Bilt RZT 50 zero turn mower, there is nothing. No ignition light, nothing. I have a new battery and I put a new fuse unit but still nothing. Help!
Do you hear a clicking sound???NO ?? Do you have the speed ?turning handles in the extrem OUT position? Is the ground cable connected to the engine block?? Is the Red cable connected to the + Positive post on the battery?? Is the BLACK cable connected to the - Negetive post on the battery?? Why did you need to replace the fuse? Is the battery charged??
If none of the above corrects the problem replace the ignition switch
May 02, 2011 | Mustang Rzt 50" Zero Turn Riding Lawn...
Craftsman 54 in lawn tractor W/ 26 hp Kohler engine
Could be, but test each item with your tester. Test key switch (12V in and 12 V out when turned to start., operator present switch 12V in 12V out (seat) Clutch switch, etc. till finally you test for 12V on the small terminal on the starter solonoid. Happy testing!
Jul 19, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Nothing happens when you turn on the lawn mower key for craftsman mower model 917 272072. I put a new battery in the mower, and new switch and a new solenoid switch but the mower don't make any noise when...
Apr 16, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Troybilt riding lawnmower - won't start
i have a troy built riding mower, just replaced battery, when i turn key sounds like battery is dead. what could be the problem?
Aug 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Husqvarna riding lawn mower will only click once but not turn over when key is turned on. Replaced battery but no help. What are some possible solutions
If you have a pair of jumper cables, connect one of the red clamps to the battery positive, then using the remaining clamp, touch the post on the starter and see if the starter turns over the engine.
Make sure the key is turned off and the transmission is in neutral.
Let me know if it turns over and we can go from there.
Regards,
May 14, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH Lawn Mower will not start
try wiggling the plug while turning the key.
you may have loose terminals inside the plug
May 05, 2009 | Husqvarna Garden
Husqvarna Ride Lawn Mower does not want to start, which theres about 1/2-tank of gas. My Husqvarna Ride Lawn Mower is only a few years old which I have done some routine maintenace. The lawnmower has set...
I've discovered that if you leave key on battery will be drained to dead. Checking battery with meter shows +12v. When key is turned to start position nothing happens. When you connect meter to battery terminals and put key to start position the meter reads about .250 VDC. Even after taking battery to Advance Auto and have it checked it still does same thing. Eventually I jumped my mower with another battery that was being used in my scooter. Bingo! all worked well with jump. You would probably be able to jump with car battery with no problem.
Mar 25, 2009 | Husqvarna Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
