Question about Kitchen Ranges
What does a micronta 22-171A test or what is it used for ,I'm not sure stereo components or kitchen appliances
  • Kitchen Ranges Master
  • 17,356 Answers
It is a Digital Multimeter for testing voltage, continuity, ohms and milliamps. The engineer will be very upset to lose it, so give them a ring.
micronta 22 171A Google Search
Posted on Dec 31, 2016
Tip
Best way to Fix Scratches on Your Radiant Smooth top Cooktop
Cooktops are in many homes and are a preferred kitchen appliance to many home owners. The Cook in the kitchen can appreciate the stylish look of a sleek radiant smooth top Cooktop . Many invest top dollar to have stainless steel appliances including the following: Refrigerator, Dishwasher and Compactor. Moreover, having a sharp looking Cooktop addition only compliments the style and design of any high end kitchen. Maintainence and care of such an essential attractive appliance such as a cooktop is important.
Here is the best way to fix scratches on your Radiant Smooth top Cooktop:
Step 1 - Prepare your Cooktop by cleaning the surface*Make sure the surface is cooled* Use a damp rag first and sweep of crumbs and food stuff. Use your favorite cleaner and rinse completely. Careful not to get moisture around knobs or switches. Dry off surface.
Step 2 -- Work on the scratch area
Run the sharp edge of a razor over the scratch around 3x and this will aid in smoothing out any raised ruff edges. Apply gentle pressure to the cooktop scratch area.
Step 3 - Apply A Cooktop Cleaner
Use a few drops of cooktop cleaner to the scratch area. Use a sponge to rub in cleaner. Use circular motions to allow scratch to absorb product. Run the razor edge over scratch again making sure not to apply to much pressure.
Step 4 -- Clean Cooktop surface again and remove cleaning product
Rise off cleaner and dry with a dry paper towel. Inspect scratch to test results. Repeat step 3 until you have desired results.
Special Note* Their are many ceramic cleaning products to choose from and many claim to be the best on the market. Be sure to choose one that has good reviews and then test the results. Special attention must be given to all radiant smooth top cooktops. Be sure to use only cookware that is recommend by the manufacturer. And be sure to clean spills as soon the cooktop is cooled to keep the appliance looking well. Deep scratches or pits cannot be removed or buffed out and may lead to a cracked cooktop.
on Dec 16, 2010 | Kenmore Elite 44173 30 in. Electric...
How do I use a micronta 22-212 ?
Unless you have a clamp-on ammeter, you can't use a multi-meter to test AC current. You can test volts or ohms, however. If you want to see if your heating element is still good, turn off the power, disconnect the wires going to the heating element then measure the internal resistance of the element. If it's "infinity" then it's open and burned out. For a 10kW heating element at 240V it should be about 6ohms.
Sep 22, 2014 | Water Heaters
My max exract 77 causes circuits to break
you need to plug your cleaner into a outlet that does not have other devices in use ,such as a lamp, tv , stereo/radio. If you use a receptacle In the kitchen you will probably not blow the breaker. make sure other kitchen appliances are not in use. - toaster , mixer, coffee maker etc.
Apr 28, 2014 | Hoover F6055-900 SteamVac Maxextract LS...
Micronta 22164 talking meter says low battery
Could be an internal memory battery that would be separate from the normal power batteries.
Jan 26, 2014 | Cars & Trucks
My 48" Viking Range top trips the GFI
One leg of the power is "dead shorted" to ground. Use a Multimeter and start looking/testing to determine which component is bad.
Aug 31, 2009 | Viking VGIC3074 Gas Kitchen Range
Cda electric cooker ,fan,
Test heating element continuity using a multimeter, then test temp probe, if there is nothing in ther , then test wiring harness to control panel and timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 09, 2009 | GE Profile Spectra JBP95 Electric Kitchen...
Kitchen Ranges Logo
93 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
