Question about Bosch Washing Machines
Bosch F/L WAE22460AU/09 stops during spin cycle. No error codes and power shuts down on machine only.unplug for 1 minute it resets and starts again. Drum moves more than usual. Recently moved house.
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
  • 1462 Answers
SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Posted on Apr 25, 2007
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
JR JR
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
  • 2976 Answers
SOURCE: Washing Machine Moves in Spin Cycle
There are 2 things you can do.
All washing machines have an off balance shut off, some are touchy, some let it run around the house. With wht machine empty, lean it towards you, on the 2 front feet, about 2 or 3 inches and let it drop. The self leveling feet in the rear must BOTH make good floor gontact and sometimes, just the weight of the machine will not adjust them. The other thing is, make sure the load is evenly distributed. Coats, blankets, small rugs etc. are very heavy when wet and they tend to throw all of the weight to one side.
There is no screw holding the yub in place. It hangs on the center post, where the agitator goes. There is however, what's called a snubber. It is a rubber device that looks like a flattened suction cup, that comes in contact with the tub. It helps keep the tub from jumping around too much.
Posted on Feb 02, 2009
I have a Bosch Maxx WFL 1662 washing machine. It does not stop washing and go over to the rinses sickle.Where do i start looking for the problem?
Hi Eric, There's two links below... 1st link is Bosch Washing Machine Error Fault Codes and the 2nd link is worth reading, The master reset is only part of the trouble shooting, I hope these help.
To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components. (This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
How To Fix Washing Machine That Is Not Spinning or Draining
Apr 02, 2016 | Bosch Washing Machines
Stops during wash cycle for about 1 min then starts again, stops, then starts, stops then starts. Does this several times before finally finishing the cycle.
Are you getting an error code? If not, Try unplugging it for 20 minutes.
Then plug it back in, The ccu might have to be reset.
Jan 27, 2013 | Washing Machines
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
Bosch 500 series washer E:27 error code?
turn dial to off. hold down both delayed start and spin select buttons and turn dial to the left one click, to the cold position. keep holding button until you here a click. let go of buttons and turn dial to off. Every thing should go back to normal. Just fixed mine and all is good.
Nov 21, 2010 | Bosch WFVC5400UC Washer
My Whirlpool Duet Font Loader Washer stopped 1 minute before the end of the spin cycle; and I need to know how to reset it so that I can start another load of laundry.
Remove the front panelfbee677.jpg and check the pump filterd05d32e.jpg for objects8b65c4c.jpg then grab the tech sheet behind the white box and use the diagnostic instructions.
You have any non-HE soap in there or 2 much the machine will overamp and act all weird and then shut down with error code flashing. If it is an F-21 it means a Long drain. Possible cause: Clogged filter, clogged/failed pump.de495ab.jpg
May 25, 2010 | Washing Machines
Hoover washing machine - door won't open and drum won't spin, error displayed is e08, ideas anyone? Thanks :-)
1. please provide the model number for the washer
2. this is a timer error code and it seems that it locked the door during the spin cycle.
There may be a malfunction sensor or you will need to unplug the washer to reset the washer to complete the cycle.
Something electronic has caused the washer to shut down to protect the electronic circuit. You may have a defective timer.
Mar 13, 2010 | Washing Machines
I have E3 error code on a Bosch washing machine maxx classic - what does it mean? thx!
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
Jun 11, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Whirlpool duet sport washer powering off during spin cycle
I had this problem with new duet sport washing machine. Service was out to fix under warranty (4 trips!) replacing water sensor and boards. Finally checked outlet and was told no neutral. ?? Charged us for that visit since not covered. Plugged into another outlet and it worked. Had electrician in, replaced original outlet (although saw no sign of bad connection) and washer worked again! Yippee until today when I had the same issues. Tried in another 2 outlets and still shut down after a few minutes (and in those few minutes it never really ran as it should) Went out to get an outlet sensor ($8 at hardware store). Plugged in and found no errors. Started washer again and it did run and completed cycle. Although estimate 1 minute of final spin cycle took almost 25 minutes (on QUICK wash no less!) Will have to monitor. See if we get lights on outlet sensor next time washer doesn'twork, see what other things in house are running, etc. (although washer on dedicated line). ONLY change since this happenned: We replaced our 30 y.o. electrical box. You'd think this would be better???
Nov 30, 2008 | Washing Machines
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
